TAG fuse box
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wrork, Sep 18, 2019.
  1. Sep 18, 2019 at 1:35 PM
    Wrork
    Wrork [OP] New Member
    2002 Black xtra cab
    Does anyone have a wiring diagram for that TAG fuse box that comes with a Leer cap? I need to wire my brake light and my dome light and I don’t know what the six pins at the bottom of the fuse box are for.
  2. Sep 18, 2019 at 1:38 PM
    Bunk Moreland
    Bunk Moreland Well-Known Member
    Bunk
    It's complicated.
  3. Sep 18, 2019 at 1:59 PM
    Wrork
    2002 Black xtra cab
    Thanks Bunk, I appreciate your response, but I read that one already. I’m capable of wiring the third taillight and dome light by tapping into the driver side brake light, but my used Leer cap came with a TAG fuse box which has a 6 pin connector on the bottom. I can use female connectors to slide onto the correct 4 pins (sans the male connector), but I was hoping someone knew which pins did what.
  4. Sep 18, 2019 at 2:30 PM
    Bunk Moreland
    Bunk
    It's complicated.
    The TW search option is janky.
    Google is your friend.
  5. Aug 16, 2021 at 6:36 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Just in case it helps someone.
    TheMonarch likes this.
