Tacoma with seat code errors
Discussion in 'New Members' started by pplusent, Jan 2, 2023.
  1. Jan 2, 2023 at 8:49 PM
    pplusent
    pplusent [OP] Member
    Lynn
    2005 x-runner
    None other than removing ground effects and putting usable tires on it.
    I picked up a 2005 2nd gen X-runner for around town use the other day. I pulled the codes and found some I am unfamiliar with. Thought someone may be able to give me some incite.
    codes are:
    B1653 Drivers side seat position sensor
    B1655 Seat belt buckle switch (drivers side)
    B1660 Passenger seat airbag active mode indicator
    I have pulled the seats and all connectors are plugged in, but under the drivers seat there are two loose plugs under the carpet. See pic. I might mention the seat belt light comes on on the dash, but no warning sound and it goes off when the belt is plugged in.IMG_20230102_134907_460.jpg
    Does anyone know what these go to, or maybe if something has been removed that is causing these codes?
    Any help would be appreciated.
  2. Jan 4, 2023 at 9:02 AM
    Tacoma’20
    Tacoma’20 Well-Known Member
    Wincent
    Southern California
    2020 Silver Sky Metallic TRD O.R. 2wd
    Welcome to TacomaWorld, from SoCal! I'm not much help, but hopefully someone chimes in, lol
