Tensioner Idler Pully Noise?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Takawa, Aug 14, 2018.
  1. Aug 14, 2018 at 12:18 PM
    Takawa
    Takawa [OP] Well-Known Member
    On Sunday I changed the serpentine belt on my 2010 V6 Auto Prerunner (113k). The install went fine and everything works as expected. Yesterday, I crank my truck with the A/C running, and when I put it into Rev or Drive I get this knocking from underneath.
    If I turn the A/C off with the truck in Rev or Drive, the noise stops. However, If the truck is in park with the A/C on there is no noise either. I'm guessing the extra load of the AC and the truck in drive is causing the tensioner bearing to make this noise?
    Thoughts?
  2. Aug 14, 2018 at 5:47 PM
    Takawa
    Any thoughts on this one? I’ve read changing the tensioner assembly is a major pain.
  3. Aug 14, 2018 at 5:53 PM
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    Are you sure it's the tensioner pulley? Do you have an automotive stethoscope that you can use to listen to each pulley?
  4. Aug 14, 2018 at 6:06 PM
    Takawa
    I do have a stethoscope. I’ll pull the skid plates and have a listen to each pulley. Odd that prior to the belt change there was no noise.
  5. Aug 15, 2018 at 12:36 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I can't tell the noise from the clip. Remove the belt from the tensioner and check each pulley for play by moving it sideways then spin it and feel for grinding.
    Before that, try old trick below. I have a stethoscope also, but the sound to my sensitive ears is deafening. Most tensioner issues just need the bearing replaced, not the whole assembly. My thread on replacing the pulley bearings might be helpful.
    https://www.tacomaworld.com/threads...arings-in-the-idler-tensioner-pulleys.480961/
    https://www.youtube.com/watch?v=fHtLH_m9gN4
    FishingInSand likes this.
  6. Aug 15, 2018 at 1:02 AM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Check to make sure the belt is in the grooves on crank and centered on all pullys. If all is good, turn AC off, start the truck. Get a flashlight, look at the front of the AC compressor. Is it turning?
    That noise honestly sounds nothing like a bad pully.
    What was the issue to make you change the belt?
    When the truck is completely cold, maybe try removing the belt. Start the truck, listen for maybe 3 seconds in park, put your foot in the brake, put it in reverse for 3 seconds, the drive for 3 seconds. Turn the truck off. Any noise?
  7. Aug 16, 2018 at 5:06 PM
    Takawa
    I checked the belt today and it was riding perfectly in all groves. I took a stethoscope and listened to all four pulleys. The #1 bottom idler pulley had a slight bit of noise, the #2 idlers were nearly silent, but the tensioner pulley was extremely noisy.
    I’d like to replace the tensioner pulley with OE parts, but looks like you have to buy the whole assembly. I may buy the assembly and just swap the pulley.
    Chuy, thanks for the links. Nice write up.
