Tailgate Cap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GorgeRunner, May 30, 2022.
  1. May 30, 2022 at 2:46 PM
    GorgeRunner
    GorgeRunner [OP] Out There
    2005 PreRunner
    All the tabs are broken off the stock tailgate cap and it's time for a new one. Most of the search results are older, not sure I need a custom job.
    OEM, Amazon, eBay; any satisfied replacement tailgate cap customers?
    DG92071 likes this.
  2. May 30, 2022 at 2:54 PM
    DG92071
    DG92071 Well-Known Member
    If you're looking for something that's made of better quality material than the stock piece Christian06 has made a really nice one for someone else. Unless he's got a grudge against you I'm sure he'll make one for you too.
  3. Jun 1, 2022 at 10:19 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    BassAckwards and Jojee117 like this.
  4. Jun 2, 2022 at 1:16 AM
    TacoTuesday1
    FL
    You know it's the internet when you get wrong answers.
    OP: What's 2+2?
    Bob: 5
    Jim: 7
    The correct answer if Relentless Fabrication. It combines both into one piece for strength. Aluminum version lighter than steel.
    Unless you want to buy crap. If you do, go ahead
    Rob MacRuger and clenkeit like this.
  5. Jun 2, 2022 at 7:36 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    If you still have a cap/topper on your truck pay attention to the fit for any aftermarket replacement. I got a Mobtown and it sits lower and flat. It also doesn't curve over the gate. I drive out in the dusty desert a lot and there is a gap that sucks in a lot of dust.
    Rob MacRuger likes this.
  6. Jun 2, 2022 at 8:33 AM
    TacoTuesday1
    FL
    I wonder if leer and snugtop caps (the nice one) would curve over. Or if you can put 1” foam insulation strip or something
    I have KB voodoo side caps which sit lower
    But it has worked with modification using a Softopper
    clenkeit likes this.
  7. Jun 2, 2022 at 8:58 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    I can vouch for this. I love my Relentless aluminum tailgate panel. Stiffened things up considerably and now there's a flat surface to put my beer.
    dborrer likes this.
  8. Jun 2, 2022 at 11:42 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  9. Jun 2, 2022 at 1:38 PM
    GorgeRunner
    2005 PreRunner
    I have an ARE shell, that's a factor, especially with custom parts. Tacomas seem to be a challenge for perfect camper shell fitment.
    I will check out the other suggestions. Thanks for the info.
  10. Jun 2, 2022 at 1:54 PM
    redcon
    redcon Well-Known Member
    Dave
    Southern PA
    2012 AC 4x4 Base 2.7L/5MT
  11. Jun 2, 2022 at 5:56 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Just drill 3-4 small holes and use stainless sheet metal screws and basically free. Works fine.
    As others said with any shell and stock or other tailgate cap, dust will always get sucked into the shell around all 4 tailgate seams/edges and the window edges.
  12. Jun 2, 2022 at 7:36 PM
    BKinzey
    Beauford
    Hollywierd, CA
    Here's my temp solution. Been on my SnugTop for over a year :duh:
    Had that foam from another project. Laid down some Gorilla Tape, put the foam on that and there is a piece of Gorilla Tape on the backside that you can't see. Was a temp solution and I just left it there.
    If the cap stuck out another 1/2" or the rubber seal on the cap rear window was an inch longer it would probably be fine.
  13. Aug 27, 2023 at 11:32 AM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    Is the Relentless Fab's panel the top cap AND a metal flat surface for the back of the tailgate all in one? Or is it just the top cap portion?
  14. Aug 27, 2023 at 12:14 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    It's the whole thing. It's great, but dear lord their shipping is out$$$rageous.
    They wanted like $180 to ship to me on the east coast. Ended up emailing their sales lady who was very nice... and in the end, paid them like $25 for packaging, and I wanna say my actual cost on Pirateship was like $50.
    Only other downside is IMO it looks extra goofy if you don't also get KBVoodoo rails for the sides.
  15. Aug 27, 2023 at 12:47 PM
    BKinzey
    Beauford
    Hollywierd, CA
    Since this popped up again I should give an update.
    I replaced the Mobtown with a used VooDoo tailgate cap. The last guy glued a piece of Delrin, about 1/4 to 3/16" thick, on top of the cap. I haven't tested it in a dusty area yet but I can tell it seals much better with my SnugTop. I'm going to be replacing the SnugTop with a Lone Peak wedge camper soon and I think the VooDoo will work better than the Mobtown for my needs.
    Another thing I will mention is the tailgate is very "leaky" where dust is concerned. I used 2 or 3 different types of rubber seals between the gate and truck bed to help with dust incursion and it's a lot better but it's not like a door seal.
  16. Aug 27, 2023 at 5:30 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I used sheet metal screws too. Works fine
  17. Aug 28, 2023 at 3:16 PM
    dborrer
    Mr. Dan
    St. Augustine, FL
    TY.
    Do you have a picture of the "extra goofy look" you refer to?? I'm curious. I like the idea of the integrated cap to back side (and flat) panel...
  18. Aug 28, 2023 at 5:42 PM
    dborrer
    Mr. Dan
    St. Augustine, FL
    is this product just the cap or an integrated flat back panel as well?
  19. Aug 28, 2023 at 5:46 PM
    BassAckwards
    Just the cap sir
    dborrer[QUOTED] likes this.
  20. Aug 28, 2023 at 7:44 PM
    fb40dash5
    11 V6 AC 4x4
    I don't, but... ya know how the tailgate top sits like 1/4" lower than the sides already? Make it sit like another 1/4"+ lower, cuz now it's just 1/8" aluminum sitting pretty much right on the sheet metal.
    On the bright side, the closest to a complaint I have about the KB side rails is that my factory plastic ones had rubbed a few spots through the paint (possibly helped along a lot by the cap that was on it when I bought it) and that's not the new rails' fault....
