The Abbreviations reference
Discussion in 'General Tacoma Talk' started by MagicToolbox, May 17, 2024.
  1. May 17, 2024 at 6:31 AM
    MagicToolbox
    MagicToolbox [OP] Well-Known Member
    2022DCSB MT TRD OffRoad in Lunar Rock
    Purchased Toyota Certified, with Vijay bumpers, additional lights, and Falken Wildpeaks on Fuel rims. Prev owner apparently painted the grill.
    I'm new. I got a lot of info from here while I was researching the purchase of my Tacoma, made an account and read a lot. I spent a lot of time trying to figure out the abbreviations that are commonly used, and read a lot of posts from others who have the same problem. I looked around and could not find a reference - so while I was slowly building my 'clout' to the point that I can post in more places, I started compiling abbreviations. It is by no means complete, these are the acronyms and abbreviations that I came across while reading. It is likely not accurate. But with the power of Cunningham's law, it will become accurate.
    If this is helpful, I'll add to it and maintain it. If it isn't, it'll die of neglect and be lost - regardless, thanks for the help.
    MBP ?????????
    3PMS - Three Peak Mud and Snow
    A-TRAC - Active Traction Control
    AC - Access Cab
    ACC - Adaptive Cruise Control
    ADD - Automatic Disconnect Differential
    ADM - Accumulator Delete Mod (Manual Transmission, clutch feel & engagement)
    ADM - Additional Dealer Markup
    ARB - Anthony Ronald Brown (Founder of ARB off road equipment manufacturer Australia)
    AT - All Terrain
    AT - Automatic transmission
    ATF - Automatic transmission Fluid
    AUTO LSD - Automatic Limited Slip Differential
    BCM - Body Control Module
    BFH - Big F'ing Hammer
    BJ - Ball Joint - (Get yer mind outta the gutter)
    BNIB - Brand New In Box
    BSM - Blind Spot Monitor(ing)
    BTM - Body Type Model (Classification system, pickup vs flatbed)
    CAI - Cold Air Intake
    CC - Cruise Control
    CMC - Cab Mount Chop (?)
    CPO - Certified Pre-Owned (Toyota designation on a used vehicle with a warranty)
    DC - Dual Cab
    DD - Daily Driver
    DMV - Department of Motor Vehicles
    DRT Fabrication Fabrication company based in (?)
    DS - Driver Side
    ECGS - East Coast Gear Supply (Louisburg NC)
    ECU - Electronic Control Unit
    FSR - Forest Service Road
    HFT - Harbor Freight Tools (Hazzard Fraught Tools)
    LB - Long Bed
    LBJ - Lower Ball Joint
    LCA - Lower Control Arm(s)
    LDA - Lane Departure Alert
    LPFP - Low Pressure Fuel Pump
    MAF - Mass Air Flow
    MIG - Metal Inert Gas (type of welding)
    MPG - Miles Per Gallon
    MSRP - Manufacturers Suggested Retail Price
    MT - Manual Transmission
    MTS - Multi-Terrain Select (Automatic Transmission only)
    MY - Model Year
    NHTSA - National Highway Traffic & Safety Administrarion
    NIB - New In Box
    NOS - New Old Stock
    NOS - Nitrous Oxide System
    NTK - NTK Fabworks https://ntkfabworks.com/
    OBA - On Board Air
    OC - Oil Change
    OE - Original Equipment
    OEM - Original Equipment Manufacturer
    OME - Old Man Emu (Suspension manufacturer, part of ARB)
    OR - Off Road
    OR - Off Road
    OTT - Overland Tailor Tuning, Overland Torque Tuning (@JustDSM)
    PDR - Paintless Dent Repair
    PM - Private Message
    PS - Passenger Side
    PS - Power Steering
    PSA - Public Service Announcement
    PSI - Pounds (per) Square Inch
    RPM - Revolutions Per Minute
    RTT - Roof Top Tent
    SB - Short Bed
    SC - Super Charger
    SDM - Stabilizer Disconnect Mechanism
    SPG - Smiles Per Gallon (when you know the MPG is low, but love your truck too much to change it)
    TB - Throttle Body
    TC - Torque Convertor
    TC - Transfer Case
    TIG - Tungsten Inert Gas (type of welding)
    TLA - Three Letter Acronym/Abbreviation
    TPS - Throttle Position Sensor
    TRAC - Traction Control
    TRD - Toyota Racing Development
    TSB - Technical Service Bulliten
    TSS - Toyota Safety Sense
    TTT - Tiny Travel Trailer / Trailer Top Tent
    TW - Tacoma World
    UBJ - Upper Ball Joint
    UCA - Upper Control Arm(s)
    UTH - Under The Hood
    VSC - Vehicle Stability Control
    WOT - Wide Open Throttle
    • OE - Original Equipment. This is the stuff that came on the truck when the dealer first sold it - usually. Some dealer installed equipment might not be considered OE, but if it came from the factory, it is OE.
    • OEM - (quoted from Andy01DblCabTacoma ) "Original Equipment Manufacturer. In this case, Toyota. However, Toyota doesn't make every part. Many of the electrical components on the trucks are made by Denso, other parts are made by Asin. You can often buy an Asin part, and it will be the original Toyota casting with the logo removed. Interesting to note that, Toyota has stock in both Denso and Asin. Things on the trucks from the factory, like shocks, tires, and brake pads, could be supplied by 3rd party companies." (from thread)
    IN THEORY, if you buy a Denso oil filter from Toyota, it should be considered an OE part. If you buy the same Denso filter from Napa or AutoZone it is an OEM part. If you buy a *Brand* filter from Napa or AutoZone, it _may_ be OEM Equivalent, depending on the quality of *Brand*.
    I-Give-Up, Finn-2187 and 9pm like this.
  2. May 17, 2024 at 6:36 AM
    MagicToolbox
    Reserved for possible additional information.
  3. May 17, 2024 at 6:43 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    More TLAs (three-letter acronyms):
    BSM - blind spot monitoring
    LDA - lane departure alert
    TPS - throttle position sensor
  4. May 17, 2024 at 7:13 AM
    MagicToolbox
    Added, thanks!
  5. May 20, 2024 at 9:29 AM
    4WDKid
    4WDKid New Member
    I am new here. Thank you for compiling this list. I can see it being super helpful.
    Just bought my first Tacoma a little over a month ago. I love it. Best decision I made.
    At the risk of showing my ignorance, is it true that A-TRAC is MT only?
    I am pretty sure that the Automatic Transmission ORs and PROs could run that option too.
    I have an Auto 2015 OR Taco and the A-TRAC button is there.
  6. May 20, 2024 at 10:41 AM
    MagicToolbox
    THANK YOU for the update. While going over the various versions, I thought that A-TRAC was a manual only feature. a little googling after your brought it to my attention and I find a thread that shows it as across both transmissions. At some point I think I found a thread with a chart that had various different modes available for each transmission, but the thread linked above and the fact that your truck has the A-TRAC is good enough for me to remove that parenthetical comment.
    Additional information:
    Perhaps this is a generational issue. I found the thread I recall looking at - in the Third Gen forum. It appears that for Third Gens, A-Trac is a MT only feature. At the end of the day, I guess it does not really matter for the Acronym/Abbreviation list.
    There are so many TLA's (Three Letter Abbreviations) that I thought it might help to rule some out depending on your equipment.
    4WDKid[QUOTED] likes this.
  7. May 20, 2024 at 11:42 AM
    4WDKid
    4WDKid New Member
    With the ability to do so much with these Tacomas, it is greatly appreciated that folks have taken the time and documented so many things.
    Ah, the 3rd gens MT
    Thanks for that link.
    I have been learning about the combination of VSC and LSD and A-TRAC lately.
    There are some threads about the combinations of traction control and their uses in different situations. Completely read the million-page Owner's Manual that came with my truck, but it's still going to take me a bit more study to figure it all out.
    I fell hard down this rabbit hole recently. It is not an easy read at first, but I have a spiffy new coffee grinder on order. I should understand it by the end of the week. (month?)
    Happy to be here. I appreciate you and everyone out here on TacomaWorld to help us get the most out of our Tacomas. There's so much I'm learning about my truck from these TacomaWorld threads.
    Thanks to you and others who have paved the way.
    :cheers:
  8. Oct 31, 2024 at 6:48 PM
    MagicToolbox
    Thanks, adding now...
    thomasburk[QUOTED] likes this.
  9. Oct 31, 2024 at 7:41 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB
    Welcome, didn't no abbreviations.Reference was a thing.
  10. Oct 31, 2024 at 8:30 PM
    MagicToolbox
    I
    don't know if it is a "thing".
    I had the devil of a time when I first started here figuring out the TLA's, so I started putting them in a file.
    Once i had enough 'clout' to post a new thread I added it in case it could be useful for someone else.
  11. Oct 31, 2024 at 8:39 PM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB
    Nice!
    TLA = Tacoma Language Acronym ?
  12. Oct 31, 2024 at 9:01 PM
    MagicToolbox
    I-Give-Up and thomasburk like this.
