Testing Coolant and Brake Fluid
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Smacky2020, Aug 11, 2024.
  1. Aug 11, 2024 at 7:13 PM
    Smacky2020
    Smacky2020 [OP] Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    I'm at 28k mi and 4.5 years of ownership. It was a COVID buy and she has lived a pretty easy life so far.
    In the past, I have flushed my brake fluid on prior vehicles every 2-3 years just as a good practice. This go-round, decided to pick up test strips that do both coolant mix %/ph and brake fluid copper content. Used BK 8006B from Phoenix Systems.
    Surprisingly, brake fluid came out pristine and coolant was 50/50 and top end of corrosion protection (all expected from the long life pink coolant). Attaching pictures of the three test strip colors.
    Wanted to see who else has used these (maybe in a shop setting) and what's their accuracy? Should I also test for moisture content with one of those pen b-fluid testers? Plan is to retest the brake fluid in 6mo but my guess is it'll still be fine.
  2. Aug 11, 2024 at 7:26 PM
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    Car Care Nut says you need to test the moisture content of the brake fluid, but the test strips he linked to are the ones you used. https://youtu.be/Imafmy3Ycew
    I worry more about the fluid in the caliper. Moisture could seep in past the piston seals. I've seen it come out dark yellow when bleeding the brakes when the rest of the fluid in the system is fine. Not sure if that's due to moisture or if its cooked from heat?
    It's probably best just to change it regularly.
    jmneill likes this.
  3. Aug 11, 2024 at 11:37 PM
    nds0000
    nds0000 Well-Known Member
    Not sure if I would wait to have a measurable corrosion level in my brake lines. Rather test for the moisture in the brake fluid which eventually leads to corrosion. Also, the brake system is not one that has a pump and the fluid gets circulated. It is more or less stagnating in the lines. That means that your test results in the reservoir may be significantly different from that at the brake caliper where the heat is produced and changes the brake fluid moisture content.
    As the manufacturer recommends, I would go back to the good old habit and change the brake fluid every 2 years.
    RustyGreen likes this.
  4. Aug 12, 2024 at 5:13 AM
    Smacky2020
    Bristol, VA
    Just like transmission fluid, the manual doesn't actually have a replace timeframe. All it mentions is "inspect brake fluid level/condition". Agree testing gives you an indication of already existing corrosion and I may pull some fluid from one of the calipers. I was still surprised that 4.5 year-old fluid is not higher in copper content. Brake fluid is still in great shape and I'll continue monitoring during oil changes.
  5. Aug 12, 2024 at 5:35 AM
    nds0000
    This brake fluid discussion has been on TW already. Most (if not all) brake fluid manufacturers recommend changing the brake fluid after 2 years. In this case, it looks like a duck but may not be a duck. Looks of the fluid, feel of the fluid, and testers are vague indicators. The cost of the brake fluid is minimal. Changing it every 2 years gives peace of mind.
  6. Aug 12, 2024 at 5:58 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    X2
    Testing fluid in the reservoir, assuming that's what the OP did, isn't really indicative of what's down where it matters most.
  7. Aug 12, 2024 at 6:12 AM
    Smacky2020
    Bristol, VA
    It was since it's the easiest point of access. I'll pull some from one of the calipers and report back.
    Spacecoast and jmneill[QUOTED] like this.
  8. Aug 18, 2024 at 1:37 PM
    Smacky2020
    Bristol, VA
    Update: tested fluid from the passenger-rear drum and it's between 30-100ppm so fluid still in good shape. I'll retest at next oil change or just end up changing it then. So if your truck is a pavement-pricess and you don't put a ton of miles, chances are your brake fluid is in a pretty good condition even after 4+ years.
    Tacorific, jmneill and brigsby99 like this.
