The P0172 That Won't Go Away...
Discussion in '1st Gen. Tacomas (1995-2004)' started by uofmguy, Mar 4, 2020.
  1. Mar 4, 2020 at 2:21 PM
    uofmguy
    uofmguy [OP] Member
    1999 3.6L 4x4 TRD OR
    Hi all,
    I've got a '99 5VZ-FE and I'm looking to get some help with an issue that has been plaguing me for a couple of months...a dreaded P0172 that won't go away...
    Bit of back story...
    When i first bought the truck, I had a misfire (P0303) and rough idle. I swapped out coils, plugs, and wires. The misfire went away but the rough idle stayed. A couple weeks later the misfire returned (P0303).
    I then purchased some matched re-manufactured fuel injectors (figured it may be a failing injector, why not swap em all), cleaned out the throttle body, cleaned out the (very gummed up) IAC, and replaced the fuel pressure regulator. The misfire went away but the P0172 still remained. I finally swapped in my friends 4runner MAF and that didn't do anything...
    Overall, the things that have been replaced/cleaned so far:
    1. New OEM Coils
    2. New OEM Wires
    3. New Plugs (NGK)
    4. Fuel OEM Filter
    5. Re-Man OEM injectors
    6. Cleaned Throttle Body
    7. Cleaned IAC
    8. New OEM Fuel Pressure Regulator
    9. Swapped in friend's MAF
    So, here I am now with a P0172 and a rough idle still...What should my next step(s) be? Change the IAC? Can those things fail and cause the symptoms that I have?
    Many thanks for the help in advance!
  2. Mar 4, 2020 at 3:17 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Have you ever hooked this up and read your fuel trims To see if this is a real issue or is tripping from damage someplace
    What are the O2 heater circuits like and the wire harnesses ?
    When you say Rough idle what do you mean since it seems The PO172 is the only code you have .
    Bad injector keeping the plug to wet to fire but not tripping a ignition miss.
    Do you have a California or Federal package ??
    rtilton12, uofmguy[OP] and djohn24 like this.
  3. Mar 4, 2020 at 4:37 PM
    zach141b
    zach141b Well-Known Member
    Zach
    Louisiana
    2001, double cab, 4WD, 3.4L Tacoma
    P0172 is too rich Bank1. I would inspect the air filter. (Not enough air, too much gas = rich?)
    uofmguy[OP] likes this.
  4. Mar 4, 2020 at 4:38 PM
    djohn24
    djohn24 Well-Known Member
    Dennis
    Pa
    03 Double cab SR5 Tacoma 4x4
    How about your air/fuel sensor? Ever been replaced? I had a lean condition. Negative fuel trim. I replaced the MAF, air fuel sensor and it's been running like a champ ever since.
  5. Mar 5, 2020 at 9:15 AM
    uofmguy
    uofmguy [OP] Member
    Hi guys, apologies for the late responses...replies below. Thanks for the questions and feedback!
    @Wyoming09 - I read my fuel trims this morning...at idle both long and short term are around -20%. While accelerating the both go to about -5%.
    I haven't checked the O2 circuits yet, but the voltage readings of Bank 1 sensor 1 and sensor 2 are both about 0.9V.
    Rough idle meaning a slight shudder while in idle, it's a rhythmic vibration but it kind of makes the cabin shake a small bit. Noticeable only at idle. The engine surges ever so slightly, the needle doesn't often reflect it though.
    I swapped out all of the injectors and the P0172 stayed, so I don't think it's a bad injector...
    Not sure what package I have, likely California as the vehicle was sold in and only ever been in California?
    @zach141b - just bought a new air filter for it the other day...still no luck. Thinking it might be an air related issue too since I have done a decent amount to the fuel system.
    @djohn24 - I am not sure if the AF sensor has been replaced...is this the one on the throttle body?
  6. Mar 5, 2020 at 9:21 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    1999 Tacos have 2 O2 sensors
    No a/f sensor
    Vac hose leaks?
    uofmguy[QUOTED][OP] likes this.
  7. Mar 5, 2020 at 9:36 AM
    uofmguy
    uofmguy [OP] Member
    I don't think there are any vacuum leaks, I had a shop run smoke and compression tests to check for leaks and nothing showed...
  8. Mar 5, 2020 at 9:39 AM
    Black DOG Lila
    Virginia
    Smoke test is good for EVAP lines.
    I'm talking about manifold vac hoses that need vac gauge testing or just replace them.
  9. Mar 5, 2020 at 9:43 AM
    uofmguy
    uofmguy [OP] Member
    Got ya, I haven't checked the intake hoses, I would imagine the shop I took it to checked for them as well if I brought it in for this issue? I will take a look at them today to see if there are any cracks or leaks. Any suggestions as to which one to start with?
  10. Mar 5, 2020 at 9:50 AM
    Black DOG Lila
    Virginia
    EGR, Modulator, Intake,Throttle body. Cracks in large intake from air filter box to Throttle body and loose or missing clamps.
  11. Mar 5, 2020 at 9:52 AM
    uofmguy
    uofmguy [OP] Member
    Many thanks! I will take a look at all of these today. Really appreciate the help!
  12. Mar 5, 2020 at 9:54 AM
    Black DOG Lila
    Virginia
  13. Mar 5, 2020 at 10:06 AM
    Black DOG Lila
    Virginia
    930508EB-CBF1-45C9-B67D-8F66B120B449.jpg I didn't see a new air filter on your parts replaced list.
    If you pop open the air box and want to kick yourself please post the fix
    :rofl::rofl::rofl:
  14. Mar 5, 2020 at 10:10 AM
    uofmguy
    uofmguy [OP] Member
    HA! I didn't know you could walnut blast your air filter!
    I replaced the air filter yesterday as suggested by @zach141b with no change...thankfully no nuts in there! It was, however, backwards so whoever put the last one in there screwed up (probably me).
  15. Mar 5, 2020 at 12:26 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    You must have great luck to have never gotten a bad part of the box .
    That seems to happen quite often as of late .
  16. Mar 5, 2020 at 1:41 PM
    uofmguy
    uofmguy [OP] Member
    good point, I can re-check all the parts that I purchased...I always assume new = works fine, but have also seen it mean "Never Ever Worked" :devil:
  17. Mar 5, 2020 at 6:22 PM
    zach141b
    Zach
    Louisiana
    Okay, to OP, from my experience five years ago. I replaced the air filter. The CEL came on and stayed on. I worried and fretted and cleaned the MAF. CEL stayed on for 100 miles, truck ran fine. WTFO, right? What's the big deal here? So then I cleaned the PCV valve, and the CEL went out and stayed out. As I cannot connect exactly how that would've solved my problem, I put it down to the ECU just finally "learning". Whether this combination of events is accurate or even possible, I cannot say.
  18. Mar 6, 2020 at 5:14 AM
    djohn24
    Dennis
    Pa
    Ok, I stand corrected. I didn't know that the 99s' did not have an air/ fuel sensor. That is the first sensor below exhaust manifold before cat. Apparently, you only have oxygen sensors on yours. The -20 even at idle is pointing toward your issue. Suppose to be -10 to +10 for normal operation. I do know that high positives readings can point toward vacuum leak. I would replace your o2 sensors
  19. Mar 6, 2020 at 5:40 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Here are some more troubleshooting steps.
    1997tacomav6[QUOTED] likes this.
  20. Mar 18, 2020 at 10:28 AM
    uofmguy
    uofmguy [OP] Member
    bump
    Both Up and Downstream O2 sensors replaced...tried spraying carb cleaner on intake hoses to check for a leak, but nothing happened.
    I started pulling vacuum hoses off to see what changes might happen, and when I removed the air cleaner "Vacuum Line" circled in red on the attached photo, my fuel trims both went up to about -5%, and STFT cycled between +/- 5%...
    Any thoughts?? Thanks for all the help in advance!
