Tacomas don't have struts
Discussion in 'Suspension' started by jberry813, Sep 21, 2016.
  1. Sep 21, 2016 at 10:56 AM
    jberry813
    jberry813 [OP] Professional Fluffer Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    The level of suspension misinformation and incorrect verbiage and nomenclature on TW is spreading faster than herpes at ASU. Please educate yourself.
    While they are visually similar, struts and coilovers are two very different things. The term "strut" originates from a MacPherson strut based suspension system. In a traditional MacPherson suspension, components include a lower control arm, a hub/spindle assembly, and a damper/coil assembly (known as a strut) that bolts to the top of hub at the bottom of the strut and attaches to the body or frame buckets at the top of the strut. Note...there is no frame mounted upper control arm with a MacPherson strut suspension. The strut itself is an integral part of the actual suspension pivots and steering. Struts provide vertical and lateral support. If you remove the strut, there is nothing holding the suspension together and the hub and wheels would flop all over the damn place however they see fit. Also the spindle/knuckle takes a significantly larger linear load when compared to a coilover based system as the entire weight of the vehicle is supported by the spindle. In addition, since there is only a single arm, the camber changes much more significantly as the suspension cycles up and down. This is why MacPherson strut based systems are used in vehicles with small amounts of wheel travel.
    In contrast, a coilover (coil over shock) based suspension has both upper and lower control arms/links. The UCA/LCA have outer pivots that attach to the hub and inner pivots off the frame. The coilover itself plays no role in the suspension pivot points. You can remove the entire coilover assembly, and the suspension will pivot and turn exactly as it would with the coilover installed (the truck would just be sitting on it's nuts). The only purpose a coilover serves is to dampen the suspension oscillation (the shock's role), and to set vehicle ride height (the spring's role)...that's it! The double arm geometry allows for less extreme camber change as the suspension cycles. Every single 6 lug Tacoma since inception came from the factory with a coilover based front suspension. Yes...you have coilovers...stock. In addition, coilover does not mean adjustable. It simply means the coil spring surrounds the shock absorber and the assembly is independent of the suspension.
    Now I realize this will probably fall on deaf ears. Typical responses are "tomato tamaato" or "you know what I'm talking about." But then again, why not sound like you actually know what the fuck you are talking about? It's not going to hurt you to sound and be more educated. Its the same contrast with firearm magazines vs. clips.
    Go forth and be educated.
  2. Sep 21, 2016 at 10:58 AM
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    This made me laugh awkwardly on the bus :rofl::rofl:
    Nice post, a good pet peave of mine. Will proceed to post in group text
    NmapFE and The Driver like this.
  3. Sep 21, 2016 at 10:58 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    Nice! :thumbsup: I'm glad to see there are other educated people on here.
    NmapFE and 08tacobear like this.
  4. Sep 21, 2016 at 11:02 AM
    minigrowl
    minigrowl Midwest Ambassador
    Corey
    Indiana
    2004 DCSBTRDORSR5
    full OME lift on Falken AT3W 33s driver mod sockmonkey designed stickers The Warehouse Edition bedsides
    well I learnt somethin
    Benjamin4609 and ramonortiz55 like this.
  5. Sep 21, 2016 at 11:03 AM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
  6. Sep 21, 2016 at 11:11 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    It would be more accurate to say every Tacoma came with upper/lower control arm front suspension and no struts. Early 5-luggers had torsion bars in lieu of coils.
  7. Sep 21, 2016 at 11:14 AM
    LivinLoud
    LivinLoud Miller Latte Advocate
    TJ
    Western mass
    ECOBOOST
    I mean… it’s a Ford, you don’t care
  8. Sep 21, 2016 at 11:16 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    All you need is a driver side lean spacer up front, you twat.
  9. Sep 21, 2016 at 11:17 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    But O'riley has them listed in the system as struts.
    :homer:
  10. Sep 21, 2016 at 11:21 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Touche. I'll change to 6 lugs.
  11. Sep 21, 2016 at 11:22 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Perfect example of a mental midget vendor.
  12. Sep 21, 2016 at 11:24 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Taco 422 likes this.
  13. Sep 21, 2016 at 11:43 AM
    jAndyMendo
    jAndyMendo i eat samiches
    Andy
    San Diego, CA
    2014 TRD 4x4 OR 2016 4Runner fake-TRAIL Edition
    going to add to that original post to include the rears?
  14. Sep 21, 2016 at 11:45 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    No. I've have a better chance curing cancer.
  15. Sep 21, 2016 at 12:06 PM
    stroM-
    stroM- @alteregoadventure
    Santa Rosa, California
    2006 4X4 TRD OR
  16. Sep 21, 2016 at 12:07 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Sometimes you just have to roll with the verbiage.
  17. Sep 21, 2016 at 12:17 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    LOL Yes! Love this post. I hate the magazine vs clip deal as much as you apparently hate the strut vs coil over issue.
    I wonder if this will get a sticky?
  18. Sep 21, 2016 at 12:34 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Hopefully it will so @jberry813 can strut his stuff.
  19. Sep 21, 2016 at 12:56 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Aaaaaaaaaaaaaaand it's a sticky.
    That's the second time I've made something sticky on TW (not including the forever lost UG).
  20. Sep 21, 2016 at 12:58 PM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    So you derived coil goes over the shock from coilover. What took so long
