Tailgate height from the ground when open on different models?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by davegoroun, Jul 26, 2022.
  1. Jul 26, 2022 at 10:20 AM
    davegoroun
    davegoroun [OP] Well-Known Member
    USA
    '19 DCLB TRD Offroad
    In looking at the current Tacoma models I notice the wheel options range from 16-18 inches.
    Does this affect the tailgate height from the ground when it is open?
    Carrying motorcycles is a major function of my truck, and loading them has been problematic at times.
    Is there a height difference between the SR5 at 16" wheels to the Limited at 18" wheels?
    I searched high and low and can't find a direct answer. Help?
  2. Jul 26, 2022 at 10:23 AM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
    Wheel size is irrelevant as all models have tires of the same outside diameter.
    An SR5 & Limited are the same height (they even share the same suspension).
    jmneill, davegoroun[OP] and Tacospike like this.
  3. Jul 26, 2022 at 10:25 AM
    Tacospike
    Two Trucks
    As wheel size changes the tire sizes will accommodate most of the difference
    davegoroun[OP] likes this.
  4. Jul 26, 2022 at 10:30 AM
    davegoroun
    USA
    Thank you! That clears it up!
  5. Jul 26, 2022 at 10:32 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    265/70-16 = 30.61” OD
    265/65-17 = 30.60” OD
    265/60-18 = 30.52” OD
    The limited will actually get you 0.045” closer to the ground. Or in other words, they’re all the exact same size and height.
    Just different sidewall heights.
    Cheers
    beergeek likes this.
  6. Jul 26, 2022 at 12:58 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Have you looked at easy load trailers? When I used to have motorcycles I always hated trying to get the in the bed.
    https://www.klingertrailer.com/ramp-less-drop-bed-easy-load-motorcycle-trailer/
