Tailgate Cable
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tantacoma23, Jul 29, 2022.
  1. Jul 29, 2022 at 5:25 PM
    tantacoma23
    tantacoma23 [OP] New Member
    Brad
    I’m having trouble replacing my tailgate cables.. has anyone else been through this? Apparently no one manufactures them! Will second gen fit on a third gen truck?
  2. Jul 29, 2022 at 7:00 PM
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
  3. Jul 29, 2022 at 7:35 PM
    tantacoma23
    Brad
    Thanks!!!
  4. Jul 30, 2022 at 9:28 AM
    cbouch001
    cbouch001 Well-Known Member
    Charlie
    PNW
    2020 SR5 Taco
    OTT Tune, Bilstein 5100 with Icon RTX, SCS F5 , ARB Recovery point, MBRP Exhaust
    I literally just replaced oneof mine
    Dealer had to order it but was there next day. 30 bucks
  5. Jul 30, 2022 at 10:00 AM
    tantacoma23
    Brad
    That’s awesome. My whole tailgate was stolen and apparently the part is on back order, so I started looking around to find it myself.
  6. Jul 30, 2022 at 11:17 AM
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    Removing the tailgate is done for loading heavy loads, especially with pallets. The tailgate cables holding the tailgates are not design for holding heavy loads, better to remove them , then damage the tailgate if cables break.
    Some people believe dropping or removing tailgates save gas mileage, studies shown this to be not true. Better to leave the tailgate up. Aerodynamics-wind goes into the bed push the air above the roof to flow over the bed.
    SEMA wind tunnel has shown having a Tonneau does improve gas mileage.
    Bottom line mainly for loading heavy loads, and keep the tailgate from damages. Yes it does make it easier to steal. Most of us will never remove our tailgate. But if needed? We got this option.
  7. Jul 30, 2022 at 12:35 PM
    Lava-road
    2019 trd-off road
    There are aftermarket tailgate locking devices. Sometimes easier to steal the whole truck. Lol
  8. Jul 30, 2022 at 9:25 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    one thing to slow the thieves down
  9. Jul 30, 2022 at 9:38 PM
    Fasthawk99
    Fasthawk99 Well-Known Member
    anthony
    2008 ACLB, 3" toytec and leitner'd out SOLD, 2021 TRD OR
    3 toytec, JBA UCA, 285 MTZ, Leitner rack with goodies
    A good practice is to replace both cables at the same time. Cables stretch slightly over time and if 1 needs it or could use it, replace both is a safety measure I take.
  10. Jul 30, 2022 at 10:30 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    When you replace the cables - use a washer to capture them at the upper bolt. Slows down someone releasing them as it will take a wrench (or cutting the cables) to free the tether.
    At the slotted hinge side, disassemble the hinge from the tailgate. Measure the hinge diameter then get a short piece of exhaust tubing that is a tight fit over the slot. Deburr this tube/ring and paint it inside and out to defeat rust. Reassemble the hinge to the gate, and the gate on the truck - with the ring slipped on and blocking the slot. To finish, fill the screw holes with JB Weld to block easy removal.
    Don't risk your tailgate on a hose clamp - my grandson can defeat that in seconds - and don't spend a lot of money on the keeper ring.
  11. Jul 31, 2022 at 12:20 AM
    RIX TUX
    :worthless:
  12. Jul 31, 2022 at 6:23 AM
    GREENBIRD56
    Casper / Tucson
    014 Taco 4Dr 4wd
    photos are in my album - years old now
  13. Jul 31, 2022 at 12:03 PM
    Lava-road
    2019 trd-off road
    The solid ring looks very secure. Great idea.
