Test Drive Fail: EBC Rotors and Pads
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JsDCTRD, Mar 23, 2019.
  1. Mar 23, 2019 at 5:14 PM
    JsDCTRD
    JsDCTRD [OP] Well-Known Member
    Josh
    Houston, Tx
    2012 DCSB TRD
    Pelfreybroke steel front bumper BHLM T4R Trail Wheels Element LED 20” light bar Bilstein 6112/5160 Icon AAL
    Just installed EBC slotted rotors and Greenstuff pads. Upon completion of install, I went for a quick test drive and all seemed fine until I brought the vehicle to a halt in my driveway. There was a shudder and sickening grunt. Driver’s side rotor looks fine but passenger rotor is pictured below:
    Any idea what could’ve caused this? tearing the truck back down now for diag.
    Any help would be much appreciated.
  2. Mar 23, 2019 at 5:34 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    What did the pads look like when you took them out?
    JsDCTRD[OP] likes this.
  3. Mar 23, 2019 at 5:35 PM
    Motofox
    Motofox Well known hermit
    Stephen
    Northern California
    2014 DCLB
    custom pin-striping and dirt
    Pretty sure thats normal. Black shit comes off once you start using the brakes.
    Edit: you need to bed in the pads/rotors. There are guidelines to break it all in. I'd expect odd brake behavior for the first few hundred miles.
  4. Mar 23, 2019 at 5:37 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    No coating will withstand braking in contact with the friction material (the brake pad).
  5. Mar 23, 2019 at 5:37 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Did you follow the recommended break-in for new pads and rotors?
    lynyrd3 likes this.
  6. Mar 23, 2019 at 5:42 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    New brakes are going to groan and shudder at low speeds ( like coming to a stop) before they get broken in, its really common. Especially the more aggressive pad compounds. Follow the brake in procedure listed in the instructions and it will smooth out
    JsDCTRD[OP] and Too Stroked like this.
  7. Mar 23, 2019 at 6:42 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    love slotted rotors on race cars,but I will stick to factory rotor and pads on my Tacomas.
  8. Mar 23, 2019 at 6:46 PM
    JsDCTRD
    Josh
    Houston, Tx
    2012 DCSB TRD
    Apparently it’s normal...no other issues other than the described groaning at slow speed coming to a halt. Checked everything out and no cause for concern yet.
  9. Mar 23, 2019 at 6:47 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Silly question, but, are the pads in upside down? I'm not sure those little ears are supposed to be facing the hub.
    eherlihy and JsDCTRD[OP] like this.
  10. Mar 23, 2019 at 6:49 PM
    JsDCTRD
    Josh
    Houston, Tx
    2012 DCSB TRD
    Was the only way to line up the holes for the pins on the top side of the caliper. I thought it looked strange too but that’s the same direction that the old pads came out, the old ones just didn’t have the small ears on them. It’s dark now and the truck will sit for the night and I’ll re-visit the issue in the morning.
    Maticuno[QUOTED] likes this.
  11. Mar 23, 2019 at 6:57 PM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    First, hello,
    Next, did you clean and grease the pads? If not, there is part of the noise. You need to grease the backing plates and the guide runners. Next, something looks off. On the front (top of caliper in the pic) it looks like a wire or something is sticking out. Did you install the rattle springs and pin clips correctly?
    EBC pads are bleh, there are better pads, every time I had to put em in bikes the made noise within a couple of miles. The semi-metallic nature of the compound is what does it. They are the cheaper of high performance brake pads.
    I will probably get blasted for saying that, but truth is truth. Brembo pads, akibono, performance friction are way better with almost no noise, you pay dearly for that.
    I’m leaning towards no grease more than anything.
    Honestly it is tough to diagnose brakes without physically seeing and touching them.
    Hope this helps.
    JsDCTRD[QUOTED][OP] likes this.
  12. Mar 24, 2019 at 5:22 AM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    Did you make sure right is right and left is left?Have same setup.Brakes were burning hot and smell horrible after proper break in...Absolutely smooth as butter now...
  13. Mar 24, 2019 at 5:33 AM
    BigE taco
    BigE taco Well-Known Member
    Eric
    Sarasota, FL
    19 TRDOR DCSB
    19 TRD OR DCSB Cement Falken Wildpeak AT3W 275/70/17 TRD Sema Pro TRD Pro Fox Shocks with Wescott lift Icon AAL progressive leaf pack Freedom Off Road UCA ECGS Bushing SSO slimline hybrid bumper in Zeak 12000lb winch Rigidhorse 20" led combo light bar Taco Garage "TRD Pro" Grill RC TuningFL OTT mild/medium tune Rav4 blindspot mirrors Seat Jackers driver seat Tri fold hard bed cover...came with truck Magnus side steps...came with truck, don't like them Tufskinz Inferno various interior items Auxbeam led low beam headlights "TRD PRO" style fog lights "TRD PRO" style skid plate Meso Custom Total Tail Stg 1 OEMAudio speakers Multi Ch amp, Sub amp and Toyota Gain Knob 09 TRD OR DCSB....sold Falken wildpeak at3w 265/75/16 TRD Pro Kit with Headstrong Prog. AAL TRD Seat Covers TRD Drop filter TRD Exhaust Led headlights and fogs Hidden light bar Led interior lights Pioneer Avic-F900BT Kicker speakers swap Kicker Solo 10" Kicker kx400.1 misc..$$$ spend on unnecessary things AVS in channel visors Trifecta tri fold Toyota Bed Extender Toyota Skid plate
    You got to get it up to 95 and check the fluorocarbon output "It's all ball bearings nowadays"
    Beretta4x4 and Jonah like this.
  14. Mar 24, 2019 at 5:46 AM
    vwarwar
    vwarwar Member
    Vitor
    Tacoma 19
    Both sides should be similar. The noise, and sometimes the smell, is normal until you bed your brakes. It take more than 500 miles to proper “bedding” these brakes. The key for disk brakes is installation. Everything must be super clean. Poor alignment (due to dirty/rust) will cause vibration and ruin your set up. I used EBC parts a couple of times and they worked great.
    Good luck
    V.
  15. Mar 24, 2019 at 8:56 AM
    jprovencher8
    jprovencher8 Well-Known Member
    I run the EBC slotted and dimpled rotors with the yellow stuff pads. I though they were one of the best upgrades i did. Make a remarkable difference stopping with a load. Strongly recommend you follow the bedding procedure as best you can per instructions.
  16. Mar 24, 2019 at 5:28 PM
    JsDCTRD
    Josh
    Houston, Tx
    2012 DCSB TRD
    I appreciate all of the feedback guys. I have since tore the truck back down and applied a little more grease than I had originally which seems to have solved the noise issue. I now have approx. 100 miles on them and everything seems to be working perfectly. Really excited to put them to the test on a hard stop after I surpass the 500 mile mark.
    HillJackJDS likes this.
  17. Mar 25, 2019 at 4:28 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Having caused a set of Brembo rotors to develop runout with the TRD semi-metallic Pads (where I followed TRD's hard-slow down break in recommendation), I'd recommend breaking the rotors in slowly by driving normally, avoiding hard braking and not dragging the brakes for the first 500 miles (about a week). (partially caused by sticky pistons(s), also caused partially by my intentional hard brake use).
    I'm now on Stoptech GCX rotors w/ Carquest Ceramic Platinum Premium (of all brands!) and so far so good for the first couple hundred miles.
  18. Mar 25, 2019 at 7:55 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Cant say im confident in your ability to do a break job considering the spring perch on your 6112's is upside down.... :eek::eek::eek: Fix that ASAP so the retaining ring is actually captured!!!
    Norton, Capt. Obvious, yeos and 8 others like this.
  19. Mar 25, 2019 at 8:28 AM
    Chiloquin_Car_Care
    Chiloquin_Car_Care homie dont play that
    Oregona
    2021 voodooblue DCSB 4x4 3.5l v6
    nada....maybe a license plate one day & BA bumpers
    I ran my factory original front brake pads/rotors for 150k miles
    replaced with OEM's at 150k, 225k, & most recently at 300k
    never had an issue with the factory brake setup or felt they needed upgrading
    to each their own, as this is a free country, but I humbly say the stock brakes are fine
    side note - im still running the factory original rear brakes at 306k miles
    they are due for replacement though, trying to make it to 325k before I do the rears dumb, sorry drum brakes
    I wish our truck had rear disc brakes!
  20. Mar 25, 2019 at 9:47 AM
    08RC
    08RC Well-Known Member
    I tried EBC Green on a Jeep once and it took a little while for the odd sound to go away but it did . Something sticks in my mind they had some kind of friction material that would wear away but I remember it couldn't happen soon enough
