Tell Tale Signs Of a Bad Timing Belt?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomakid96, Jul 19, 2010.
  1. Jul 19, 2010 at 8:32 PM
    tacomakid96
    tacomakid96 [OP] Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    I was wondering what some signs are of a bad timing belt, I know they should be replaced something like every 90,000 miles. My truck has a weird squeek when im accelerating out of 1900 rpm to 2300 rpm, Also When do I know the water pump needs to be replaced? Asking these questions because I have money from this summer and would like to spend some of it maintaining my Tacoma.
  2. Jul 19, 2010 at 8:36 PM
    Firefighter160
    Firefighter160 Well-Known Member
    Josh
    Eastern VA
    05 DCSB Offroad
    The squeek is probably not the timing belt. When the water pump starts failing water will drip out of a weep hole on the bottom of the pump. The timing belt is recommended to be changed every 90k but how long it lasts will vary. A friend of mine just changed his for the first time on his 96 Taco at 215k miles! He said the belt still fit and looked fine. Luckily these are non-interference engines and if the belt breaks they dont mess the engine up.
  3. Jul 19, 2010 at 8:37 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    How many miles are on the current one? You probably have a bad idler pulley which requires removing the belt to replace. Might as well do everything (t belt, water pump, t stat, pulleys)
  4. Jul 19, 2010 at 8:41 PM
    tacomakid96
    Phil
    Out n' about
    I dont know how many miles are currently on it I tried contacting the previous owner and his phone wasn't on. The truck itself has 174,000 miles on it now
  5. Jul 19, 2010 at 8:42 PM
    Firefighter160
    Josh
    Eastern VA
    05 DCSB Offroad
    Check under the hood and on the timing cover for a sticker that says it has been changed....
  6. Jul 19, 2010 at 8:43 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Just do it soon. I did mine for the first time at 156,000 miles and it was baaaad. The water pump had been leaking so bad it had crusted over the entire crank pulley with dried coolant.
  7. Jul 19, 2010 at 8:51 PM
    tacomakid96
    Phil
    Out n' about
    So should I just have changed the belts water pump and timing belt and tstat? How much would that run me?
  8. Jul 19, 2010 at 8:53 PM
    tacomakid96
    Phil
    Out n' about
    I looked and couldn't find a sticker.:mad:
  9. Jul 19, 2010 at 9:00 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    well I just did the water pump, t stat, and the belt because the pulleys were still in good shape. It was a real PITA though and ended up at $163.93 for everything at NAPA. Expect a bit more since you have a bad pulley.
  10. Jul 19, 2010 at 9:04 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    when i changed mine...it took me and tacomaman06 like 4 or 5 hours maybe? but we were bullshittin around too...we changed my timing belt, water pump, and tstat...nothing else but all my pulleys and such were still good
    if i were you i'd change it all out in 1 go...might as well...all 3 are in the same basic location and require the same teardown to get to...
    if youre paying someone you might as well only pay labor once right?
    my parts were around $200 or so (cant remember exact price)...no labor for me
    expect $600-$800 from a dealership
  11. Jul 19, 2010 at 9:11 PM
    Drewboto
    Drewboto Well-Known Member
    Drew
    Missouri
    Base model ಠ_à²
    (Former Tacoma owner) 17" Mustang wheels, Eclipse AVN 5435, Deck plate mod, vertical Maglite mount, K&N high-flow air filter, Delta gullwing box, amp, sub, 30 percent tint, floor lighting, tilt activated glove box lighting, lighting behind seat, engine bay lighting, SR5 grill surround, power windows, outside temp display
    Check your coolant daily for about a couple weeks. It's a pain in the butt, but sometimes coolant leaks gradually where there isn't a puddle on your driveway.
  12. Jul 19, 2010 at 9:11 PM
    tacomakid96
    Phil
    Out n' about
    Damn ya I would have to have the stealership do it because I dont have anyone who can help me. Thanks for all the input so far guys:)
  13. Jul 20, 2010 at 5:15 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    just pop the cover and take a look. ...mine still looks brand new at 100k miles ...and surprisingly enough, the water pump isn't leaking.
  14. Jul 20, 2010 at 5:26 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    If you buy the water pump from Toyota that will be $200, Timing belt $45, thermostat $15. You should also replace the top & bottom radiator hoses and the three fan belts. You won't know if the timing belt idlers are bad until you remove the timing belt and check them out. My 4Runner's timing belt idlers were bad at 183,000 miles.
  15. Jul 20, 2010 at 6:34 AM
    tacomakid96
    Phil
    Out n' about
    How can I tell if the idlers are bad?
  16. Jul 20, 2010 at 6:52 AM
    hillbillynwv
    Fairmont, WV
    After the belt is off, spin them with your hand and see if they rotate easily and don't flop around or make any time of grinding noise from the bearings going bad. But, if you have 174K on them I would replace them even if they do seem to be alright. They usually don't replace them at 90K because they are still good. On eBay they sell complete kits for the timing belt job. The kit includes the water pump, timing belt, idlers, and gaskets. You can save a ton of cash by buying one of these kits instead of buying your parts from Toyota like I did. Just buy a good kit that has a quality name brand pump in the kit. Then buy your hoses and belts and thermostat from your local Napa dealer.
  17. Jul 20, 2010 at 8:30 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Toyota coolant leaves a pink crust behind when it dries. Look for that by the weep hole on the pump.
    On the squeak, if you can make it happen a in the driveway, put water on the belt, if it goes away, it's the belt. Don't drench it, just spray.
    Spray WD-40 on idler and tensioner. If it goes away, you found the culprit.
  18. Jul 20, 2010 at 6:43 PM
    tacomakid96
    Phil
    Out n' about
    Cool thanks for all the help guys! I think im going to have my uncle help me do it.
