The details no one talks about with bilstein 6100’s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 05 4x4, Mar 29, 2023.
  1. Mar 29, 2023 at 5:44 PM
    05 4x4
    05 4x4 [OP] Well-Known Member
    Hello Gents,
    I’ve been researching the bilstein 6100’s and haven’t found the following info. Can anyone help?
    20 trdor with sliders, skid plate, 265 75 16 tires.
    If I got the 6100 fronts with 600lb springs and 5160 rears, I wanted to keep the leveled front and stock stance in the rear.
    What specific ride quality will improve or degrade? For example on the highway on concrete paved sections the truck bounces quite a bit(yes I’ve played with air pressure)
    I am looking for a more smooth ride, definitely not a more rigid ride. Will the 6100’s be more stiff than stock?
    Will the only improvements be seen when wheeling? I do mostly super slow small Rocky sections and also pretty washboarded Rocky type fire roads mostly.
    the info im gathering seems to be that I’ll have a more rigid ride. I am hoping that isn’t the case. Any help would be great. Thanks!
    WilliamJames likes this.
  2. Mar 29, 2023 at 6:39 PM
    jakbakcrak
    jakbakcrak Well-Known Member
    Jack
    2020 Quicksand TRD Off Road Tacoma
    Several aesthetic
    It's top secret....that's why no one is talking about it....
  3. Mar 29, 2023 at 10:08 PM
    PasoSteve
    PasoSteve Well-Known Member
    Denver, CO
    2020 Tacoma TRD Off-Road Silver
    SCS Ray 10's, Clazzio Leather Seats with bun warmers.
    I noticed mine are stiffer but in a good way. At higher speeds the truck has less roll and bounce. At lower speeds something like a speed bump seems to hit harder. I didn't like the Cadillac feel of the off-road so I'm happy with the upgrade
    auskip07, Ricardo13x and 05 4x4[OP] like this.
  4. Mar 29, 2023 at 10:15 PM
    05 4x4
    thanks @PasoSteve those are the details I was looking for. That is what everyone seems to gloss over during their reviews.
    Would love some more input if anyone feels differently.
    I feel like when I take hour long slow very rocky roads/or even longer mixed terrain roads, I’m beat up and tired with the stock suspension. I feel like if speed bumps hit harder with the 6100’a it’s going to be even worse. Thoughts?
  5. Mar 29, 2023 at 10:16 PM
    05 4x4
    @PasoSteve what springs did you use and are you lifted? What leaf’s? Thanks!
  6. Mar 29, 2023 at 10:19 PM
    Bishop84
    Bishop84 Well-Known Member
    B8 6100s are called 6112's on Tacoma, there's loads of threads on them here.
    The 600# spring is the standard spring I believe, and it rides amazing over rough terrain at higher speeds. It's a worthwhile upgrade.
    The higher clip you go the firmer it gets, so staying mid to low will level the truck and give the best ride.
  7. Mar 29, 2023 at 10:22 PM
    PasoSteve
    Denver, CO
    I have the 600# springs that come with them. Set on 9/8 for the clips. Got about 2" of lift. The rear is the 3 leaf aal from @HeadStrong Off-Road . It kept a slight rake which I prefer. If you drive faster off-road it helps smooth it out. Slow speed crawling is a harder hit.
    05 4x4[OP] likes this.
  8. Mar 29, 2023 at 10:37 PM
    Ballz
    Ballz Well-Known Member
    Bfe SF Bay
    2023 Ice Cap Taco TRD Pro
    I think you mean 6112’s. They ride nice and plush vs 5100’s. And they do pair up with 5160’s quite nice! Definitely a good step up from the 5100’s! Can’t go wrong with this upgrade.
    71tattooguy likes this.
  9. Mar 30, 2023 at 5:57 AM
    Bishop84
    You lose down travel and ball joints get worse angles, tie rods point down attributing to bump steer. It’s not like the 5100 but all lifts have compromise
    TacoGranny likes this.
  10. Mar 30, 2023 at 6:17 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    A quick search count says that there are currently 242 threads with "6112" in the title.
    Start with this one.
    https://www.tacomaworld.com/threads/bilstein-6112.421995/
    And then really dive down the rabbit hole and look up performance characteristics of progressive, digressive, and linear valving. Decide which one works for you. And be honest with yourself and how often you really will be running the Baja course vs just sitting in traffic.
    The 6112s are one of the best digressive examples in a budget-to-mid-tier shock. Read the reviews in that thread ^^^
  11. Mar 30, 2023 at 6:22 AM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I think you are asking for the ride that the TRD Off Road comes with. Should be pretty easy to pick up a set of shocks and spring that someone has taken off their tacoma for an "up grade." I have the 6112's on my tacoma and I love the way it rides but I think, from what you are saying, you would appreciate the softer feel of the Off Road set up.
  12. Mar 30, 2023 at 7:19 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    CaptainBart45 likes this.
  13. Mar 30, 2023 at 10:36 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    6112’s / 5160 is a great combo IMO. CANT go wrong. Paired with a nice leaf pack
    AmateurTaco1313 and MadKatt like this.
  14. Mar 30, 2023 at 11:12 AM
    egb1776
    egb1776 Well-Known Member
    2017 Tacoma OR
    If you're looking for smoother not rigid and do mostly slow speed stuff I suggest that you look at progressive or linear valved shocks then. Digressive valved shocks like the 6112s are characteristically stiff in the beginning of their rod travel.
    cosmic65charlie likes this.
  15. Mar 30, 2023 at 11:51 AM
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    Giggity
  16. Mar 30, 2023 at 12:02 PM
    Ballz
    Bfe SF Bay
    Or go with 8112’s up front and 8100 out back but the price jumps a lil, ultra plush on road and off-road is like riding in a Caddy!! Better ride than King oe. I’ll go this set up if I end up not liking the pro fox shocks..
  17. Mar 30, 2023 at 1:02 PM
    egb1776
    2017 Tacoma OR
    very nice shocks, but into the realm of boutique suspension that adds extra maintenance costs to the equation. It all depends on what the OP plans on doing, shocks of that caliber may be way overboard. Since it seems like they are interested in slow speed, light rock crawling and forest service roads they might be better off looking at what our friends down under are running because that's similar to alot of their offroading.
    Chew and MadKatt like this.
  18. Mar 30, 2023 at 8:31 PM
    CaptainBart45
    Bart
    Work in progress...
    Yep, I think he has an 05 4x4 and I was thinking an "Off Road" set up from a 3rd gen would be perfect for what he is asking for. And not spending needless money is what I'm all about.
  19. Mar 31, 2023 at 3:59 AM
    DeuceDeuceBravo
    DeuceDeuceBravo Well-Known Member
    New England
    No extra maintenance with the 8112/8100 unless you're really hammering them. They're not like Fox or King in that regard.
    But these probably wouldn't work for OP's purposes. My experience with the 8112/8100 setup is that they are firm on the road so you feel the "small" stuff, but the truck is way more controlled and they take big/fast hits with ease. Should be great for washboard stuff. Haven't tried them on slow off-roading yet.
    Ballz likes this.
  20. Mar 31, 2023 at 4:20 AM
    Firn
    Firn Well-Known Member
    White OR
    Not to be pedantic but it is not a beginning of travel thing but instead a component of digressive valving. The shock can have more dampening when it is moving slowly (cornering, dips and rises in the road) and less dampening when it is moving faster (expansion joints, potholes). This gives a firm feel, it is responsive, but removes the harshness.
    OP, I upgraded the front from stock OR shocks to 6112s. It is amazing. Completely remove the wallowy, floaty, feel the stock shocks had while also made it more comfortable. These new shocks are firm, but more comfortable. Everything I gained in the front though was lost by a lift block in the rear with stock shocks.
    DeuceDeuceBravo likes this.
