Tail light sockets
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yota_Ivan, Feb 10, 2019.
  1. Feb 10, 2019 at 5:06 PM
    Yota_Ivan
    Yota_Ivan [OP] Geaux Tigers!
    Arlington, TX
    2006 Tacoma DCLB 4x4 TRD Sport
    A little bit of this, a little bit of that...
    Are the tail light sockets an Toyota part available to order? I was changing my incandescents for LED and the small clips inside a couple of the sockets broke off.
    Edit: Seems they could be. Does someone have the P/N readily available.
  2. Feb 10, 2019 at 5:24 PM
    caribe makaira
    Caribbean, Puerto Rico
    81555-04150 Right Side
    81561-04150 Left Side
    TnShooter likes this.
  3. Feb 10, 2019 at 5:42 PM
    Yota_Ivan
    Arlington, TX
    Gracias!
  4. May 4, 2021 at 8:56 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    I could be wrong but it seems 81555-04150 is good for both left & right sides. 2nd P/N provided by @caribe makaira is for the actual lens assembly and not a harness. Does this sound right to you all? I'm working through a similar issue and just want to make sure I get the right parts (and that future people searching TacomaWorld get accurate details). Thanks!
  5. May 4, 2021 at 9:08 AM
    caribe makaira
    wi_taco[QUOTED] likes this.
  6. May 4, 2021 at 9:18 AM
    wi_taco
    Adam
    SE Wisconsin
    Thanks for the update, that does appear to confirm 81555-04150 is correct for both left & right sides. Your original comment said "81561-04150 Left Side" which seems to be a typo. Cheers, thanks for the info!\
    Edit 05/10/21: Confirmed the 81555-04150 work for both left & right sides. Allowed me to install aftermarket LED tail lights.
