Taking Ignition cylinder lock out without using ACC? Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mohMoto115, Apr 10, 2019.
  1. Apr 10, 2019 at 5:59 PM
    mohMoto115
    mohMoto115 [OP] Member
    Moses
    I
    New member to the Toyota family, just bought my first Toyota off Craigslist, used, truck is in great shape, drives smooth, can’t even feel it shift, drives really awesome honestly.
    It’s a 2006 regular cab, 2.7 base model.
    I need y’alls help. So my key won’t twist. It did this 3 times Friday, but I got it to work twice by shaking the steering wheel/twisting the key. Well the 3rd time, no luck at all. Key is useless besides locking/unlocking the door.
    I’ve tried almost all the tricks trying to get the key to twist. How can I get the lock out Without the key turned to ACC.
    Also, no immobilizer, correct?
    Ignore the extremely poor electrical tape masking job.
  2. Apr 10, 2019 at 6:12 PM
    mohMoto115
    Moses
    I
    ^^ I watched that video. My key won’t turn, any suggestions?
    whatstcp likes this.
  3. Apr 10, 2019 at 6:27 PM
    mohMoto115
    Moses
    I
  4. Apr 10, 2019 at 6:37 PM
    Tacoma Mike
    Southern Maine
    You can drill it right down the center. The only problem is you need to know how to do it.
    There is a major risk of damaging the housing if done wrong.
    Not much else you can do.
    b_r_o likes this.
  5. Apr 10, 2019 at 6:42 PM
    Tacoma Mike
    Southern Maine
    Now that I have scared you.
    Bring your reg to a Toyota dealer.
    Ask them to cut you a key by vin.
    75% of the time a correct key is the solution.
  6. Apr 10, 2019 at 7:33 PM
    mohMoto115
    Moses
    I
    This isn’t the original lock in the first place, so getting a key by vin wouldn’t work?
    Drill it straight down the center? Can you elaborate a little more
  7. Apr 11, 2019 at 3:34 AM
    Tacoma Mike
    Southern Maine
    Oh crap
    Not original......
    Forcing it won’t help move it. Install, try ,jiggle, remove turn the key over, try again.
    I spent a lunch time one day doing this on a tow in. Took me 20 min but I got it to turn.
    Takes only once. Saved him the drill.
    Hard to explain.
    Drill size varies
    Depth varies.
    Start with drill size slightly bigger than key width.
    1/4 inch at a time ,blow out the chips. Go 3/4 of an inch.
    Try a screwdriver to turn.
    Watch your depth with another cyl.
    Make sure your key in buzzer switch and all removable items are off.
    Then go slightly bigger drill.
    I’ve done a lot of them over my career.
    It’s a technique
    A learned skill
    Patience is a virtue...
    Go slow and take your time and think of what your doing.
    You will need to be a little lucky the first time.
    b_r_o likes this.
  8. Apr 11, 2019 at 4:01 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Put the key in the cylinder and tap, hit the end of the key while turning it.
    b_r_o likes this.
  9. Apr 11, 2019 at 5:31 AM
    Tacoma Mike
    Southern Maine
    Then go up in hammer sizes...lol
    JK
    b_r_o, Larzzzz[QUOTED] and rmorse like this.
  10. Apr 11, 2019 at 6:45 AM
    mohMoto115
    Moses
    I
    Would it be possible to drill out the inside (like described above) and use a flathead to start it?
  11. Apr 11, 2019 at 6:51 AM
    Tacoma Mike
    Southern Maine
    Once you get the lock cyl assembly out ?
    No it's a male connection to the cyl IIRC
  12. Apr 11, 2019 at 12:30 PM
    Larzzzz
    Larry
    MA
    Seriously. I had to whack it pretty good to get it to turn.
  13. Apr 11, 2019 at 12:34 PM
    Tacoma Mike
    Southern Maine
    Sometimes that will work.
    I drill as a last resort. But you need to watch the lower internals of the switch housing also.
    The Ford Focus had issues years ago with ign cyl.
    Towed many a ford because of that. Ended up with a small hammer and doing what you did and got them started and told them to drive right to the dealer.
    Larzzzz[QUOTED] likes this.
  14. Apr 11, 2019 at 12:52 PM
    Larzzzz
    Larry
    MA
    Tape the drill bit the length of the key...
    mohMoto115[OP] likes this.
