Taillight harness
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SoonToBeOn39s, Nov 13, 2023.
  1. Nov 13, 2023 at 4:03 PM
    SoonToBeOn39s
    SoonToBeOn39s [OP] Well-Known Member
    I finally got bigger tires 2020 Long Travel Tacoma 1997 MAGNUM
    Long story short my taillight fell out and I dragged it for a little ways. The tailight pulled the wires off the harness clips. Any one know how to get this back to how it was?
  2. Nov 13, 2023 at 4:46 PM
    wayne0
    wayne0 Well-Known Member
    First of all, we want to know how your tail light 'FELL OUT". It's held in by two 10mm bolts and the wires are not long enough to drag on the ground. Come clean, you fu*ked up some how.
    Chew, BlackTRD4Me and Barsoom like this.
  3. Nov 13, 2023 at 5:14 PM
    SoonToBeOn39s
    Fiberglass bedsides. Ask someone with fiberglass besides that actually off-road, and they'll tell you they've had taillights fall out. Where the 10mm bolts bolt into break as pictured. I'm on my 3rd set. Just wondering how to fix it. Not that big of a deal
    Stevie17 likes this.
  4. Nov 14, 2023 at 2:25 PM
    wayne0
    OOOW, That's nasty!!
  5. Nov 14, 2023 at 5:37 PM
    SoonToBeOn39s
    Any recommendations tho? Do I need a new harness clips thing, or what's my best bet? I'm not a wiring genius lol
    FLAK-TAC likes this.
  6. Nov 14, 2023 at 5:56 PM
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
    I’d talk to Dave with FBC Harness Solutions, maybe he can build you one or steer you in the right direction.
  7. Nov 14, 2023 at 7:22 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Tag him in to the thread
    @daveeasa
    As for the taillamp bolts pulling through the fibreglass, how about using a large fender washer to spread the load out.
  8. Nov 14, 2023 at 8:34 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I can build a pigtail or help you locate terminals and seals. You’ll need a crimper too.
    3rd gen Tacoma brake connector (triangle) pinout is:
    1. Brake, blue
    2. Ground, white w black
    3. Parking lights, green
    turn connector (flat 3 pos) I think has ground also in the 2 spot but I have to check my templates.
    SoonToBeOn39s[OP] and Speedfreak like this.
  9. Nov 14, 2023 at 11:24 PM
    SoonToBeOn39s
    You are the shit. Thank you so much
  10. Nov 14, 2023 at 11:31 PM
    SoonToBeOn39s
    On second thought How much would pigtails cost for you to build them?
  11. Nov 15, 2023 at 7:01 AM
    daveeasa
    David
    PNW
    $10 each connector maybe? One turn and one brake? $5 shipping. Hard to know if it’s just one side or if the reverse is ok. I can include supplies, you’d need wire strippers and a heat gun or hair dryer.
  12. Nov 15, 2023 at 8:45 AM
    wayne0
    Junk yard for the win. A couple of heat shrink crimps and you're on your way.
  13. Nov 15, 2023 at 3:28 PM
    SoonToBeOn39s
    What size are the crimps for the harness clips? It's giving me the option for different sizes
  14. Nov 15, 2023 at 3:35 PM
    daveeasa
    David
    PNW
    If you're going to re-crimp your wires, I believe OEM is 20 gauge so you want 090II sealed for the smallest size and the matching seal:
    Yazaki:
    7116-4025 -- skt
    7158-3006-90 -- seal
    or sumitomo:
    8100-0460 -- skt
    7165-0842 -- seal
  15. Nov 15, 2023 at 3:37 PM
    daveeasa
    David
    PNW
    Then, if your connectors are damaged you'd need
    6189-0179 brake (sumitomo)
    6189-0177 turn (sumitomo as well)
    The sumitomo and yazaki 090II terminals and seals are cross compatible but if you want to get all super duper matchy matchy then go sumi for everything.
    SoonToBeOn39s[OP] likes this.
  16. Nov 15, 2023 at 3:40 PM
    SoonToBeOn39s
    Y
    You are so helpful, I really appreciate it. Another question but is there an easier way to get the old crimps out?
  17. Nov 15, 2023 at 3:44 PM
    daveeasa
    David
    PNW
    1.5mm flathead screwdriver. Pry the white TPA away from the face and pop completely out. Small needlenose can help but more for the males, female need to be pried open. Then use the same 1.5mm blade to pull the plastic tab away from the terminal and push it out from the front if no wire to pull on the back. So you need another small screwdriver or at least a toothpick.
  18. Nov 15, 2023 at 3:45 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    You can probably buy the entire connector repair package from Toyota. I buy them all the time for fixing collision damaged harness’s.
  19. Nov 16, 2023 at 10:46 PM
    SoonToBeOn39s
    I was able to get the old pin crimps out. Now I'm just waiting on the new ones to arrive. I appreciate all the info, it's been super helpful.
    daveeasa[QUOTED] likes this.
  20. Feb 19, 2025 at 2:19 PM
    SoonToBeOn39s
    Thread revival. @daveeasa do you have a website you recommend to buy the sumitomo 8100-0460.
    All the websites I pull up are shipping from China, just seeing what you recommend thanks
