Tapping My Cargo Lighting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by krumdoggg, Sep 22, 2019.
  1. Sep 22, 2019 at 7:33 AM
    krumdoggg
    krumdoggg [OP] Member
    Dave
    Colorado
    2017 White Taco DC TRD OR
    I got a topper for my bed, and built a little platform in it, but I want to give more light to the inside. Im thinking of getting some LED strips and velcroing them to the ceiling, and if possible I want to tap the cargo light (that no longer has any use) so I can turn the lights on and off from the cab. Im new to wiring and tapping and have no idea where to start. Im hoping not to cut my light out and then need to run around in my wife's car while i try and get the pieces i need to fix it. Any words of advice on how to tap the cargo wire and if i need a wattage converter to run from stock lights to LED strips?
  2. Sep 22, 2019 at 10:10 AM
    DESportTRD
    DESportTRD Well-Known Member
    2017 Blazing Blue Pearl DCSB Sport 4x4, MT
    Maybe consider using several of theses. I have one strip on each side of my bed under my tonneau cover. At night, when I drop the tailgate, the led lights come on. Have had them for two years...and they work great.
    Available from Amazon, e trailer websites and others.
    Truxedo 1704998 Truck Luggage B-Light Battery Powered 18" Tonneau Lighting System All Vehicles - Truck Luggage - Battery Powered truck bed lighting system 18"
  3. Sep 22, 2019 at 10:17 AM
    nvnv
    nvnv Stop geotagging
    Connor
    2016 Tacoma TRD OFF ROAD
    Find the fuse for the cargo light and then use an add a fuse to tap into the circuit.
  4. Sep 22, 2019 at 10:35 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    You are risking a water leak if you open up your cargo light lens
    Unless you want fancy dancy swag LED mood lighting to match a shag carpet kit, just use basic battery powered LED lights- they are cheap and easy to install, last a long time too. Just put a large velcro patch on them and stick to ceiling.
  5. Sep 22, 2019 at 10:58 AM
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
  6. Sep 22, 2019 at 9:37 PM
    caribe makaira
    Caribbean, Puerto Rico
    Very incorrect advice...
    Dopplerplus and beergeek like this.
  7. Sep 22, 2019 at 9:38 PM
    caribe makaira
    https://www.tacomaworld.com/threads/3rd-gen-added-lamps-to-cargo-sw.587660/
  8. Sep 23, 2019 at 3:26 AM
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    Meso forumn on 3rd brake light shows the wiring behind the cargo light
  9. Sep 23, 2019 at 7:24 AM
    narkicu187
    narkicu187 Instagram @foe_pro
    Andrew
    New Mexico
    2016 White AT OR DCSB
    Just wired some bedlights into the factory Cargo-light switch this weekend. This thread/post helped me out immensely.....Worked perfectly for me.
    Bed Light Wiring Advice? (SOLVED)
  10. Sep 23, 2019 at 7:53 AM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
    You should not tap the wire at the light itself. The light is installed from the inside and removing it requires dropping the headliner.
    Tap the wires behind the driver’s side kick panel as shown here:
  11. Sep 23, 2019 at 5:38 PM
    nvnv
    Connor
    How is it incorrect? The LEDs he’s installing are going to be extremely low draw but if you’re worried about it then use the add a fuse as a trigger and run a relay. It’s the best way to do it without modifying the factory wiring.
  12. Sep 23, 2019 at 5:40 PM
    caribe makaira
    Because the fuse is always "HOT" and before the rest of the Cargo Lamp circuit...
