Tailgate hinge
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JKP, Sep 28, 2023.
  1. Sep 28, 2023 at 8:09 AM
    JKP
    JKP [OP] New Member
    2016 Tacoma TRD Sport
    My 2016 tailgate started binding when closing on the passenger side. I see there is what looks like a rubber cap that goes on the little post on the tailgate and then slips into the slot on the bed. Every parts website i've been on want's to sell me a new hinge. Can you just buy the little rubber cap? Sorry if this has come up before, I tried a search and couldn't find any reference to this. Thanks
  2. Sep 28, 2023 at 8:13 AM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
  3. Sep 28, 2023 at 8:15 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  4. Sep 28, 2023 at 8:28 AM
    mrtonyd
    mrtonyd Well-Known Member
    Tony
    Colorado
    2019 TRD OR DCSB cement
    this thing? this is the passenger side. no idea what part numbers would be though
  5. Sep 28, 2023 at 8:32 AM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    You Tried Lube?
    wombatz likes this.
  6. Sep 28, 2023 at 8:50 AM
    wombatz
    wombatz Active Member
    Doug
    2017 Tacoma 4x4 access cab
    Receiver hitch.
    If I see that right then it looks like the worn/torn section is in a flat. So that should not be wearing unless a rock/etc got in there when closing.
    You can pull that up, like you were going to remove the gate and see if it needs cleaning in there. Just be careful of the backup camera wire.
  7. Sep 28, 2023 at 8:52 AM
    mrtonyd
    Tony
    Colorado
    i posted that pictures and am no OP. was just trying to see if thats what they were talking about.
    yea, i loaded my bed up with tons of rocks and some got in there. oh well
    HondaGM likes this.
  8. Sep 28, 2023 at 8:57 AM
    wombatz
    Doug
    Receiver hitch.
    Oops, forgot to even notice that it was not the OP that posted that. Maybe the OP has one that got torn up much worse.
    HondaGM likes this.
  9. Sep 28, 2023 at 9:00 AM
    RichochetRabbit
    It has only been 45 minutes. The OP should report back before the end of the day. Then you superheroes can swoop in and save the day. ;)
    TRDRed and HondaGM like this.
  10. Sep 28, 2023 at 9:22 AM
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
  11. Sep 28, 2023 at 9:40 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    There is an updated part number, you can only get the entire hinge. The rubber piece is no longer available
    TRDRed and stftaco like this.
  12. Sep 28, 2023 at 9:47 AM
    JKP
    JKP [OP] New Member
    Yes, it looks like that. I won't see the truck for a couple of weeks, but I will check that out. Thanks everyone for the replies. I was surprised by the fast results
    TRDRed likes this.
  13. Sep 28, 2023 at 9:54 AM
    stftaco
    ...Unless you look on ebay...
    rolled93slc[QUOTED] likes this.
  14. Sep 28, 2023 at 10:44 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    someone told me the Chevy version works too, but i havent confirmed.
  15. Sep 28, 2023 at 11:00 AM
    wombatz
    Doug
    Receiver hitch.
    I did not do anything to confirm fit, but my hit does look about the same. If it does fit then it looks like you can get two for less then one of the ebay Tacoma dinguses:
    https://www.amazon.com/APPERFiT-Tai...=&hvlocphy=9033136&hvtargid=pla-1966325016940
    stftaco and aficianado[QUOTED] like this.
  16. Sep 28, 2023 at 12:49 PM
    stftaco
    Dinguses, I'm not sure I've ever heard the plural before. I would have thought the plural would be Dinguii or something similar. o_O
    So for $10 it's worth getting it, and having an extra on hand. It does appear to have the plastic pin with the flaired tip. I think the chances are good it's going to work. :burnrubber:
  17. Sep 29, 2023 at 7:20 AM
    aficianado
    back to bone stock.
    Dinguses. I can work with that.
    akimmel and stftaco like this.
  18. Oct 19, 2023 at 12:47 PM
    JKP
    JKP [OP] New Member
    Finally fixed it. Thanks everyone for the input. Before going on vacation I ordered the part that Stftaco recomended on EBAY. After ordering, I read another post somewhere that said Toyota changed this hinge from what came on the early '16 Tacomas (bought mine (9/15), and the hinge would have to be changed out to the new style (which means removing the bumper to get to it). While the part from EBAY was too tight to fit over the hinge piece on the bed, I was able to slightly increase the opening size in the new part and it fit. Good old Dewalt drill and a sharp wood chisel made it work. I don't know how long it will last as I made the walls of the part thinner, but if it lasts half as long as the first one (8 years) I will be happy with the $13.00 fix.
  19. Mar 14, 2025 at 6:24 PM
    Jimlanier01
    Jimlanier01 Member
    Jim
    '16 Tacoma SR5 4x4
    Husky Floor Mats. Plastic center console divider. CoverKing Neoprene seat covers. Febreeze air freshener, the stick kind you put on the AC vent.
    Reckon how hard it is to change that hinge out? Anybody got any idea?
  20. Mar 14, 2025 at 6:52 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
