Tapping reverse light power for backup camera
Discussion in '1st Gen. Tacomas (1995-2004)' started by bliggity, Aug 21, 2021.
  1. Aug 21, 2021 at 12:25 PM
    bliggity
    bliggity [OP] Active Member
    2022 Lunar Rock Tacoma TRD Off Road
    I’m in the middle of a backup camera install on a 2003 double cab Tacoma. Anybody know what wire I should tap in for power? Looks like my options are green with a blue stripe or white with a black stripe.
    Kevins60 likes this.
  2. Aug 21, 2021 at 6:27 PM
    Bolt Head
    Bolt Head Well-Known Member
    Colorado
    Silver 2001 SC DC LTD
    Fox 2.5 w/resi and adjusters, LR UCAs, Wheeler's minus 2 leaf pack, Toytec rear shocks, FN 5 Star w 33" Toyo OC AT3, Pinch-weld mod, Supercharger, Heated/Cooled Leather Seats, Pioneer DVD w/backup cam, Alpine PDX amp, Remote Start, Spray-on bed liner
    Did you figure it out? I believe it should get connected to your reverse lights so when you shift to reverse the the power turns the camera on. Should be able to trace which ones go to the reverse bulb, yeah?
  3. Aug 21, 2021 at 7:37 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    According to the diagram it's Black/Red going to the switch and Red/Black coming out.
  4. Aug 21, 2021 at 7:41 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    White with black is Toyota for ground. If you have a multi meter you can easily confirm this with the Ohm setting.
  5. Aug 21, 2021 at 8:39 PM
    bliggity
    Got through it. Green with blue was positive. White with black was ground.
    I’m not sure where to mount this the camera though. For now it’s on the license plate, but I’d like move it below my trailer hitch some how.
  6. Aug 22, 2021 at 4:12 AM
    jaclark91
    jaclark91 Active Member
    2000 tacoma v6 4x4
    Can you see your trailer hitch in the camera with it mounted on the license plate? I got one coming in too, hoping to use it to line the ball up more easily.
  7. Aug 22, 2021 at 5:40 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Top of license plate works well for aligning hitch and ball. You have to angle it down just a bit. It is still good for general backing too. My only complaint with the inexpensive cameras is that the wires for ground and power from reverse light is so microscopically thin!! Would love to find one with heavier wires.
