The NorthStar AGM Battery + Voltage Booster Upgrade
Discussion in 'Technical Chat' started by crashnburn80, Apr 14, 2019.
  1. Jan 26, 2021 at 6:56 PM
    #821
    Bwthomas77
    Bwthomas77 Well-Known Member
    North Carolina
    12 dbl cab trd sport 6spd
    Supercharger, flowmaster exhaust, 4runner disc brakes, Volant CAI, ECGS bushing
    Well after much discussion with batteries plus bulbs, it looks like nationally there is a long delay on the x2 27f. My option was either go with a marine battery version with a shorter warranty or the odyssey. So I chose the later.
    The eBay diode seems to be doing the job. At idle with all my stuff turned on it was 13.8v, went to 14.2 with the diode installed. At idle with all the accessories and lights off it is at 14.45, over the 14.4 threshold. I think I am good.
    crashnburn80[OP] and Norton like this.
  2. Jan 30, 2021 at 8:28 PM
    #822
    agbofortsi
    agbofortsi Well-Known Member
    2015 Prerunner Sports Series
    Hello Cr
    Hello CrashnBurn,
    Needless to say, this is an old thread that has some utility and currency for me because the battery on my 2015 Tacoma Prerunner DC with a tow package has just sailed to the bottom edge of the south pole without advanced notice and I am actively in the market for a new one. I have gravitated towards NorthStar AGM (X2 Power) because my research findings have dictated my leaning.
    Here is my use case:
    1) Truck will be shipped to Ghana, West Africa, in three months.
    2) The weather in Ghana is very hot.
    3) Truck will be used occasionally. Certainly not on a daily basis.
    Now, let me tap your expertise:
    1) Is NorthStar AGM (X2 Power) the optimal choice?
    2) Will the fixed (.5) voltage booster suffice and is it safe?
    3) Is the booster truly plug-and-play with no extra set-up?
    4) Does the voltage of the truck need re-calibration?
    Looking forward to hearing from you very soon.
    Cheers,
    agbofortsi
  3. Jan 30, 2021 at 11:03 PM
    #823
    crashnburn80
    crashnburn80 [OP] Vehicle Design Engineer
    Kirkland, WA
    2003 DCSB TRD OR
    1) High heat negatively affects all batteries, but a quality sealed AGM should fair better than a flooded battery which will likely vent its water content.
    2) 0.5v booster is the recommended option under the conditions I have tested, though I have not tested in extreme heat. Under the conditions I have tested 0.5v is optimal and safe.
    3) The booster is plug and play in 2nd Gen trucks with nothing else required. 3rd Gen has ECU voltage control complications, meaning the booster does not work in 3rd Gen.
    4) No calibration needed, the booster is the calibration. It makes the regulator see -0.5v so the regulator compensates and boosts the alternator +0.5v, elegantly simple.
    Here is some Q&A from Oddessy on hot weather battery info. Note the Northstar falls under the 99.99% pure lead thin cell battery tech discussed in the article.
    https://www.odysseybattery.com/news/faq-how-to-protect-your-battery-against-the-summer-heat/
    d.shaw likes this.
  4. Jan 31, 2021 at 1:45 PM
    #824
    agbofortsi
    C&B,
    Thanks a lot for your prompt response, time and kindness. Based on your input and the referenced article, NorthStar is the way to go.
    I have four Texas Special Edition rims (265/65R17) that I would like to give to someone - free. Let me know if you know someone who would be interested; otherwise, I will post the offer on Tacoma World. They are as good as new.
    Cheers,
    agbofortsi
  5. Jan 31, 2021 at 2:30 PM
    #825
    agbofortsi
    C & B,
    Is this HKB Electronics' 0.5v voltage booster?
    Thanks,
    agbofortsi
  6. Jan 31, 2021 at 2:44 PM
    #826
    agbofortsi
    C&, these are the options for the 2015 Tacoma:
  7. Jan 31, 2021 at 2:45 PM
    #827
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You want the micro one of the far left.
  8. Jan 31, 2021 at 2:45 PM
    #828
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I agree that Northstar is a good choice, if you can find one...
  9. Jan 31, 2021 at 2:56 PM
    #829
    agbofortsi
    C&B, it's me again. Where can I purchase this item? From HKB's site or is it available in the US? HKB's prices are quoted in AUD. Does this mean the item will be shipped from Australia and the site will convert to USD?
  10. Jan 31, 2021 at 3:23 PM
    #830
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You can order from HKB direct. Shipping does take a little while. Prices are shown in AUD and 1 AUD = 0.76 USD today. You can also buy from HKB on ebay, though I don't know that there is any benefit, still ships from the same place.
    https://www.hkbelect.com/product/182-mk2-micro-blade-75a-electronic-fuse-version-2014/
    mac_2_nite likes this.
  11. Jan 31, 2021 at 6:42 PM
    #831
    agbofortsi
    C&B,
    I know I am bothering you; but please bear with me. I have a 1993 Toyota Pickup 4WD manual shift which I will never give up for all the money on planet earth. Can I upgrade the battery to AGM. If yes, do I need voltage booster?
  12. Jan 31, 2021 at 7:47 PM
    #832
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    If it has the Alt fuse in the fuse box. You can do the voltage booster and AGM battery.
    @crashnburn80 will correct me if I'm wrong
    crashnburn80[OP] likes this.
  13. Jan 31, 2021 at 7:52 PM
    #833
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I didn’t check my 89 or 94 for the alt-s fuse, but if it has one it will work as @BenMara mentioned.
  14. Jan 31, 2021 at 8:57 PM
    #834
    agbofortsi
    Dang,
    When did you order the voltage booster? Did you receive it? How long did the delivery take? Finally, how much did you pay (USD)?
    I ask because I would like to order the booster but I don't know if the supply chain has been disrupted by Covid. I wouldn't want to place and order and sit in limbo waiting for it.
    Thanks for your help.
    agbofortsi
  15. Feb 7, 2021 at 9:16 PM
    #835
    6 gearT444E
    Deep South
    Herculiner Hootus
    I found something funny today inadvertently, maybe a cheap way to boost the battery voltage. Years ago when I did my "fog light anytime mod", I tapped into the white sense wire (at the time I didn't know what that wire was in the fuse box, just that it had voltage all the time even with the key out). I noticed driving tonight that when I switched the fogs on, my battery voltage went up almost 0.6V due to the voltage drop on that wire from energizing the fog relay. Since I already installed the voltage booster, it bumped my voltage up to almost 15.5 volts which was too high for my liking and now that I'm aware of it, I'm going to switch where I have the fog relay positive tapped from. But for those that want a cheap voltage booster, just hook up a toyota relay up to the sense line lol. And got me to thinking that if you could source a potentiometer of the right range, you could calculate the voltage drop and have essentially an infinite adjustable voltage booster.
    Rob MacRuger, ToyRyd04 and Tremors834 like this.
  16. Feb 11, 2021 at 5:18 PM
    #836
    Dang Quesadila
    Dang Quesadila Well-Known Member
    SW Florida
    2011 TRD Sport DCLB 4WD
    Dobinsons/ MLO GTS Suspension, FJ 17" wheels, RIGID LED fogs, X2Power AGM battery, Extended stainless/braided brake lines, OBA.
    I paid $176 shipped.
    I ordered it on 9/15 and there was a bit of a delay but I was ok waiting a bit.
    They emailed me immediately to let me know they were waiting on customs forms before they could ship and offered me a refund if I was unable to wait.
    They shipped it out on 9/27 and it didn't take too long to arrive after that.
    Seems like a great company with great customer service and communications!
  17. Feb 16, 2021 at 12:20 PM
    #837
    onesojourner
    onesojourner Well-Known Member
    The Ozarks
  18. Feb 16, 2021 at 12:55 PM
    #838
    Norton
    What "oddesey QA decline"? Are you confusing Odyssey with Optima, whose quality went downhill after moving production south of the border?
  19. Feb 16, 2021 at 1:12 PM
    #839
    onesojourner
    The Ozarks
    Very possibly. Do you have the details. I may be confusing brands.
  20. Feb 16, 2021 at 1:25 PM
    #840
    Norton
    I have no details beyond what I said - Optima was considered a solid brand until they moved production south of the border, after which their quality became more hit and miss. I'm unuaware of such concern with Odyssey's quality, nor any expected decline in Northstar's now that they're combined.
    Perhaps you could provide details of the "QA decline" your post referenced?
