Tail light mod (both lights used as brake and signals)?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chris.taco.2016, Jan 22, 2017.
  1. Jan 22, 2017 at 10:21 PM
    Chris.taco.2016
    Chris.taco.2016 [OP] Well-Known Member
    2016 Tacoma trd sport mgm dclb
    has anyone done a wiring mod so both lights in the tail lights work as a signal and both light up when braking instead of just the bottom section I'm sure visibility would be better and aestheticly look better.
    PvilleJohn, ToyoDrew and Kilokato like this.
  2. Jan 22, 2017 at 10:33 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I hate our tail lights.
  3. Jan 23, 2017 at 7:25 AM
    Optimaltaco
    Optimaltaco Well-Known Member
    Dave
    Cochrane, AB
    '17 Tacoma DCSB TRD Off-Road
    TRD Pro - Grill and Rear Tail-Lights OEM Roof Rack FN overland 17x8.5” -6 BFG KO2 Morimoto 2 stroke LED headlights 30” auxbeam light bar Custom built Canopy Readylift 3" spacer kit Deaver 1.5-2" AAL Amber hazard strobe lighting
    Should be simple enough, just need to create a jumper wire that taps the signal lights and brake lights together. once it gets warmer here I might give it a go.
  4. Jan 23, 2017 at 8:13 AM
    Pickupman2007
    Pickupman2007 Well-Known Member
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    2020 Tacoma: Morimoto xB LED Headlights & fogs, MESO Total Tail S1, Fortin Evo One Remote Start, OEM Audio Plus System 500Q,, Redarc trailer brake controller, Carplay2Air wireless adapter, Custom shift knob, Electric tailgate lock, Chrome tailgate inserts, Limited fog light bezels, 2018 TRDOR Grill, Chrome door handle covers
    I wired mine so both bulbs are brake lights and replaced the clear back up bulbs with amber ones for turn signals. Also installed new backup lights under the bumper. Doing this was less wiring than combining them. You can not just wire them together as the brake would override the turm signal, so you would have to use a trailer light converter or wire your lights to the towing harness. To do what I did you would need to disconnect the backup wire and run it to other lighs, cut the signal wire off the signal socket and connect to the backup socket amd then splice the original signal socket to the brake light socket.
  5. Jan 23, 2017 at 10:13 AM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    What amber bulb did you use?
  6. Jan 23, 2017 at 11:17 AM
    Pickupman2007
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    921NA
    PvilleJohn and Siblue[QUOTED] like this.
  7. Jan 23, 2017 at 11:27 AM
    Camel89
    Camel89 Well-Known Member
    Houston, TX
    2016 TRD OR 4x4
    Any pics of the new backup lights? I was thinking of doing the same thing.
  8. Jan 23, 2017 at 11:28 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    I'm sure if a wreck happened and somehow this was caught, it would be your fault
    PvilleJohn and Joe23 like this.
  9. Jan 23, 2017 at 11:37 AM
    FiaCobra
    FiaCobra Well-Known Member
    I'm not buying that. As long as his truck passes State Inspection, he should be good to go.
    Mushu, remgu2000, Blais03 and 2 others like this.
  10. Jan 23, 2017 at 11:46 AM
    Camel89
    Houston, TX
    2016 TRD OR 4x4
    Are you referring to the OP? The problem I see with that is you would need dual filament bulbs for both turn signals and brakes.
    PvilleJohn likes this.
  11. Jan 23, 2017 at 12:41 PM
    Pickupman2007
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    Also video:
    https://youtu.be/V8h_zh8uPd4
    This was a sunny day and all brake lights on.
  12. Jan 23, 2017 at 12:46 PM
    Outlier
    Outlier I get around...
    Dallas GA
    2016 Tacoma AC TRD OR 4x4 V6 Slushbox
    No BRO-ness to speak of... Well, except Kbro2's
    This.
  13. Jan 23, 2017 at 1:23 PM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    2016 SR5 Access Cab V6 Auto 4wd
    Limited wheels, extra rope hooks in bed.
    I'd buy a kit to convert the whole light to brake lights
    Then just have the entire light blink for turn signals.
    I like our tail lights but not the way they halfway light up when applying the brakes.
  14. Jan 23, 2017 at 1:24 PM
    MESO
    State of Jefferson
    I debated about using an amber 921bulb(in reverse socket) and relocating Reverse lights to under bumper. But they just look tacky hanging there(IMO).
    The ultimate way is to run a set of Switchback Amber/White (will require some minor modifications to bulb socket)
    I went from; OEM reverse lights(SUCK)----->Led white 921 bulb(OK)--->V3 tritton(HOLY CRAP). Reverse is literally a spot light(the chrome reverse housing helps alot with projecting the light out)
    I can tell a huge difference looking through the backup camera during night.
  15. Jan 23, 2017 at 5:05 PM
    Chris.taco.2016
    That's literally what I want and why I posted this thread I wanna know what to splice to do this
    Kilokato[QUOTED] likes this.
  16. Jan 23, 2017 at 5:06 PM
    Chris.taco.2016
    Yes all I would think you would need is a dual filiment for the the running light bulb
  17. Jan 23, 2017 at 5:21 PM
    MESO
    State of Jefferson
    ^ I think the problem that you are going to encounter when trying to make both lights the same,
    is that you have THREE circuits(parking,brake,turn), and only a DUAL filament bulb.
    For instance, what if your turn signal is on, and you are applying the brakes??
    Both lights would be completely solid. And if you did get them to flash, how will I see your brake light?
    Best way:: put the turn down in the reverse bucket, and use the upper section for Running light/Brake.:cheers:
  18. Jan 23, 2017 at 6:13 PM
    Pickupman2007
    Kenneth
    Murfreesboro, TN
    2022 Rivian R1T
    From the factory both the turn signal and brake lights are dual filament bulbs, just wired separately. Combining the signals is the issue, just like wiring a truck with amber signals to a trailer.
    The Tacoma already has wiring with the combined signal if it has the factory trailer tow wiring. To use this you would run the left side off the violet wire from the trailer harness to the yellow and the light blue wires on the turn signal and brake light sockets and on the right side the the light blue wire from the trailer harness to the blue and light blue wires on the brake and turn signal sockets.
    If you don't have or don't want to use the trailer harness then the same could be done with a trailer light converter available at any auto parts store. it would be wired as follows: on the input side of the converter: yellow wire on left side of truck to yellow, light blue wire from right side of truck to green, light blue wire from left side to red, white wire with black stripe to white. Then from the converter output: yellow to both left side sockets and green to both right side sockets.
  19. Feb 3, 2017 at 5:40 PM
    Siblue
    So Cal
    25 Tundra TRD pro
    Here is my take on this mod. I used tail as turn diy from diode dynamics to make this possible. I forgot I had this originally for my TLX. Diode dynamics noted in an email that I must use LEDs not incondesent bulbs. I purchased two sets of philips 7443 red and used universal resistors to prevent hyper flash.
    I'll try to upload a video.
    https://www.diodedynamics.com/store...1872/s/tail-as-turn-module-diy/category/1441/
    Can someone show me how to upload video?
    taco2018x and r_to_the_k like this.
  20. Feb 3, 2017 at 6:04 PM
    9TRDTCO
    9TRDTCO Well-Known Member
    Upload it to YouTube then post the link
    Siblue[QUOTED] likes this.
