Tailgate replacement options?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tac0000, Oct 19, 2020.
  1. Oct 19, 2020 at 9:09 AM
    Tac0000
    Tac0000 [OP] Member
    I am doing some research to figure out the best way to go about replacing the tailgate on the truck I just bought.
    My paint and clear coat is in great condition on the rest of the truck.
    An exact copy might be hard to find in a junkyard with good paint; how good are the aftermarket tailgates? Is it hard to find the decals to make it stock again? Any recommendations?
  2. Oct 19, 2020 at 9:12 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Find a good one in the Salvage yard. Take it to a Body Shop for prep and paint to match your truck. The body shop can apply decals or emblems of your choice.
    Install on truck.
    You chances of finding a good tailgate that matches the paint/decals/emblems on your truck is pretty slim. If you order a tailgate, it will likely be primed, some may provide a painted gate, but you need to provide your truck's paint code.
  3. Oct 19, 2020 at 9:25 AM
    Tac0000
    Tac0000 [OP] Member
    Thanks Knute. I’ll start looking.
  4. Oct 19, 2020 at 12:00 PM
    Tac0000
    Tac0000 [OP] Member
    Any thoughts on salvage yard tail gates vs the non-oem/aftermarket new ones that are on eBay?
  5. Oct 19, 2020 at 12:02 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    where are you located? There is a red tacoma sitting outside a body shop with a wrecked front end but perfectly good rear parts near me in Nashville.
    Edit: nvm, I see the california plates now. You shouldn't have any issues finding one in a salvage yard somewhere
  6. Oct 19, 2020 at 12:57 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If you were closer I would buy your old one much better shape then mine is.
    Making a new one is on the project list some place down the road.
  7. Oct 19, 2020 at 1:22 PM
    Knute
    Frankly, I don't have a lot of faith on parts on Fleecebay.
    Hit the salvage yards first. Many are connected to a network of other yards. You may be able to "order" from another yard to be delivered to you or your salvage yard.
    Seagull233 likes this.
  8. Oct 19, 2020 at 2:03 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    Hey, that'll buff out!:rofl:
  9. Oct 20, 2020 at 2:11 PM
    Skybow
    Skybow Well-Known Member
    Manuel
    2000 Toyota Tacoma 4wd Extended Cab
    A lot
  10. Oct 20, 2020 at 6:18 PM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    Try car-part.com.
    NSDON, hogeyphenogey and Kwe1982 like this.
  11. Oct 20, 2020 at 8:10 PM
    UtahTacoma02
    UtahTacoma02 Well-Known Member
    Dave
    SLC
    02 Tacoma Double cab TRD Limited
    ARB front bumper, Old Man Emu suspension, on board air compressor, on board hot water converter, cb radio, safari snorkel, warn 8K lb. winch, AP rock slidders/rear bumper, gray wire mod
    I would stick to finding a used oem tailgate. I have heard that the aftermarket ones are made with thinner gauge steel.
  12. Oct 21, 2020 at 2:35 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    I use this all the time. Be careful though- I ordered headrests for my 03 and got 96-00 versions with a “tweed like” material not the velour like that I need.
    not that that would be the case with the tailgate.
  13. Oct 21, 2020 at 3:00 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    I can’t tell if the first link is silver or tan. If silver, 400.00 is a great deal.
    https://sacramento.craigslist.org/pts/d/sacramento-tailgate-for-2003-toyota/7214483171.html
    https://sfbay.craigslist.org/pen/pts/d/redwood-city-tacoma-tailgate/7215561128.html
    http://www.californiaautoparts.com/
    You can also have some junkyards do a national search to find what you need.
    I would stay away from pre-painted tailgates. I went that route and it was a rust bucket in 5 months, and my truck sits in a temp controlled garage.
    F6EE1D42-400D-4DAB-8793-DA63052CD623.jpg 5D2A3EB0-61B2-421B-BFA8-8FA12A3E9109.jpg
    You can get a primed tailgate and spray it yourself with aerosol cans. I went to Sherwin Williams and for around 120.00, purchased my color and clear coat/supplies needed to fix my truck.
    Let me know if you can see where I painted....
  14. Oct 22, 2020 at 11:18 AM
    BNG_PA
    BNG_PA Member
    Eastern PA
    2002 Tacoma Double Cab, V6, 4x4 (320,000+), 2020 TRD Sport Double Cab MT
    2.5’ Rancho Quick Lift & OME
    My 02 DC is Super White, so found a painted tailgate from Amazon for $170. Yes, you find cheaper, it just depends on your location and level of finish that you desire
    TAILGATE PAINTED 040 Super White TO1900106 FOR 1995-2004 TOYOTA TACOMA STANDARD BED https://www.amazon.com/dp/B07B8WTVCM/ref=cm_sw_r_cp_api_i_NVCKFb73NDE2Z?_encoding=UTF8&psc=1
    the fit and finish is great. But, I didn’t transfer the letters (like OP).
    Dekoy909 likes this.
  15. Oct 22, 2020 at 1:37 PM
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
