Temp gauge goes into red but everything seems normal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ICECOACH, Nov 24, 2019.
  1. Nov 24, 2019 at 6:49 AM
    ICECOACH
    ICECOACH [OP] Member
    2012 gun metal Tacoma
    I get in the truck this morning, 1st time it ran since 7pm yesterday, i go about 1 mile, make a stop, get back in truck, and notice i have no heat, blowing cold air, but temp gauge is at running temp, put selector to defrost and the air circ light comes on. Go's off if i direct heat to other spots, i go another 2 miles and all of a sudden temp gauge shoots up into the red, but truck sounds, and feels fine, no steam from under hood, but still no heat. Go in store for 5 mins, come out, open hood and feel radiator lines, they're hot, bit normal hot, start truck and temp gauge goes up to running temp, and holds there, Leave and in about 1/2 mile, temps gauge goes back into the red, again, truck feels and sounds fine, no steam, i have about 3-4 mile drive to home, and about 1/4 mile from home, temp gauge goes right back down to running temp, then 2 dash lights come on, the check engine light, and some trac off light. Actual temp seems fine, no boiling. Anyone ever seen this or have any idea what i should be looking at??????????
    I have a 2012 Tacoma, 4 cyclinder, 4WD
  2. Nov 24, 2019 at 6:51 AM
    Dan 77
    Dan 77 I leave my bikes outside
    Dan
    San Antonio
    06 DCSB TRD Sport 4X4
    Kings and TC UCAS 01 DCSB 4X4 Totaled All-Pro bumper, mile marker winch
    Any coolant smell?
  3. Nov 24, 2019 at 6:52 AM
    IL Capo
    IL Capo Well-Known Member
    Sidney BC Canada
    Stuck engine thermostat?
    SR-71A and lynyrd3 like this.
  4. Nov 24, 2019 at 6:53 AM
    ICECOACH
    No, no coolant smell.
  5. Nov 24, 2019 at 6:55 AM
    ICECOACH
    My thought also, but the check engine light and trac off light baffles me. And also the air circ light for the AC coming on when i put it to defrost.
  6. Nov 24, 2019 at 6:56 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Did you check the level? Sounds to me you are really low on coolant.
  7. Nov 24, 2019 at 6:56 AM
    Dan 77
    Dan
    San Antonio
    Maybe the heater core is going bad.
  8. Nov 24, 2019 at 6:58 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    thermostat or temperature sending sensor
  9. Nov 24, 2019 at 7:29 AM
    ICECOACH
    Just checked was definitely low. If my heads or gasket was bad, wouldnt the coolant be in the engine oil? Checked the oil and it is totally clean, im thinking a coolant leak in a hose or something
  10. Nov 24, 2019 at 7:43 AM
    Delta09
    Delta09 OSHA Violator
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Traction lights come on when the check engine light is on regardless of the code. Stop by any Autozone or the like to get the code, should narrow it down. If i was a betting man I would guess it would be a temperature code.
  11. Nov 24, 2019 at 7:46 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Lower radiator tank leak?
    Do NOT assume the sender/gauge are wrong. Assume they're correct and don't drive the truck until it's fixed. This could turn really expensive if not taken *very* seriously.
  12. Nov 24, 2019 at 7:46 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    This doesn’t exactly help your current situation but it’s why I have an ultra gauge. It will tell you your exact temp in real numbers rather than relying on the little gauge on the dash. Just helps you be more aware of what’s going on with your truck by monitoring different things in real time.
    good luck with it, and I hope you didn’t warp a head by letting it get too hot.
  13. Nov 24, 2019 at 8:03 AM
    1moonshine2
    1moonshine2 Well-Known Member
    Appalachian Mountains in VA
    Tacoma 4x4, 4cyl, 5spd, reg cab
    YES! Definitely! Never second guess warning lights without a thorough checkout.
  14. Nov 24, 2019 at 8:08 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    If the thermostat was somehow stuck shut or if you were super low on coolant, I don't think you would get any heat. Even if the engine was super hot
  15. Nov 24, 2019 at 8:12 AM
    TuTacos2Go
    TuTacos2Go 2nd / 3rd Gen Hybrid
    Cincinnati, OH
    2011 RC Barcelona Red MT, 2019 DC Cement MT
    I'd bet it's a head gasket or other failure internally and you are burning/blowing the coolant out the pipe.
    That's why the oil isn't contaminated
    Or, its weeping out the water pump seal, or other leak and you havent noticed it
    I'd take a light and start looking around the engine and radiator and hose bottoms and see if you see a line of wet or dried coolant.
  16. Nov 24, 2019 at 8:16 AM
    LAMCKMA007
    LAMCKMA007 Well-Known Member
    San Diego county
    2006 DCLB 2WD
    No, not always.
    I had the heads rebuilt and ended up with the exact same problem it had before because it had a cracked block. $1,800 down the drain.
    You're going to need the code read.
  17. Nov 24, 2019 at 8:18 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Doesn't the UG rely on the same sending unit the temperature gauge uses? So if the gauge is getting corrupted data the UG would also?
    I don't have a UG so I'm not sure how they get data.
  18. Nov 24, 2019 at 8:35 AM
    ICECOACH
    I added coolant and did a few starts and the chk engine light and trac light went out, let it run a while untill temp gauge showed running temp, but still no heat, also, hose from t-stat is still cool, thinking t-stat is shot.
    LAMCKMA007 and Sterling_vH111 like this.
  19. Nov 24, 2019 at 8:48 AM
    IL Capo
    Sidney BC Canada
    Good Work! I think you're on the right track - keep us posted.
  20. Nov 24, 2019 at 9:46 AM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    What age / mileage was the coolant at in the truck prior to you adding?
