Tapping into parking lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trick Deck, Feb 14, 2022.
  1. Feb 14, 2022 at 11:39 AM
    Trick Deck
    Trick Deck [OP] New Member
    2022 TRD Sport
    So I got the new SS3 foglights by Diode Dynamic that come with a backlight that can connect to either my DRL or my parking lights via a T-Tap, I can't find any pictures online of which wire I need to tap into, and the instructions that came with it are basically non-existent.
    I know T-Taps are generally frowned upon but can anybody help me figure out which wires they would go to if I want to connect to my parking lights? I'm new to modding and don't feel comfortable soldering and don't want to add a fuse.
  2. Feb 14, 2022 at 12:13 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I bought a running light custom made taps that just plugs into the existing plugs here on tw.
    tcjacado and Key-Rei like this.
  3. Feb 14, 2022 at 1:50 PM
    Trick Deck
    2022 TRD Sport
    Bump. Anyone know which wire I'm meant to splice into?
    BrokeKayaker likes this.
  4. Feb 14, 2022 at 2:27 PM
    DeuceDeuceBravo
    DeuceDeuceBravo Well-Known Member
    New England
    2wheelnut and Bob1971 like this.
  5. Feb 14, 2022 at 3:36 PM
    caribe makaira
    Caribbean, Puerto Rico
    Do you have Halogen headlights?
    OffroadToy and tcjacado like this.
  6. Mar 10, 2022 at 2:16 PM
    BrokeKayaker
    BrokeKayaker Slava Ukrania!
    Ouachita Mountains
    2022 TRD OR DCLB Army Green
    Bump, I'm about to order some backlit SS3s and I'd love to know what the best way is to tap into the DRLs or maybe the parking lights. I'm not very handy with electrical wiring so if there's some harness I can buy I probably would go that route.
  7. Mar 10, 2022 at 2:18 PM
    pilfer
    pilfer Active Member
    I ordered back kit ones myself, mistakenly Lol. I just didn’t hook them up to be honest. Capped the wire and the lights still work. Interested to hear what you guys do.
  8. Mar 10, 2022 at 3:55 PM
    316sherm
    316sherm Well-Known Member
    South Louisiana
    2020 Tacoma SR TSS Package 4 Cyl
    So these just tap into the parking/drl lights without running a switch inside? I'm wanting to add fogs to my rig (which did not come with any) as easily as possible.
  9. Mar 10, 2022 at 4:28 PM
    Wicked_Taco
    Wicked_Taco Well-Known Member
    Wick
    PA
    ‘21 SR Utility 4x4
    Interested in this as well
  10. Mar 10, 2022 at 4:37 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Do you remember who or the vendor?
  11. Mar 10, 2022 at 6:30 PM
    Tacomike18
    J
    @Puppypunter
    tcjacado and Puppypunter like this.
  12. Mar 10, 2022 at 7:49 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Thanks @Tacomike18 I can make tees for both the SR and TRDs with halogen headlights, as well as the Full LED headlights. PM me if you need anything as that is the best way to get me. And if you are going the tap route, those Posi-Taps mentioned by @DeuceDeuceBravo are the way to go. If you have an SR, @caribe makaira diagram there is what you need to tap (pink on drivers side, blue on passengers side), if you have a TRD with halogen headlights, they are the same color for the parking lights, but it is a different plug. The plug will have a green as well as a white/black wire. If you want to tap the DRL, it will be that green one. And lastly, if you have OEM LEDs, the colors are still the same (pink/blue for parking, green for DRL). If you have LEDs though, be advised that the passengers side plug will have two blue wires. Make sure you tap the one that is in the same physical location as the pink on the drivers side.
  13. Mar 10, 2022 at 7:55 PM
    BrokeKayaker
    Ouachita Mountains
    Forgive my ignorance, but what is a Tee? Would that still require me to cut and tap into my DRL wires?
  14. Mar 10, 2022 at 8:00 PM
    Puppypunter
    Johnny
    2019 Black SR
    When I refer to a tee, it is just a male and female connector with a short (3-4") piece of wire in between them, and a longer (really any length you want) wire coming off of it. So you would just unplug the exist plug from the head light, plug it into the tee, and plug the tee into the headlight where that plug came from. Let me see if I have a good picture.
    Here is an example for a taillight. Same concept, just different connectors :)
  15. Mar 10, 2022 at 8:14 PM
    BrokeKayaker
    Ouachita Mountains
    cool, so for a DRL tee, the loose wire is tied to the DRL wire in the tee and then connects to the backlight power wire coming from the SS3 harness, right?
  16. Mar 10, 2022 at 8:34 PM
    Puppypunter
    Johnny
    2019 Black SR
    Yeah, that would be the idea. If you give me a length, I can ever terminate the end going to the SS3 in a Deutsch terminal if you don’t want any splices at all. You’d have to depin the existing connector for the SS3, but that isn’t hard to do
    tcjacado likes this.
  17. Mar 10, 2022 at 8:58 PM
    BrokeKayaker
    Ouachita Mountains
    I’m not very experienced with splicing wires so that is probably a good idea for me. I’m not sure yet of the length. I take delivery of my Tacoma next week. I think 5 feet would be a conservative estimate.
  18. Mar 15, 2022 at 12:10 PM
    therealodb
    therealodb Member
    Eddie
    2018 Tacoma SR
    Just got these. It was easy to tap into the headlight. You just clip the t tap into the blue and pink wire which is the middle wire on both.
    R0dzilla75 likes this.
  19. Mar 15, 2022 at 12:14 PM
    BrokeKayaker
    Ouachita Mountains
    Looks good!
    I'm still waiting on R4T for my SS3s :popcorn:
  20. Mar 15, 2022 at 12:14 PM
    2wheelnut
    2wheelnut Well-Known Member
    Angelo
    Vallejo, CA
    '11 S/C K.I.S.S. "Factory Enhanced" DC TRD OR
    TRD Supercharger, TRD First Gen CAI, TRD FJ Alloy, Toyo OC A/T II 265/75/16, 5100's Front and Rear, OME 885x with 1/4 taco lean spacer, Toytec AAL 1.5" non TSB. TSB not done. WheatherTech Side Window Deflector, Satoshi Grill, T Rex Eyelids, Matt123 Skid Black stamped, Modded Maglite with Maglite mod for driver seat, Bed extender. Full debadging
    RSOTACO and DeuceDeuceBravo like this.
