Taking a dent out of the roof?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by willconltd, Apr 6, 2023.
  1. Apr 6, 2023 at 11:39 AM
    willconltd
    willconltd [OP] Well-Known Member
    Orlando, Florida
    I think I put a dent in one of my roof ribs while reaching over to wash the roof. Its super thin sheetmetal I guess. At least I think that's what happened, I'm honestly not sure.
    I'm thinking I should drop the headliner in back and push the dent back out.
    Anyone pulled down the headliner in the back before?
  2. Apr 6, 2023 at 11:51 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Maybe lie on your back and push with your feet gently? Or is it really dented in?
  3. Apr 6, 2023 at 11:52 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Id try pulling it with a suction cup first.
    zoo truck and japjoe7 like this.
  4. Apr 6, 2023 at 11:53 AM
    willconltd
    Orlando, Florida
    I placed my hand on the rib while reaching with the other to wash towards the front of the truck and it just caved in a bit.
    I don't think it will be all that hard to push out with my hand, however, I have to get around the headliner first.
  5. Apr 6, 2023 at 11:53 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    they have dent pullers that attach with hot glue and pull the dents out. I would go that route if i cared (but i dont remotely care about any dent on my roof that no one would ever see)
  6. Apr 6, 2023 at 11:53 AM
    willconltd
    Orlando, Florida
    I didn't even think about that. Great idea!
  7. Apr 6, 2023 at 11:59 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I don't think it's any thinner than the rest of the truck. Roofs in general aren't designed to take weight and can easily flex. As a kid I used to cave in the roof of my grandfather's pickup all the time with my body weight. It had a different design so it would pop back out on its own, but either way, it isn't designed to take weight.
    As for the headliner, I haven't personally done it, but I had the 3rd brake light recall done which required pulling the liner. You can't tell the liner was pulled, in case that's a concern for you.
  8. Apr 6, 2023 at 12:04 PM
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    Here is a quick instructional video:
    https://youtube.com/shorts/WsA5oeJIA-w?feature=share
    But honestly, its the roof. Assuming this is a door ding sized dent, how often are you actually going to even notice it?
  9. Apr 6, 2023 at 12:09 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    I pushed one out in my truck without even removing the headliner. Just pushed.
    SR-71A likes this.
  10. Apr 6, 2023 at 12:10 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    toilet plunger!
    musicisevil likes this.
  11. Apr 6, 2023 at 12:21 PM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    before you make it worse, just contact a PDR person in your area. (Paintless Dent Repair). it may be more cost effective than you think. and... when you make it worse, it will cost more to fix. Ski
    na8rboy and Chew like this.
  12. Apr 6, 2023 at 12:27 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
  13. Apr 6, 2023 at 12:33 PM
    auskip07
    Skip
    Atlanta, Ga
    Bertw192[QUOTED] likes this.
  14. Apr 6, 2023 at 1:40 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I used one of these when when a branch fell on my roof. Fixed the dent perfect.
  15. Apr 6, 2023 at 1:52 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    Yes, anytime there is a dent even like what you described the metal has been stretched, popping it back will get it 90%
  16. Apr 6, 2023 at 3:14 PM
    RedWings44
    Michigan
    Chew and Bertw192[QUOTED] like this.
  17. Apr 6, 2023 at 3:32 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I knew TW wouldn't let me down.
    mabepossibly[QUOTED] likes this.
  18. Apr 6, 2023 at 3:58 PM
    skidooboy
    central lower mich
    How are you getting the light out, without accessing the retainer screws for the lamp from the inside under the headliner? you need to at least drop the liner in the rear to access them, to remove the lamp, to add the new gasket, or lamp. no external retainers/screws on the lamp. Ski
    na8rboy likes this.
  19. Apr 6, 2023 at 4:24 PM
    auskip07
    Skip
    Atlanta, Ga
    to fix it correctly you need to drop the headliner, Toyota decided to fix it from outside. when you sell as many trucks as they do making a cheap fix is top priority.
  20. Apr 7, 2023 at 8:11 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I acquired a dinger in my rear quarter panel from a careless person with a shopping basket. Took one of these 110 lb suction cups, and pulled 99% of it back. You have to really look close to see where it was.
