Terrible noise when loss of traction light appears
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cacraig4, Sep 1, 2021.
  1. Sep 1, 2021 at 4:09 AM
    cacraig4
    cacraig4 [OP] Member
    Carson
    2016 dcsb 6-Speed
    I have a 2016 trd sport and anytime the traction light come on even if i havnt lost traction there is a terrible noise. It sounds like somthing is grinding on something else and seems to be coming from under my feet or right infront of them. Any ideas what it could be because im just worried something is getting screwed up
  2. Sep 1, 2021 at 4:16 AM
    Juisebocks
    Juisebocks Commander of the Inglorious Badger
    Drew
    2015 SR5 2.7L AT OPAF,DTF&PITA
    "Stock+"
    The ABS pump makes a grinding noise when it kicks on during low traction.
  3. Sep 1, 2021 at 4:16 AM
    BOSS-DS2
    BOSS-DS2 Well-Known Member
    Sam
    Texas
    2016 Tacoma 3.5L A/T DCSB
    Motofab 3” Spacer lift Spidertrax 1.25” wheel spacers Yokohama G003 M/T 285/75/17 (34”) MBRP 3” Turndown PowerStop slotted & drilled rotors Tekonsha P3 brake controller
    From my understanding it’s just the traction control working. Not sure of the mechanical science behind it, but it appears to be “normal” (think it’s the ABS Pump and other things activating). During these times you will also notice a huge loss in power as the computer is limiting the amount of throttle input you have in an attempt to help you regain traction.
    zoo truck likes this.
  4. Sep 1, 2021 at 4:29 AM
    jakbakcrak
    jakbakcrak Well-Known Member
    Jack
    2020 Quicksand TRD Off Road Tacoma
    Several aesthetic
    It happened to me once when sitting on a steep uphill grade. Took foot off brake to hit the gas and I thought the gears were shedding parts....Couldn't figure out what I did wrong...crazy noises and grinding...found out here the truck was doing its job...!
  5. Sep 1, 2021 at 4:37 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    The noise of the pump is normal, the traction control engaging when there's not a loss of traction is not normal. You could have a bad wheel speed sensor or another issue, I'd get it to a good tech.
    Kev250R likes this.
  6. Sep 1, 2021 at 5:01 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Its happened on my truck to when starting off in deep snow, mud, or ice. You'll notice your traction led on the dash blinking like hell when it happens.
  7. Sep 1, 2021 at 5:13 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    That's hill start assist. Not Toyota's most eloquent work because most people who experience it immediately think the truck is broke. Must come up on this forum once a week.
  8. Sep 1, 2021 at 5:41 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
  9. Sep 5, 2021 at 7:35 PM
    cacraig4
    Carson
    2016 dcsb 6-Speed
    I j
    I just put new tires on it after my lift and ever since it says i lose traction when making turns fairly often which i assume isnt normal
  10. Sep 5, 2021 at 7:46 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Is there a VSC calibration that could (should) be done like on the 2nd gens?
