TACUNDRA - 5.7L 3URFE swapped 2nd gen project
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikieSwartz, Jan 13, 2019.
Will I end up with a functional 5.7L Tacoma?
  1. Yes. I watched you're video and I have faith in you.
    37.8%
  2. Probably. I mean, you already have a whole Tundra for parts.
    41.1%
  3. Maybe. If you're a Toyota tech and have an engineering degree.
    14.3%
  4. Probably not. If it was possible, other guys would already have it done.
    7.6%
  5. No. You're blowing smoke or you're delusional.
    7.1%
Multiple votes are allowed.
  1. Jan 13, 2019 at 7:19 PM
    MikieSwartz
    MikieSwartz [OP] 5.7L iForce V8 Tacoma : YouTube.com/WhipBash
    Carlisle PA
    Rolled 05 Tacoma 4x4 crew cab "Tacundra" + Rolled 96 Tacoma 4x4 Budget Build
    05 Tacoma: 37" Tires, Method bead-locks, Long Travel, King shocks, Custom fabrication, currently swapping in a 5.7L 3URFE Tundra V8 ! 96 Tacoma: Budget Build Lots of DIY !
    I have the ability to do this AND I just bought a donor truck - a 2007 4x4 5.7L Tundra. I'll be documenting the swap on my YouTube channel.
    This Tacoma was rolled when I bought it. I straightened it up just enough to get glass back in it and get it R-titled. (I'm a function over fashion guy 100%) I removed the DB lift the previous owner had and fabricated my own 3.5" long travel arms with King shocks. I have Method beadlock wheels with 37" tires, RCV front axles, 4.56 gears, and some custom fabbed parts like the high clearance front diff carrier/skid plate and front bumper. I also moved the front cab mounts back a few inches for lots of tire clearance.
    I'm building a GM 14 bolt full floating 6 lug disc brake rear axle for it now - also installing 48" trailing arms and King shocks. I have to get that done first cause the ring/pinion is busted right now. THEN I can start on the 5.7L swap!
    Subscribe to my channel https://www.youtube.com/whiplashdvd and check out my old school videos too! I live in Carlisle PA - Home of some of the largest car shows in the world. And I've been making videos since the early 2000's. Just started the YouTube channel though.
    This is the playlist for the entire truck build:
    https://www.youtube.com/playlist?list=PLU5lR_tbWf0zep_2PlB2nioosQY4ueE7T
  2. Jan 13, 2019 at 7:27 PM
    MikieSwartz
    Carlisle PA
    Some pics of the Tacoma when I first got it. It was rolled and the rear ring and pinion were trashed.
    TRDSport10, lo2hi, Bebop and 5 others like this.
  3. Jan 13, 2019 at 7:36 PM
    MikieSwartz
    Carlisle PA
    Current pics. It gets beat, not babied!
  4. Jan 13, 2019 at 7:42 PM
    darkyota33
    darkyota33 Well-Known Member
    AJ
    Upstate NY
    '05 TRD Sport, 4x4 Manual 6 spd trans, Black.
    Replaced engine with an '07 FJ Cruiser motor. Clutch accumulator deleted. WIP. plan to add new exhaust, cold air intake, URD short throw shifter,
    Just finished pulling the motor from my 05 taco! But just going w a the same engine to replace it. Thought about doing a v8 swap but too expensive for me, and too involved.
    But im sure it can be done and it will be bad ass! Good luck.
    MrKatanga and MikieSwartz[OP] like this.
  5. Jan 13, 2019 at 8:02 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
  6. Jan 13, 2019 at 8:07 PM
    TheDrewster
    TheDrewster Active Member
    This'll be an interesting build.
    MikieSwartz[OP] likes this.
  7. Jan 13, 2019 at 8:09 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Nice! I'm intrigued by the "budget friendly" long travel as well. I've seen these for 1st gens but never in 2nd or 3rd gens
  8. Jan 13, 2019 at 8:22 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Do you plan on making it emissions legal?
    I'm just curious because that sounds like a nightmare trying to integrate all the electronics and emissions etc???
    I've often thought about how this kind of swap would work out !!:thumbsup:
  9. Jan 13, 2019 at 8:28 PM
    Willyummk
    Willyummk Well-Known Member
    Will
    HA TO CA
    2011 DCSB TRD Sport
    :popcorn: Subbed
  10. Jan 13, 2019 at 8:33 PM
    motodude95
    motodude95 Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
    Damn this is cool man. I think you can pull it off
  11. Jan 13, 2019 at 8:45 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    I’m in :popcorn:
  12. Jan 13, 2019 at 9:09 PM
    smw62891
    smw62891 Well-Known Member
    Stephen
    Santa Fe, NM
    09 Tacoma DCSB
    What a build! Can't wait to see this thing come along!
  13. Jan 13, 2019 at 9:35 PM
    Holloman
    Holloman Well-Known Member
    chris
    nor cal Cloverdale
    2016 dcsbTRD OR
    Things and stuff
    @MikieSwartz you obviously have the skill and knowledge to put this thing together so get started and post lots of pics :thumbsup: I have a buddy that’s throwing a 4.7 out of an 05 tundra into an 85 extra cab and I’m wondering if your swap might be a little easier with the computer side of things being that it’s going into a similar year truck. Here is a pic of his.
  14. Jan 13, 2019 at 10:31 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Am really interested in seeing it here but not so much on the youtube channel you are pushing. Hope you keep us updated here.
  15. Jan 13, 2019 at 11:56 PM
    MikieSwartz
    Carlisle PA
    Those 4.0L V6 engines aren't cheap either. I had one rebuilt about 4 years ago because the cheapest one at a junkyard was $2200 at the time. Thanks for the encouragement.
    darkyota33[QUOTED] likes this.
  16. Jan 14, 2019 at 12:03 AM
    MikieSwartz
    Carlisle PA
    It looks like the 05 Tacoma has a similar drive-by-wire pedal as the Tundra. I figure that will be an advantage. The wiring is the most dreadful part. I have a friend here with an 85ish truck he put a 4.3L V8 from a Lexus in. It is pretty sweet.
  17. Jan 14, 2019 at 12:11 AM
    easleycrawler
    easleycrawler Well-Known Member
    Travis
    Easley, South Carolina
    2014 RC Taco 4wd
  18. Jan 14, 2019 at 12:11 AM
    MikieSwartz
    Carlisle PA
    I'm planning to keep the factory Tundra ECU and I'd like to keep it emissions friendly (at first anyway). Definitely sounds like a nightmare, but I'm pretty confident. And after the swap is done, I have a friend that is a very experienced tuner. He can probably tweek the ecu to keep the check engine light off. But where I'm at, we can have emissions exemption if we use the vehicle less than 5,000 miles per year. So I'm not too worried either way.
  19. Jan 14, 2019 at 12:12 AM
    MikieSwartz
    Carlisle PA
    ThankYou!
  20. Jan 14, 2019 at 12:16 AM
    MikieSwartz
    Carlisle PA
    I certainly am pushing my YouTube channel. I just started it a few months ago. My videos will be way more complete and informative, but I will keep updates on here as well.
