Tailgate Lock by McGard
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skistoy, Dec 16, 2010.
  1. May 18, 2011 at 4:21 PM
    #41
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    The tailgate is EASILY (as in less than 30 seconds easily) stolen.
    To remove it, you just open it, and lift up on the right (passenger) side while rotating it, until the gate slides up and out of the rotating hole. The driver's side id completely enclosed, so it can't be removed by that side.
    This is where the lock, (or cheap hose clamp) come in handy. It wraps around the passenger rotating hole, thereby stopping the gate from just being lifted out. You first have to remove the object, which takes time and effort. Hopefully more time and effort than the next truck beside you ;)
  2. May 19, 2011 at 7:44 AM
    #42
    jigmyster08
    jigmyster08 New Member
    Tacoma
    Thanks Ryan. Got it now.
  3. May 19, 2011 at 6:44 PM
    #43
    skistoy
    skistoy [OP] Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Nice, didnt even think about that.
    you dont have the preatty plastic cover
    but you have the keyed clamp still
    that cant be removed without the special key.
    great idea
  4. May 19, 2011 at 6:52 PM
    #44
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Though they might not have the key but you guys do know that the strap can be cut with a cutting pliers fairly easily. I've tried it with just the hose clamp mod attached.
  5. May 25, 2011 at 11:21 PM
    #45
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    I called mcgard and they say they don't make a lock for 2nd gen tacos is the one for tundras the same
  6. May 25, 2011 at 11:27 PM
    #46
    csjumper2003
    Savannah, GA
    So then Wat the hell is this thing in this forum then lol
  7. May 25, 2011 at 11:32 PM
    #47
    csjumper2003
    Savannah, GA
    I just bought pop n lock at 4wheel parts pl5300 for 53 dollars the hell with the other lock think I like that better anyway. U get one of those
  8. May 26, 2011 at 12:56 AM
    #48
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Its on the forum as a precautionary tale. To warn you about what you're getting yourself into with this item. The only way this will work with a taco is to cut the cover off. then you have a hose clamp with a fancy end. Save 24 bucks. Buy the hose clamps with the little yellow end for toolless tightening. Tighten it down, then with a pair of pliers pull the plastic top off and the screw that left is a "security" square head.
  9. May 26, 2011 at 5:59 AM
    #49
    viperstd
    viperstd Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    Or do the hose clamp mod and then grind the head down so no tool will take it off. If you ever need your tailgate off, you will need to cut it off. A thief with a good pair or dykes or end cutting plairs will get a hose clamp off in under 10s.
    They know about the hose clamp mod. They read the forums. They are professional-human-filth.
  10. May 26, 2011 at 10:21 AM
    #50
    csjumper2003
    Savannah, GA
    Did that first just personally like the security of the pop n lock as well
  11. Oct 3, 2012 at 10:52 AM
    #51
    lchbowhunter
    lchbowhunter Member
    Clay, WV
    12 DCSB TRD off road
  12. Dec 9, 2012 at 11:51 AM
    #52
    Steage
    Steage Member
    I saw that as well, and seeing as the McGard is my favorite slightly-more-secure-than-a-hose-clamp solution, I decided to give it a try on my 2013.
    Sure enough, it still doesn't fit. You can actually close the tailgate with the thing installed, but its an interference fit. So, I trimmed it down with a dremmel.
    Pretty ugly, but I'm happy with it...
  13. Jan 8, 2013 at 10:58 AM
    #53
    lchbowhunter
    lchbowhunter Member
    Clay, WV
    Thanks for that info!!
  14. Aug 18, 2013 at 4:32 AM
    #54
    SamSin
    SamSin I can resist everything except temptation
    Jersey Sam
    NJ
    Longbed 4x4 SR5
    Oil Free AFE Pro Dry S Air Filter, Nitrogen filled tires, Tonno Pro Tri-Fold Hard Tonneau Cover BLU Logic Handsfree
    While a pop & lock and a hose clamp are not theft proof, they will slow down a thief. Most thief's like to be quiet and quick. Anything to slow them down might be enough of a deterrent for them to move on. Backing up to a wall or pole if available, wouldn't give them any clearance to open the tailgate enough to get it off.
    If you are in an area where that is a common occurrence, perhaps having the gate hooked up to the alarm system would also work.
  15. Jul 24, 2014 at 12:42 PM
    #55
    ItsaDryHeat
    ItsaDryHeat New Member
    Phoenix, AZ
    2014 PreRunner Double Cab 4x2 V6
    I got my 2014 Double Cab last week and I was going to do a tailgate lock as my first mod (I've had other tailgates stolen) and when I put the gate down guess what I saw... it already came with a MacGard tailgate lock. The sticker makes no mention of it anywhere and the dealer never mentioned it. Also, I can't find the key anywhere so it must be a dealer thing but I will ask when I go in for some maintenance stuff.
  16. Jul 25, 2014 at 6:38 AM
    #56
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    The dealer probably installed the lock while the truck was stored on the lot to prevent theft, and forgot to take it off when sold.
  17. Jul 25, 2014 at 9:33 AM
    #57
    ItsaDryHeat
    Phoenix, AZ
    I'm at the dealership now getting the clear bra installed (they ran out when I picked it up) and the told me that they added the lock to all trucks as a courtesy (no charge) after someone came into their parking lot and stole about a dozen tail gates. The key is with the jack tools along with the lug-nut key.
    Cool!!!! Freebie.
  18. Jul 25, 2014 at 10:10 AM
    #58
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    Did the dealer modify the lock in any way to get it to fit? Seems the posts above say the lock is too large to fit.
  19. Jul 25, 2014 at 9:02 PM
    #59
    ItsaDryHeat
    Phoenix, AZ
    It doesn't look like its been modified and this one looks a tad bit different from the other pics here. Tomorrow I will try to take it off and see if there's a model number on it and I'll post some pictures.
  20. Jul 26, 2014 at 10:02 AM
    #60
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    I agree. If someone really wants something bad enough thay can tow the vehicle. I want to be sure "someone else" has an easier tailgate to snatch and run with. I use the hose clamp w/ plastic key wrench....
    also ... "Backing up to a wall or pole if available" an obvious easy solution if available but I never thought of this - especially in a parking garage!
