the elusive jbl amp wiring diagram
Discussion in 'Audio & Video' started by jslum, Feb 11, 2013.
  1. Feb 11, 2013 at 8:40 PM
    jslum
    jslum [OP] Well-Known Member
    jason
    SoFL
  2. Feb 11, 2013 at 8:50 PM
    whonoez
    whonoez Well-Known Member
    Jay
    Bay Area
    2013 Tacoma TRD Sport DCSB
    3"lift, Monster XD w/ 285/65/18 Nitto Trail Grapplers, Blacked out emblems, tinted front windows, BHLM
    I would like to know this too! Sub'd!
  3. Feb 11, 2013 at 8:52 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
  4. Feb 11, 2013 at 10:01 PM
    jslum
    jason
    SoFL
  5. Feb 11, 2013 at 10:33 PM
    blake5995
    Blake
    Truckee, CA
    why dont you just take the speaker wire that is going to the amp in there now and convert them to RCA to use on a aftermarket amp?
    firelu likes this.
  6. Feb 12, 2013 at 6:30 AM
    kevinsc
    kevinsc 2012 dbl cab 4x4
    kevin
    Lexington, south carolina
    12 4x4 dbl cab
    chrome on front painted to match, satoshi grill done by myself, BHLM, billys all the way around with ome springs upfront and LR ucas with wheelers 3 leaf progressive pack in the rear, mb gunner wheels powdercoated black on 285/75r16 nitto trail grapplers, tinted all the way around and on windshield, pioneer dbl din touch screen with two 10's behing the seat and new speakers all the way around and certain interior parts painted to match, also have a road wire leather kit black with red stitching sitting here waiting for me to find time to install it!
    so you need the wire colors for the speakers at the amp? if so i can get that for you...
  7. Feb 12, 2013 at 6:40 AM
    jslum
    jason
    SoFL
    Yes. That is exactly what I need
  8. Feb 12, 2013 at 6:43 AM
    kevinsc
    kevin
    12 4x4 dbl cab
    tell me if this is what you need..
    wires for jbl system at the amp on the rear wall
    driver front door
    -On vehicles with amplifier, the speaker wires are pink(+) - purple(-) at the amplifier, white 12 pin plug, pins 2 and 1. The tweeter wires are red/white(+) - red(-) at the amplifier, blue 10 pin plug, pins 8 and 7
    pass. front
    - the speaker wires are lt. green(+) - blue(-) at the amplifier, white 12 pin plug, pins 9 and 3. The tweeter wires are blue(+) - pink(-) at the amplifier, blue 10 pin plug, pins 2 and 6.
    driver rear
    - the speaker wires are black(+) - yellow(-) at the amplifier, blue 10 pin plug, pins 3 and 9.
    pass. read
    - the speaker wires are red(+) - white(-) at the amplifier, blue 10 pin plug, pins 10 and 4.
    factory sub
    (sub wires are run parallel with the rear speakers)
    - the speaker wires are green/yellow - green/white pins 5 and 12 (1); blue/black - blue/red pins 4 and 10 (2) at the amplifier, white 12 pin plug, ; .
    hope this helps
    *BY ALL MEANS THIS IS NOT YOUR BASIC EVERY DAY INSTALL THAT ANYBODY CAN DO. IT SHOULD BE DONE BY A PROFESSIONAL OR SOMEONE WITH GREAT KNOWLEDGE OF AUTO ELECTRONICS AND HOW THESE NEW SYSTEMS WORK AS YOU CAN SEVERALY DAMAGE YOU VEHICLE!
    Ciscokid559 and TRDSport10 like this.
  9. Feb 12, 2013 at 6:50 AM
    jslum
    jason
    SoFL
  10. Feb 12, 2013 at 1:31 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Ummm, if this works, I'll be amazed.
    Lemme edit:
    Replacing the stock amp with an aftermarket amp will do nothing for you.. if I works. JBL speakers are a custom impedance, I forgot how much though. Your amp probably wont put out much more than the stock power, and if it does, it will probably blow the little crap speakers.
    Replacing anything in the JBL system without replacing the entire system really isn't worth it man. I'm telling you this because I've been there. The only thing that is sorta nice is replacing the head unit....but you gain little.
    I did it all, until eventually I got rid of it altogether.
  11. Feb 12, 2013 at 4:53 PM
    jslum
    jason
    SoFL
    Yeah im planning on replacing the entire system but for now I want to keep the stock head unit
  12. Feb 12, 2013 at 5:09 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I suggest you just replace the speakers for now with good components that you can reuse later when you're ready to replace everything else but since you're taking off your door panels, use sound deadning!
  13. Feb 13, 2013 at 6:30 AM
    kevinsc
    kevin
    12 4x4 dbl cab
    edit: sorry to anyone who recieved the wrong info from my post but jslum has pm'ed me and we have talked more about this and he is either wanting to remove just the factory sub and wire in a line level converter that works with the jbl system to run a sub amp and a new sub.. or we also talked about running a 5 channel amp and replacing all door speakers and a new sub.. which will work just fine as long as you have the know how.. if you are not sure of how to do this do not hack up you truck and try because it is an above average job! i know this works because i have done this same type of install when you change all factory speakers to new speakers and and bypass amp on the factory units to put a new amp in on these vehicles tacoma with the jbl system, a charger with the 8 inch sreen and factory amplified sytem, yukon with bose amplified system, infinity g-35 with the bose system and many other factory amplified systems with factory nav or if they just didnt want to change the factory radio..
  14. Mar 4, 2015 at 12:22 PM
    Max1588
    Max1588 Well-Known Member
    Brian
    Mount Pleasant, TX
    15 4X4 V6 SR5
    Lots
    So my question is, is the JBL headunit sending signals to the amp rather than powering the speakers? Im asking because I really like the factory radio, and if I get a harness to plug into the back of a JBL radio, and wire it to an aftermarket amp's low volt input, than I should be good correct? I have the non JBL system as of now, and have done a factory integration with an alpine amp and JBL speakers. I don't even know if that makes any sense, im tired... lol
  15. Nov 9, 2016 at 6:11 PM
    hazard2600
    hazard2600 Well-Known Member
    Ted
    Watertown, TN
    2009 White 4x4 SR5 TRD Sport LBDC V6
    3" ProComp sus lift 2" Roger Brown body lift 33" BFGs ko2s 1.25" spidertrax wheel spacers Custom rock sliders Seat covers USB ports OBD2 computer monitor
    Is there a 12v line going to the amp to activate it? I want to run a switch on it to activate and deactivate it. I have a lot of noise coming from it and only want to turn it on when I wanna rock. :)
  16. Nov 11, 2016 at 6:40 PM
    DunkinDal
    DunkinDal Active Member
    South of Boston
    2015 TRD Off Road
    attached is the wire diagram for a 2013 with jbl
    SteveStPaul, TRDSport10 and mattgecko like this.
  17. Nov 15, 2016 at 2:20 PM
    fergsonfire
    fergsonfire Electrical Guru
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    glad to see that is getting good use
  18. Dec 31, 2016 at 8:22 PM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    Thanks for sharing that PDF. :thumbsup:
  19. May 31, 2017 at 8:06 AM
    TRDSport10
    TRDSport10 Well-Known Member
    Rhode Island & Virginia
    '10 AC TRD Sport 4x4 - Silver
    TRD Exhaust, Tube Steps, Towing Hitch, Paint Protection Film, Bed Mat, Wheel Locks, Spare Tire Lock, First Aid Kit, Ashtray Cup, TRD Air Filter, TRD Oil Cap, TRD Radiator Cap, FJ TRD Hub Caps, FJ TRD Shift Knob, BackFlip F1, TSB Rear Springs, Coupe TRD Battery Hold Down Bar, KatzKin Leather Seats with W.E.T. Seat Heaters, WeatherTech: FloorLiners DigitalFit, Side Window Deflectors, ClearCover License, LampGard
    Anyone have similar wiring diagrams for 2010 and / or 2011 Tacoma JBL audio systems?
    Haydude28 and firelu like this.
  20. Jun 26, 2020 at 6:51 PM
    firelu
    firelu Well-Known Member
    el monte, Ca
    2011 4x4 sport package
    Smoked tail lights, blacked out emblems
    Is there a harness for that?
