The Dreaded Throwout bearing chirp
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blue92, Sep 1, 2018.
  1. Sep 1, 2018 at 4:35 PM
    Blue92
    Blue92 [OP] Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Well, Ive figured out the source of the chirping coming from my Dads 2008 DCSB V6. Throwout bearing chirp. It goes away when the clutch is engaged. It has 3 new idler pulleys, a new belt, and a new bearing in the tensioner pulley so that rules out the front of the engine. After much research Ive determined that the symptoms match the throwout bearing TSB. I understand the URD sleeve kit is the way to go here. Truck has 115k on it. Anything else that should be replaced? I guess my most important question here is, how long should I let this go? It started a few weeks ago. Still very faint but its there. Its still under a powertrain warranty until next August. Hopefully I can get the dealer to cover labor under the warranty and I'll just get them to install the URD kit.
  2. Sep 2, 2018 at 7:05 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Bump. Anyone?
  3. Sep 3, 2018 at 5:58 AM
    k5driver
    k5driver I hate bums
    Montana
    2009 4x4 DCSB MT SR5
    Blue92[OP] likes this.
  4. Mar 31, 2021 at 6:15 PM
    Alexander20
    Alexander20 Member
    2007 Tacoma TRD Off Road
    Thought I would share my experience with the Throw Out Bearing squeal on this forum.
    I have a 2007 4.0 6 Speed Tacoma.
    I got a shop to replace my OEM clutch with a LUK clutch, after a couple days of driving I noticed a metallic chirp sound any time I engaged or disengaged the clutch. Shortly after I noticed a squealing sound coming from around the bell housing area.
    When I went back to the shop who replaced the clutch, they said it could just be a faulty throw out bearing that was put in, so they once again put in a brand new thowout bearing. This only got rid of the noise temporarily, the squeal and chirp came back. I decided to look online and found many threads about this seemingly common issue with these 6 Speed transmissions.
    While I spent months reading online, trying to find a solution to this problem, the noise continued to get worse and worse. The options I found to try and solve the issue were either:
    - Clutch Masters Hydraulic Release Bearing
    - URD Throw Out Bearing Sleeve Kit
    - Toyota TSB "Fix"
    After reading about people's experiences with the CM Hydraulic Release Bearing (Loss of fluid, inconsistent pedal feel)
    I decided against that option because of the mentioned unreliability of the product.
    I finally decided to go with a combination of the URD Throw Out Bearing Sleeve Kit and the Toyota TSB.
    I had a shop install the URD Kit, while also replacing the original Slave Cylinder and Fork Support that came with my truck with the updated TSB parts.
    So far (drive from the shop to my house), there has been no squeal or chirp. I will periodically post updates on whether or not my truck remains squeal and chirp free.
    jsev likes this.
  5. Jan 18, 2022 at 8:29 AM
    liftedhippy
    liftedhippy New Member
    Colorado
    2007 Tacoma
  6. Jan 18, 2022 at 10:00 AM
    Alexander20
    Alexander20 Member
    Roughly 8-10,000 km of driving on it, no noise or clutch issues have returned so far.
    Marc70 and GilbertOz like this.
  7. Jan 18, 2022 at 12:09 PM
    liftedhippy
    Colorado
    2007 Tacoma
    @Alexander20 Thank you for the response! I did the TSB when I first got the truck, twice. Now she's screaming! Sleeve, and 3rd time's a charm! So it is!
    Alexander20 likes this.
  8. Mar 25, 2022 at 5:48 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    Please keep us updated here on the long-term performance at least once or twice a year if you can...
    I just bought the URD TOB / sleeve kit & it will sit on the shelf for possibly months to years until I want or need to do a clutch job on my young (63K miles) 2014 4.0L 4WD 6-MT.
  9. Mar 25, 2022 at 7:02 PM
    Alexander20
    Alexander20 Member
    Still haven't had any noise return. Coming up on a year with the Sleeve kit and TSB update combo
    GilbertOz[QUOTED] likes this.
  10. Mar 25, 2022 at 7:07 PM
    GilbertOz
    GilbertOz Driver
    CA
    About how many miles a year do you drive on average? Do you just daily-drive it or do you also haul/tow and/or go offroad much?
  11. Mar 25, 2022 at 7:36 PM
    sloshy
    sloshy Well-Known Member
    Houston
    2012 DCSB TRD Sport
    NONE
    I ended up doing the whole toyota fix, slave cylinder, new fork, TOB, clutch, and PP. 10k miles later still no noise fingers crossed
  12. Mar 25, 2022 at 7:38 PM
    GilbertOz
    GilbertOz Driver
    CA
    By "TOB", do you mean the URD throw-out-bearing + sleeve kit, yes?
  13. Mar 25, 2022 at 7:40 PM
    sloshy
    Houston
    2012 DCSB TRD Sport
    NONE
    No the original toyota throw out bearing is what I used if it starts acting up I will try the URD
    MetalMaggot666 likes this.
  14. Mar 25, 2022 at 7:44 PM
    GilbertOz
    GilbertOz Driver
    CA
    Phew. I'm glad I asked. Yes, according to a youtube I watched (can't find the link, now) the Toyota original throwout bearing has a design flaw which will cause it to fail / squeak much sooner than it should. Whereas the URD TOB/sleeve kit is re-engineered to eliminate the root cause of the problem & hopefully last ?? 3x or more longer.
    sloshy[QUOTED] likes this.
  15. Mar 25, 2022 at 7:48 PM
    sloshy
    Houston
    2012 DCSB TRD Sport
    NONE
    Man sometimes I regret buying the 6 speed lol. Hopefully this "fix" last for me
    O'DubhGhaill likes this.
  16. Mar 28, 2022 at 9:11 AM
    Alexander20
    Alexander20 Member
    Roughly 12-15,000 km per year. Mostly daily driving, but occasional light-moderate off road/wheeling in the summer and fall
  17. Jul 27, 2023 at 9:12 AM
    88up10
    88up10 Member
    06 Tacoma DLX 4x4 Mt & 98 Tacoma 4x4 Mt
    Are the manual transmissions from 12-15 fixed of this issue?
  18. Sep 18, 2023 at 11:58 PM
    MetalMaggot666
    MetalMaggot666 New Member
    2013 Toyota Tacoma V6 TRD-Sport 6-Speed Manual
    Are you able to update wether the noise cam back or not? Been about year from this post
  19. Sep 18, 2023 at 11:59 PM
    MetalMaggot666
    No, my 2013 does it
    GilbertOz likes this.
  20. Sep 19, 2023 at 1:13 AM
    TacoTuesday1
    FL
    the throwout bearing is problematic. That is not in the transmission. TOBs go onto transmissions.
    they did not fix this. Nor on 16-23.
