Taking Wilson 1000 off magnet mount
Discussion in 'Audio & Video' started by YDCtaco, Mar 26, 2017.
  1. Mar 26, 2017 at 9:47 AM
    YDCtaco
    YDCtaco [OP] Well-Known Member
    Alexandria, VA
    2016 DCSB TRD OR 4x4-Auto
    Hey guys,
    I don't know if this is in this is in the right forum, but I am thinking about attaching my old cb setup(from my ridgeline) onto my tacoma. It is a midland handheld with a wilson 1000 w/ magnet mount. I don't want to use the magnet mount cause it ruined the paint on my roof, so I am looking at tail light or hood mounts. However, can I simply take my 1000 out of the magnet coax mount and reattach it onto a different mount with a new coax cable or is part of the "coil" in the magnet mount itself? Thanks
  2. Mar 26, 2017 at 6:55 PM
    YDCtaco
    Alexandria, VA
    bump?
  3. Mar 26, 2017 at 7:00 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I don't actually know the answer, but am subbing to hear the answer.
    I do know there are some 'cats on the 1st gen threads that really know their way around CB radios.
    YDCtaco[OP] likes this.
  4. Mar 29, 2017 at 3:01 PM
    YDCtaco
    Alexandria, VA
  5. Mar 29, 2017 at 8:18 PM
    YDCtaco
    Alexandria, VA
    Bump Bump! There have got to be some cb guys on here!
  6. Mar 30, 2017 at 6:14 AM
    YDCtaco
    Alexandria, VA
  7. Mar 30, 2017 at 6:18 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    You'll have to get a different antenna. Magnet mount antennas are no ground plane antennas and ground through the mount and coax.
    Firestiks are pretty inexpensive
  8. Mar 30, 2017 at 6:27 AM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Honestly for your purposes you will want to get a new antenna. NMO is the way to go for our trucks and gives a very good signal as the cab creates an excellent ground plane. If you don't want
    To drill though, then mount a firestick to your bed liner rail and run a 12 other 10 Guage wire from the antenna mount to the frame as our beds don't make a proper ground. This will set us up well.
  9. Mar 30, 2017 at 6:51 AM
    YDCtaco
    Alexandria, VA
    Thanks, I think I will get a 4' firestik and mount it to the tail light
  10. Mar 30, 2017 at 6:56 AM
    YDCtaco
    Alexandria, VA
    Well I have used the magnet mount before, but it traps dirt underneath the base and basically sands off clear coat. Dont want to use it on a new black truck haha
  11. Nov 4, 2018 at 5:38 PM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    Sorry to resurrect this :anonymous:
    I’m liking into this as well. Couldn’t you just put clear vinyl on the roof and attach magnet to that?
  12. Nov 4, 2018 at 6:27 PM
    kidthatsirish
    That is certainly possible, but understand that the magnetic mounts use capacitance grounding...you just put a layer of plastic between those pieces of metal. Also the dirt and crap will just get trapped between the vynil and the truck instead.
    I used to do the magnetic thing...then I finally just said screw it I want to be serious about high quality signal...so I went with a NMO mount for my antenna.....works like a champ....and if you ever did sell the truck, they make black flush rubber plugs that are water tight and look nice.
  13. Nov 8, 2018 at 2:12 PM
    YDCtaco
    Alexandria, VA
    I went to an nmo Mount on Hood Ditch light bracket.
