The JBL upgrade they didn't want you to have
Discussion in 'Audio & Video' started by JasonT87, May 21, 2016.
  1. May 21, 2016 at 3:49 PM
    JasonT87
    JasonT87 [OP] Well-Known Member
    Southern California
    '16 TRD Sport DCSB
    Total Chaos mid-travel front. JD Fab SUA rear.
    So here's the scoop. I purchased my truck and it came with the JBL package. I looked for one without because I knew I was going to gut it of the factory speakers and came up with nothing so here I am.
    2016 TRD Sport DCSB. JBL with Entune package. I've been following everyone else's 2016 stereo builds here but apparently I'm the first on here with the JBL package? So kinda treading into unchartered waters...that is until @Mr Marv came along and solved probably the most complicated part of this whole setup.
    I was going to follow everyone else and make a new metra harness from the factory HU to a 'summing device' aka my Audio Control LC6i. That isn't the case with the JBL package which has a factory amp next to the factory sub behind the rear seats.
    The build:
    Keep the factory HU for essentially the same reasons everyone has already stated: 'simplicity' (hah!) and integration. All speakers will be upgraded. A sub and enclosure will be added with an amp to power all. A Line-Out-Convertor in place to put the sound back in the music that the factory amp takes away.
    The parts:
    JBL GTO 609c 6.5" components for front doors.
    JBL GTO 628 6.5" 2-way for rear doors.
    JL Audio 10TW3-D4 Subwoofer
    Audio Control LC6i
    Kicker 16g speaker wire
    Mr Marv speaker adapters
    ArcAudio xdi 850.5 amp
    Amp wiring kit
    Mr Marv sub enclosure
    RAAMaudio BXT ii sound deadener
    Nedrolls, Man of Steel TRD and Ch78 like this.
  2. May 21, 2016 at 3:50 PM
    JasonT87
    Southern California
    '16 TRD Sport DCSB
  3. May 21, 2016 at 3:50 PM
    JasonT87
    Southern California
    '16 TRD Sport DCSB
    Subbbb
  4. May 21, 2016 at 3:50 PM
    JasonT87
    Southern California
    '16 TRD Sport DCSB
    And sub
  5. May 21, 2016 at 5:31 PM
    Ch78
    Ch78 GBO!
    Tomball, TX
    25’ Landcruiser 1958
    Tuned By D3 Performance
    Following
    JasonT87[OP] likes this.
  6. May 21, 2016 at 11:52 PM
    Man of Steel TRD
    Man of Steel TRD Ignorance is the new normal
    Jeremy
    Gilbert, AZ
    2021 Ram Limited Night Edition, 91 300ZXTT, 90 Toyota Pickup ECLB
    Tow package, LED interior lighting, led low beams, led fog lights, led licence plate lights, OEM bed mat, OEM mud flaps, OEM chrome raised tailgate letter inserts, nerf bars, AVS ventshades. Complete Kicker audio system (4 channel amp, mids and tweets in the front, 2 ways in the back, 2 10 inch comp rt subs, Zxsum8, alpine pdx 1.600 boxes and amp rack by Mr Marv), Pop & Lock, Mobtown locking bed storage doors, Bilstein 5100s, Katzkin Leather interior, Redline Hoodstruts, Backflip.
    Good to see you started a thread. Install looks like it is going well. I take it you figured out the wire colors for those tweeters. Can't wait to see it all done.
  7. May 22, 2016 at 9:02 AM
    JasonT87
    Southern California
    '16 TRD Sport DCSB
    Haha yeah. There is no wiring diagram to help that I've found or heard of, basically had a 50/50 chance of it working. Your advice about the stock speaker clips and the hot wire was helpful and ended up being correct. I will make a note of that on here also.
  8. May 22, 2016 at 9:10 AM
    Guerrilla
    Guerrilla L(.)(.)K@G(.)(.)Dz
    D. Cooley
    Coast to Coast
    El' Black 13 DCSB 4x4
    Stuff
    Double (I mean triple) subbing to your own audio thread.. Does that mean you're gonna put subs in or just saving those spots?:notsure:
  9. May 22, 2016 at 9:15 AM
    JasonT87
    Southern California
    '16 TRD Sport DCSB
    Yes and yes
  10. May 22, 2016 at 2:53 PM
    Ch78
    Ch78 GBO!
    Tomball, TX
    Did you have to use an aftermarket wiring kit for the speakers since you went with JBL?
    Got links for the components you used? You know, because Google is hard. :annoyed:
    TurboGT and ManBeast like this.
  11. May 22, 2016 at 5:16 PM
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Just look the models name up on Amazon man. It's not that hard. You could have done it in the time it took you to write that post. Took me 2 minutes to find you the links on amazon and write this.
    http://www.amazon.com/gp/aw/d/B003K...jbl+gto638&dpPl=1&dpID=51T2bYz71fL&ref=plSrch
    http://www.amazon.com/gp/aw/d/B00AN...bl+gto609c&dpPl=1&dpID=51QeZpqTO-L&ref=plSrch
    solscooter likes this.
  12. May 22, 2016 at 5:21 PM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
  13. May 22, 2016 at 5:22 PM
    Ch78
    Ch78 GBO!
    Tomball, TX
    I was bumping his thread more than anything. Notice the sarcasm at the end? I'm not that lazy but I know other people are.
  14. May 22, 2016 at 5:23 PM
    arkywally
    arkywally Well-Known Member
    David
    2016 DCSB TRDOR
    ICON Stage4 285/70/17 Cooper STT Pro Method NV
    Interesting enough to see how it all goes....
  15. May 22, 2016 at 7:04 PM
    JasonT87
    Southern California
    '16 TRD Sport DCSB
    As @1sttruckguy78 mentioned, I went on Amazon for the speakers and actually a majority of my parts. Helps to have prime also :)
    I did not need a speaker harness like other guys have used (Metra harness + stinger speed wire). I just clipped the wires off the old speakers then used butt connectors to 16ga speaker wire then soldered and heat shrinked the wire to the new speakers
  16. May 23, 2016 at 2:57 PM
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    Sorry about that. I'm so used to seeing others just being lazy. My bad man.
  17. May 23, 2016 at 3:17 PM
    Ch78
    Ch78 GBO!
    Tomball, TX
    No worries. I see it constantly in the "What have you done to your 3rd gen today" thread.
  18. May 23, 2016 at 3:23 PM
    Man of Steel TRD
    Jeremy
    Gilbert, AZ
    That's exactly where I have seen it running rampant. Forgiveness is golden brotha.
    Ch78[QUOTED] and JasonT87[OP] like this.
  19. May 23, 2016 at 11:20 PM
    JasonT87
    Southern California
    '16 TRD Sport DCSB
    Couldn't wait for the Shok Ind GB, purchased RAAMaudio BXT ii, should be in by this weekend. Amp and sub is next, then have @Mr Marv do his magic for an enclosure. Soon gents, soon.
    Man of Steel TRD likes this.
  20. May 23, 2016 at 11:29 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You are still not going to be happy with the sound that the stock HU is capable of pushing. There are ways around it, but the methods end up being just as expensive if not more than just replacing the headunit as a whole if you want quality sound. Not only that. The stock speaker amp is very limited to it's capabilities as well. SEVERELY. You basically have 8 ohms being driven to the speakers when the ones you are currently running are 4 ohms. They will work, but they will not last the test of time, especially if you like to play your music loud.
    My advice? If you want to save yourself space and avoid making custom enclosures get yourself a compact amp and your choice of headunit, rewire as necessary and call it a day. Stock JBL headunits and amplifiers suck on these trucks. Shame too, because the headunits are graphically pleasing GUI interface friendly for the most part and nothing beats OEM wire cleanliness at the rear of the stereo. Plus, they have everything in them that a modern day stereo could really want.
    I'm telling you, you will be walking into the wolves den if you decide to keep the OE amp and headunit.
    If you would like I could see if there are wiring schematics available for 2016's and post it if you need them. I have access to all of that stuff.
    Soul Surfer and IronPeak like this.
