Temp gauge showing 3/4 hot ..My FIX
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoGo, Sep 23, 2022.
  1. Sep 23, 2022 at 1:48 PM
    TacoGo
    TacoGo [OP] Member
    Madison, Mississippi
    2000 green tacoma sr5 with grey bottom . 4 WD Manual 5 speed W59 Transmission, 2.7 liter 4 Cylinder
    my 2000 tacoma 2,7 liter had temp gauge reading 3/4 to hot rather than center as should be.
    replaced temp sending unit and connecting pig tail wiring. No Help.
    I told my friend that when I would stop and raise hood for short time, gauge would go to normal
    but when running, it would go back up to 3/4 hot.
    He told me it sounded like radiator not getting proper air flow. the radiator fan clutch was replaced last year.
    His advice to home get some Coil Cleaner for A/C condensar cleaning, wet the ac condensar and radiator then SPRAY THEM WELL WITH CLEANER...let foam up for 5-10 minutes then rinse WELL with shower setting and fan setting on water hose..
    RESULT...
    PROBLEM SOLVED.. hope this will help someone else Run Cool...
  2. Sep 23, 2022 at 1:49 PM
    5efvz
    5efvz Well-Known Member
    Condensor was blocking airflow to rad?
  3. Sep 24, 2022 at 6:51 AM
    TacoGo
    TacoGo [OP] Member
    No, bugs in both condensor and radiator were stopping flow of air thru radiator..
  4. Sep 24, 2022 at 7:15 AM
    5efvz
    ah. need to clean mine too. it's pretty much a bug cemetery
  5. Sep 24, 2022 at 5:31 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Mine was low on fluid. The switch on the4 firewall broke a hose connector. Just dry rotted away
  6. Sep 26, 2022 at 11:37 AM
    Pauhana
    Pauhana Well-Known Member
    Mark
    Irvine, CA
    04 SC PreRunner
    RECARO Trend Seats TRD SC URD Fuel Upgrades
    I'm having issues with my temp gauge. It will go all the way to the redline and then drop under it. At times around 3/4 then rise up to red, lower down 7 so forth.
  7. Sep 26, 2022 at 1:49 PM
    Skulking
    Skulking Well-Known Member
    San Jose, CA
    1998 Xtra Cab v6 4x4 Manual
    The first thing to do is figure out if it is your gauge or you are actually overheating. Throw and OBDII scanner on there and monitor your coolant temp. If the OBDII scanner is following the gauge, then your gauge is working and you are overheating which needs to be dealt with. It's also possible at that point that it is the coolant temp sensor rather than actually overheating, but you want to be careful so you don't further damage your engine.
    Pauhana[QUOTED] likes this.
  8. Sep 26, 2022 at 1:54 PM
    Pauhana
    Mark
    Irvine, CA
    04 SC PreRunner
    Yes. Couldn't happen at a better time but is it ever. Thanks for the advice. Def. need to do this to start.
  9. Sep 26, 2022 at 3:29 PM
    Potomus Pete
    Hippy
    Never let your engine get that hot. That's one thing that will kill the mighty Tacoma
  10. Sep 26, 2022 at 4:01 PM
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    Cattle farmer here has same issue with fescue seed clogging a ford truck radiator.
  11. Sep 26, 2022 at 4:58 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Thats why the grill goes up with the hood is to blast the radiators out. Really shows there target audiance having moved away from that. Also know some people that run fine mesh over there radiators for easy cleanout.
