Tail light lense replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by John1234, Apr 8, 2024.
  1. Apr 8, 2024 at 5:17 PM
    John1234
    John1234 [OP] Member
    Back again lol, I have a 2009 regular cab Tacoma, only realized after that I have one red and one white tail light. I’m wondering if I can get just the lense to make them match; because it’s not worth buying a whole new one and besides the color they’re pretty much the same. It looks like one of them already had a lease replacement, and the other one’s cracked anyway. Any tips or links? I inserted pics. I plan on relaxing the white lense
  2. Apr 8, 2024 at 6:17 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Drivers side is older year model not an LED while pass side is correct for 09 and LED stop/tail light. Blinker and backup are bulbs.
    Lenses do not come off unless shattered then junk.
    Buy a new set. Amazon has a lot under 100 for the pair.
    I bought a set of Alziria tail lights for $77 and been working well plug and play for my 09.
  3. Apr 8, 2024 at 6:20 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    You can prob find a matching red replacement for under $20 on eBay
  4. Apr 8, 2024 at 6:41 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Headlight lenses can be replaced, albeit not easily, but with some heat, can be sepearated.
    Tail lights are welded together. You can not replace a tail light lens. You'll need to replace the assembly.
  5. Apr 10, 2024 at 7:04 PM
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    I just poked a hole in my rear passenger tail light (2nd time I’ve done this). As mentioned before tons of cheap options on Amazon for around $75 and that’s for a pair! Id go aftermarket and just check for condensation. Good luck!
  6. Apr 10, 2024 at 7:15 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Like MUDDOG321 said, you have 2 completely different taillights. The driver's side is an old school filament bulb style and the pass side is LED. The cheapest option is to match the older red one by finding one on Craigslist or Ebay. I think you need a separate harness to make it work though. Otherwise, just get a matching set of whatever.
    You can't take them apart. I had an LED go out on mine and thought I could cut it apart and solder in a new one. Nope. Trashed it instead. Don't even try.
  7. Apr 10, 2024 at 9:09 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    One is a halogen. The other is LED.
    You’ll have to replace the whole housing to get them to match.
    Pick the ones you like best and get a replacement set.
  8. Apr 12, 2024 at 12:49 AM
    TacoTuesday1
    FL
    whichever one you want.
    never seen a lens sold for this. Would entail bake in oven to separate butyl.
  9. Apr 12, 2024 at 6:48 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    For OEM tailights this is not correct. OEM taillight lenses are sonic welded to the reflector (melts the 2 plastic parts together), and will not come apart like the headlight assemblies. Maybe some aftermarket parts are different, but the ones in my 2008 are welded together.
    ABA180 and TacoTuesday1[QUOTED] like this.
  10. Apr 12, 2024 at 12:48 PM
    steveo27
    Pittsburgh
    I wish they were butyl.
    gotta cut me to separate the lens.
  11. Apr 12, 2024 at 1:04 PM
    winkel
    Corydon, IN
    Absolutely correct. You won't separate an OEM tail light and get it back together.
  12. Apr 16, 2024 at 11:18 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    n
    I learned this tinkering with mine (which the lens was busted anyways, I just was curious).
    Plus as you said, OP has 2 different kinds in the first place.
    Decide which you like and buy a match, or get a pair and be done with it.
