Taillights stay on when engine is off
Discussion in '1st Gen. Tacomas (1995-2004)' started by emiintrn, Mar 28, 2022.
  1. Mar 28, 2022 at 12:52 PM
    emiintrn
    emiintrn [OP] New Member
    edwin
    2004 Tacoma TRD
    nne
    I have a 2004 Tacoma TRD 3.4 liter 2 wheel drive
    my tail lights started staying on when I turn off the engine
    Can anyone help me with this?
    Thanks: Ed
    Black DOG Lila likes this.
  2. Mar 28, 2022 at 1:14 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Does it have Tow wiring ?
  3. Mar 28, 2022 at 1:19 PM
    emiintrn
    edwin
    2004 Tacoma TRD
    nne
    it does not have tow wiring
  4. Mar 28, 2022 at 1:23 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Like key out of the ignition and the tail lights are still on? What about the headlights? Only time (that I'm aware of) the tail lights are on is with the headlights, and even if you leave the headlights on, they shut off when you turn the engine off and remove the key. I used to just leave my headlights on 100% of the time (poor man's daytime running lights) because it was basically impossible to leave them on accidentally.
    But as blackdog said, trailer wiring is a common cause of weird tail light/turn signal issues.
    Have you done anything to it recently? Wiring or other mods/maintenance?
  5. Mar 28, 2022 at 1:39 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Check the 10A tail fuse for power with the key OFF and OUT of the ignition and headlights off.
    It should NOT have power. Then go from there.
    Otterstuff likes this.
  6. Mar 28, 2022 at 3:37 PM
    alexh
    alexh Well-Known Member
    1998 TRD
    Are you sure its not brake lights? I saw this a couple of times on my truck, made me do a double take for sure. It must have been a sticking brake light switch or I adjusted the switch, can't remember.
    Black97v6MT and Otterstuff like this.
  7. Mar 28, 2022 at 3:59 PM
    jbrandt
    Justin
    Good point! Definitely a possibility.
    @emiintrn the 3rd light on top of the cab will tell you if it's the brake lights or not (assuming the bulb isn't burned out).
    Black97v6MT likes this.
  8. Mar 28, 2022 at 4:49 PM
    Cheap Taco
    Cheap Taco Well-Known Member
    2001 Tacoma Limited Double Cab
    Make sure it's not the brake lights. Mine did that a couple months ago. I noticed some green plastic on my floor- the little plastic piece broke on my brakes by the pedal. I put a quarter in it's place with gorilla tape and never had an issue since.
  9. Mar 30, 2022 at 8:53 AM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    If this is the brake lights staying on, I had the same issue and the fix is cheap! There is a little bump stop where your brake switch sits into, the old plastic gets brittle and falls apart, $1.50 part from the dealer fits right in. Mine fell apart in hardened pieces.
    Black97v6MT, Otterstuff and Civi like this.
  10. Mar 31, 2022 at 4:52 PM
    Civi
    Civi Active Member
    Carlos
    2004 Impulse Red Dbl TRD 2wd
    265/70R17, Helo Rims, leveling kit, smoked rear lights, led light bar, double din JVC, backup camera, led interior lights, red rock pod lights, led headlights
    Same thing happened to my '03 IS300. I was actually able to get down there and found an adjustment nut. Just had to back it off ever so slightly. Drove me nuts till I figured it out and just like cheap taco I had little green bits on my floor mat
  11. Jun 30, 2022 at 5:37 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    This has been plaguing me for months. I tried adjusting the switch and it would work at that time. I finally ordered a new switch and went to install it just 20 minutes ago when I noticed that the old switch perfectly lined up with a hole in the tab that triggers it. I’ll assUme that there used to be a piece of plastic that fit there which has long since deteriorated and finally fell apart a few months ago. I didn’t have a bolt/nut small enough to put in it so I slightly bent the mounting tab the switch is in to miss the hole.
    Now that I think of it. I happen to have a small kit of automotive push in barbs that may have a small enough one to work.
  12. Jul 1, 2022 at 10:07 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    What year did that start lights shut off with the ignition and key being removed?
    Tail light relay contacts fused?
    I think Brake light switch failed or out of adjustment?
  13. Jul 1, 2022 at 2:25 PM
    jbrandt
    Justin
    Not sure, mine's an '04. I can't remember if my '97 5 lug had auto shut-off lights or not. That was a long time ago, lol.
  14. Jul 1, 2022 at 2:35 PM
    Clearwater Bill
    Billy
    Largo Florida
    Another vanishing OP.
    Gone over a month, and we may never know the solution.
  15. Jul 1, 2022 at 2:46 PM
    noodles93
    Charleston, SC
    This seems like a common issue among these trucks as they age. Generally its the bump-stomp that falls apart after 20+ years and costs a buck and change to replace. Fixed the issue for me and was a hell of a lot cheaper than a brake switch.
  16. Jul 1, 2022 at 7:06 PM
    Brake Weight
  17. Jul 3, 2022 at 10:30 AM
    Kevins60
    Kevins60 axle wrap tells me my rear brakes are working
    Kevin
    Odessa FL
    ‘04 4cyl SR5 AT Pre-runner Garage Queen
    SCS Cruise Westin step bars Lund tonneau Jensen HU
    i bet it wasn’t a problem to begin with. The headlights and taillights stay on until the door is opened even with the key out of the ignition.
  18. Jul 3, 2022 at 10:41 AM
    Bivouac
    Now my 2000 does not have this option or show it on the EWD.
    I did have it on my 85 Celica
