Tail Light wiring harness disconnect from bulb socket
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jskwelch, Feb 10, 2022.
  1. Feb 10, 2022 at 4:32 PM
    Jskwelch
    Jskwelch [OP] Member
    Jim
    2019 Tacoma Ofroad
    Basic stock with some LED lights
    I need some help I can’t seem to disconnect my rear tail light wiring harness from the bulb socket. Do I need to push down, pull back etc I want to install a MESO total tail stage 1 kit? So far I can’t seem to figure out out to separate the harness so I can plug in the provided one in the kit. YouTube doesn’t really show the process other than people seem to simply pull the bulb socket from the harness with ease.
  2. Feb 10, 2022 at 4:35 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    I had this same problem when I installed the Stage 1 on my truck. You have to twist the bulbs out. Sometimes they stick.
  3. Feb 10, 2022 at 4:36 PM
    316sherm
    316sherm Well-Known Member
    South Louisiana
    2020 Tacoma SR TSS Package 4 Cyl
    Squeeze and pull by hand outward. I had trouble with the reverse light so I used a pair of pliers (very gently).
  4. Feb 10, 2022 at 4:44 PM
    Jskwelch
    Jim
    2019 Tacoma Ofroad
    I can get the bulbs out without an issue it is separating the harness from the socket itself. Pulling, tucking etc hasn’t work yet and I don’t want to start using some tool to force something and end up breaking something.
  5. Feb 10, 2022 at 4:45 PM
    Jskwelch
    Jim
    2019 Tacoma Ofroad
    What should I be squeezing?
  6. Feb 10, 2022 at 4:48 PM
    316sherm
    South Louisiana
    There's a little clip on the top of the sockets
  7. Feb 10, 2022 at 4:50 PM
    Montana_Actual
    Montana_Actual ;)
    The tab. It's just hard the first time. Use a screwdriver liberally and give it some play. Don't force it! But a flathead should give you the extra play you need. Be patient. Wiggle a lot.
    I will not take bets on them breaking. $10, do I hear $10?
  8. Feb 10, 2022 at 4:50 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    These can be a pain. I use a small screw driver to gently pry the light socket from the connector housing. Do this while squeezing the tab. If you plan on ever doing anything again back there, a tiny dab of dielectric grease on the connector housings works well. Let me see if I have a pic to show where to squeeze
    Montana_Actual likes this.
  9. Feb 10, 2022 at 4:53 PM
    316sherm
    South Louisiana
    Untitled.jpg Try to use your fingers...it's way better than tools. Except for that reverse light connector.
    Kahpo likes this.
  10. Feb 10, 2022 at 4:59 PM
    Jskwelch
    Jim
    2019 Tacoma Ofroad
    Thanks I appreciate the help from everyone.
  11. Feb 10, 2022 at 5:03 PM
    316sherm
    South Louisiana
  12. Feb 10, 2022 at 5:04 PM
    Borracho Loco
    DFW, Texas
    I used a small flat head to release the connector tab. I remember a few of them were VERY tough, I think it was the reverse lights?
  13. Feb 10, 2022 at 5:04 PM
    caribe makaira
    Caribbean, Puerto Rico
    Yes and careful with the locking tab.
  14. Feb 10, 2022 at 5:17 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Air hammer?
    Puppypunter and Montana_Actual like this.
  15. Feb 10, 2022 at 7:57 PM
    Jskwelch
    Jim
    2019 Tacoma Ofroad
    I walked away from it for now. Tomorrow if can’t figure it out I will take brother in law a former Toyota mechanic who can fix just about anything.
  16. Feb 10, 2022 at 9:01 PM
    Jskwelch
    Jim
    2019 Tacoma Ofroad
    I was able to get them disconnected and reconnected and now lights are installed. I used a little WD40 and just like that they removed super easy. Tough little buggers but in the end I was successful. Thanks for your help.
    Kahpo and Montana_Actual like this.
