The Correct Way To Drain/Fill the 4.0 Antifreeze
Discussion in '2nd Gen. Tacomas (2005-2015)' started by parfleet, Apr 21, 2010.
  1. Apr 21, 2010 at 10:39 AM
    parfleet
    parfleet [OP] Well-Known Member
    Rex
    Pensacola, FL.
    05 PreRunner, SR5 Package, 4.0 Engin
    Front Bush Guard with 100 Watt Driving Lights, Color Match Tonel Cover. Cold Air Intake By True Flow,added an additional 26 HP.
    I have a 2005 Tacoma PreRunner with the 4.0 Engine. I know that the original antifreeze should last for 100,000 miles according to Toyato. Yea! Right! Get Real! Anyway, I have studied the correct way to drain and refill, chatted with mechanics, relied on "All Data" Auto Repair and guess what? They are all wrong.
    Yes that's right! WRONG!
    Here's the real deal...
    1. You must remove the skid plate
    2. Attached a piece of 3/8" hose to the nipple on the radiator drain cock located on the bottom left of the radiator.
    3. Remove the radiator cap and open the radiator drain cock.
    4. Once the radiator is empty, close the drain cock.
    5. There is one "And Only One" coolant block drain cock on the right side (passenger side) of the engine block. It is to the rear of the engine mount. Attached a 1/4" hose to the nipple and open the drain cock with a 10MM
    socket. Once the block is empty, then close the drain cock.
    6. Add new Toyato Antifreeze to the radiator. Start the engine and allow the coolant to circulate. Sqeeze the upper and lower radiator hoses. Add more coolant as needed.
    7. Once you are satisfied the system is full (it hold 9 quarts), take it for a test drive and at the end of the test drive, check the coolant again and add as necessary.
    P.S. The Toyota Antifreeze is around $25 per gallon and you will need three gallons as the coolant system requires 9 quarts.
    The End!
    Good Luck.....Rex
  2. Apr 21, 2010 at 10:42 AM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    A few questions...
    • What do the others say to do that's wrong?
    • Do you have pictures of the items you note in your walkthrough?
    Alexely999 likes this.
  3. Apr 21, 2010 at 10:47 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    sounds good to me
  4. Apr 21, 2010 at 10:49 AM
    parfleet
    Rex
    Pensacola, FL.
    I was told there was a drain cock on top of the engine on the left valve cover and one below the engine oil filler tube on the left side of the block. Both which are not true.
  5. Apr 21, 2010 at 10:49 AM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    question, whats a toyato?
    (to the OP)
  6. Apr 21, 2010 at 10:59 AM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    Some pics and a walk through would be nice.:)
  7. Apr 21, 2010 at 11:22 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    The OP is actually wrong. For what it's worth, there is a block drain on the driver's side too.
    Pigpen, jgalvar, Nwasbotten and 9 others like this.
  8. Apr 21, 2010 at 1:44 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Switch the last two vowels and take a wild guess...
    gunn_runner likes this.
  9. Apr 21, 2010 at 7:45 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    so you're saying you like to drain cocks.....:eek:
  10. Apr 21, 2010 at 11:26 PM
    buzz wrecker
    buzz wrecker Hair Metal Rules
    Newport News, VA
    07 Silver SR5 TRD Sport 4x4
    MN Twins license plate frame, N-fab nerf steps, Aero Turbine muffler, AFE stage 2 intake
    Actually to get a 50/50 mix for your coolant, you should only need to buy 2 gallons of coolant, since that is 4 1/2 qts water, and 4 1/2 qts coolant (4 qts in a gal). Unless you used full strength coolant for your whole system.
  11. Apr 22, 2010 at 5:57 AM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    The OP is talking about the super long life pink fluid, which comes pre-mixed at 50-50.
    wi_taco, Norton, McDudesYota and 2 others like this.
  12. Apr 22, 2010 at 8:14 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    :goingcrazy:
  13. Apr 22, 2010 at 9:05 AM
    buzz wrecker
    Newport News, VA
    Gotcha, didn't know that the coolant came pre-mixed. I retract my previous statement then....
  14. Apr 28, 2010 at 2:32 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    My dealer is running a special on the super long life coolant this month and in April. Picked up a couple gallons this morning for $19.95 a gallon of the premixed pink stuff. Not sure how good of a deal it is or if other dealers are doing the same. For others in the middle TN area, it was at Beaman Toyota.
  15. Sep 30, 2010 at 2:44 PM
    yrffej
    yrffej Active Member
    '05 prerunner trd sport
    i wanted to bump this thread, to see if the orig poster is still here?
    i've got some questions about the missing drain plug just behind the alternator....
  16. Sep 30, 2010 at 4:47 PM
    Fortech
    CANADA
    Maybe something someone else can help you with?
  17. Sep 30, 2010 at 7:43 PM
    snowmansgarage
    snowmansgarage Well-Known Member
    Portland, OR
    '06 TRD Offroad AC Tacoma
    I just did mine a little over a week ago and I agree for the most part with the OP. There is only 2 drains (radiator and passenger side of engine, but I only needed two gallons of the pre-mixed pink coolant. I change coolant every four years regardless of mileage, it's a time based interval not mileage.
    Loera Ruvalcaba likes this.
  18. Sep 30, 2010 at 8:29 PM
    evile
    evile Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    So glad I have access to a coolant flush machine. Not sure if this will post or not but here is what alldata shows
    1. DRAIN ENGINE COOLANT
    CAUTION: To avoid the danger of being burned, do not remove the radiator cap while the engine and radiator are still hot. Thermal expansion will cause hot engine coolant and steam to blow out from the radiator.
    1. Remove the service hole cover from the engine undercover.
    2. Install a vinyl hose onto the drain on the radiator side.
    3. Fix the vinyl hose with tape.
    4. Loosen the 3 drain plugs on the engine and radiator, and drain the coolant.
    5. Remove the radiator cap.
    6. Drain the coolant from the reservoir tank.
    7. Tighten the 3 drain plugs. Torque: 13 Nm (130 kgf-cm, 9 ft. lbs.) for the engine
    8. Remove the vinyl hose from the radiator.
    2. ADD ENGINE COOLANT
    1. Pour coolant into the radiator until it overflows.
    Capacity
    HINT:
    * Use of improper coolants may damage the engine cooling system.
    * Use only Toyota Super Long Life Coolant or similar high quality ethylene glycol based nonsilicate, non-amine, non-nitrite, and non-borate coolant with long-life hybrid organic acid technology (coolant with long-life hybrid organic acid technology consists of a combination of low phosphates and organic acids).
    * New Toyota vehicles are filled with Toyota Super Long Life Coolant (color is pink, premixed ethylene glycol concentration is approximately 50% and freezing temperature is -35°C (-31°F) ). When replacing the coolant, Toyota Super Long Life Coolant is recommended.
    NOTICE: Do not substitute plain water for engine coolant.
    2. Check the coolant level inside the radiator by squeezing the inlet and outlet radiator hoses several times by hand. If the coolant level goes down, add coolant.
    3. Install the radiator cap securely.
    4. Slowly pour coolant into the radiator reservoir until it reaches the FULL line.
    5. Warm up the engine until the cooling fan operates.
    (1) Set the air conditioning as shown while warming up the engine.
    (2) Maintain the engine speed at 2,000 to 2,500 rpm and warm up the engine until the cooling fan operates.
    6. Squeeze the inlet and outlet radiator hoses several times by hand while warming up the engine.
    7. Stop the engine and wait until the coolant cools down.
    8. Remove the radiator cap and check the coolant level inside the radiator.
    9. If the coolant level is below the full level, perform the steps from (a) through (h) and repeat the operation until the coolant level remains at the full level. Check the coolant level inside the radiator reservoir tank again. If it is below the full level, add coolant.
    3. CHECK FOR ENGINE COOLANT LEAKAGE
    1. Fill the radiator with coolant and attach a radiator cap tester.
    2. Pump it to 118 kPa (1.2 kgf-cm2 17.1 psi), then check for leakage.
    jgalvar, Stryker420, Marc70 and 2 others like this.
  19. Oct 4, 2010 at 4:03 PM
    yrffej
    thanks....
    it seems that i can locate the third drain, being behind the alternator & below the oil refill spout, as pictured.
    this is the pdf file of the toyota svc manual...
    you can see in the picture the three drain plugs.... being a pdf, you can also greatly zoom in on the one that appears to be on top of the block. notice it seems to be mounted sideways? yes pointing the drain off the passenger side. this view is a point of view perspective. you're actually looking down on the block from above, and all the drains are placed in view as if you could see through the block.
    be that as it may, i'm wondering if the rest of you are unable to locate the third drain plug? as i have.
    btw, i just purchased 3 gallons of the toyota 50/50 pink coolant from the deallers, their shelf price was $26- per gallon. i asked if i bought 3 if he'd make a better price. yes 3 gallons at $60- plus tax
    i bought the thermostat $50- approx and will change it all this weekend coming up.
    more later,
    and thanks
    thank
    7A7ER and PzTank like this.
  20. Oct 9, 2010 at 4:00 PM
    yrffej
    just drained and refilled the coolant.... and yes, the third drain plug, is there and functional.... but hard to reach with short arms, i had 3 or 4 extensions together with a wobbler extension. reaching through the wheel wells...
    it's still cooling down so i can recheck the level, and hopefully add coolant.
    so far i've only replaced 2gal/8qts. where the book says 10.4qts w/autotrans. maby the additional coolant in the heater element doesn't easilly drain?
    update.... 9qts total.... added
    more later
    btw, EVILE.... whats up with the diagrams on your post? sometimes when i look at your post the diagrams displayed are wheel patrs, sometimea a troubleshooting tapping noise flow chart, sometimes blank?
    what;s up with that? and what are they supposed to be?
