Test to check for bad IAC valve ???
Discussion in '1st Gen. Tacomas (1995-2004)' started by RGosen, Apr 1, 2013.
  1. Apr 1, 2013 at 10:16 PM
    RGosen
    RGosen [OP] Well-Known Member
    Christ would now agree, don't get yourself nailed to a tree
    Kamloops B,C CANADA
    2000 toyota tacoma 4x4 2.7
    Cold air intake
    So is there a way to test a IAC valve like unplugging it and seeing if the idle changes ? I really dont want to take the whole throttle body off to take the damn thing out if its not the problem. as well as that its a expensive part and damn im getting tired of spending hundreds after hundereds on this thing.Thanks:)
  2. Apr 2, 2013 at 2:40 PM
    RGosen
    Kamloops B,C CANADA
    Cold air intake
    No way to test one hey :mad:
  3. Apr 2, 2013 at 8:48 PM
    joeer77
    joeer77 Active Member
    North Plains OR
    Bilstein 5100s
    Obtain a copy of the factory service manual. There are a couple checks you can do without removing it. You need a ohm meter for one of the checks.
  4. Apr 2, 2013 at 10:06 PM
    RGosen
    Kamloops B,C CANADA
    Cold air intake
    I DL a FSM for my 2000 tacoma but it didnt DL right as I search for it and its not there. andyone have a link for the dl of the factory service manual please ?
  5. Apr 3, 2013 at 5:32 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
  6. Apr 3, 2013 at 7:51 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    pm me your email and I have a FSM
  7. Apr 3, 2013 at 11:01 PM
    RGosen
    Kamloops B,C CANADA
    Cold air intake
    Thanks a lot man
  8. Apr 3, 2013 at 11:02 PM
    RGosen
    Kamloops B,C CANADA
    Cold air intake
    Yea for sure thanks dude ,,pm,d you
  9. Mar 7, 2014 at 6:53 PM
    TJF
    TJF Well-Known Member
    NM
    01 xtra cab 2.7 4x4
    I know this thread is old but I stumbled on it after searching for numerous weeks. I have replaced my iacv and truck still doesn't idle right.
    The main question I have when doing the check how much should I see the valve move? I have a new iacv and old and they both only move a hair and then I can feel humming from the actuator. Shouldnt they do a full stroke open when the ECT sensor is disconnected?
    I find it hard to believe the iacv valve is bad?
  10. Mar 7, 2014 at 7:48 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    For those who missed it there are FSMs for Tacoma's in this forum. Look at the top of the stickies. Download while you can. Sooner or later Toyota's attorneys are going to see this and that will be all she wrote.
  11. Mar 8, 2014 at 7:25 AM
    TJF
    NM
    01 xtra cab 2.7 4x4
    Got the FSM, I know how to check it, but all it says do these steps and check for " normal operation". What is normal operation? should the valve fully open or fully close? my just twitches, the new one and the old one, old one is spotless clean. Do the magnetic actuators ever go out?
