Tacoma window rattle
Discussion in '1st Gen. Tacomas (1995-2004)' started by merleinspect, Oct 11, 2017.
  1. Oct 11, 2017 at 1:45 PM
    merleinspect
    merleinspect [OP] New Member
    Toyota Tacoma 2001
    How do I fix a window rattle on my 2001 Tacoma front door window
  2. Oct 11, 2017 at 5:50 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Tighten the bolts on the side of the doors - it connects to the window track.
  3. Oct 11, 2017 at 9:56 PM
    Glamisman
    Glamisman Well-Known Member
    the rear guide can pull the spot welds also.
  4. Oct 11, 2017 at 11:52 PM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
    Yup! My window shook for ever! Removed the door panel, located the noise and it came from the bolts on the side of the door!! Not inside the panel. Just tightened it down and boom no more shaking
  5. Oct 12, 2017 at 8:36 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Doesn't work for me. When I tried to tighten the bolts on the edge of the door they were already tight.
    I noticed that the door lock button (that sticks up through the inner sill) is loose and hits the sill when I'm off-road. One of these days I'll fix it.
    GQ7227 likes this.
  6. Oct 12, 2017 at 5:30 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'd take off the door panel and inspect everything. If the window is the obvious culprit then it should be pretty easy to figure out. Lock components are also sources of rattles in these doors.
    GQ7227 likes this.
  7. Nov 10, 2019 at 12:30 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    ahh, found a good topic thread to start from
    just have this new-to-me rattle while cruising highway or other in town speeds at over 35mph with window partly down
    never chattered ever before like this
    i have power windows if it matters
    so the only know thing i have done is to near thoroughly clean out the inner run channel with qTip and many many squirts of wd40 water resistant silicone spray and continous up and down to work it in real good.
    the reason I did this cleaning was i saw a thread somewhere on how to reduce power window 'chatter' when up and down with buildup in the run channel
    so I went to town as a preventative maintenance to reduce wear on the motor
    and now a whole world of weird stuff initiated
    frustrated...
    i HIGHLY doubt it is the bolts on the sides of the door but one never knows these days
  8. Nov 10, 2019 at 5:29 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Take it apart and look - I'll bet you figure it out. You could drive with the door panel off if you needed to.
  9. Feb 6, 2020 at 9:16 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    so you did not need a new rubber run channel?
    that is what i thought is causing the weird wind rattle in mine with window partway down for fresh air
  10. Feb 6, 2020 at 9:17 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i would not know where to start to take it apart without issue :bananadead:
  11. Feb 6, 2020 at 2:57 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    GQ7227[QUOTED] likes this.
  12. Feb 6, 2020 at 6:54 PM
    07toyota1991
    07toyota1991 Well-Known Member
    1999 Toyota Tacoma Regular Cab 2.7 5spd
    5100's with OME 883, Dakar's, SCS Ray 10, 285/75/16 Cooper STT Pro, LCE header, Magnaflow exhaust, ARE shell, Addicted offroad front plate bumper with Warn VR8S
    I gave that bolt on the side of the door one turn and it snapped off. Can I pull the panel off, redrill, and tap? Or what next
    04Pre_Runner likes this.
  13. Feb 6, 2020 at 8:03 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    I did this on my Tundra the other day. I got a new bolt for the door but have yet to take it's door panel off.
  14. Feb 6, 2020 at 8:16 PM
    Fuergrissa
    Devin
    San Jose
    2000 T4R Limited
    no rubber needed. Few things can cause window rattle, best thing is to get in there and find the source.
  15. Feb 7, 2020 at 8:01 AM
    dimoimo
    dimoimo Member
    Dimo
    03 XCAB SR5 5spd
    My guide tracks were loose inside the door causing this noise. I added some loctite to the bolts after torquing them down and the rattle is gone. Hopefully the loctite will keep it from happening again.
    I also noticed one of the retaining clips for the wiring harness had popped out and the nub was broken off. Might have been me pulling the door card off that caused this, but a zip tie easily took care of that problem
  16. Feb 7, 2020 at 8:08 AM
    skeezix
    Colorado
    1998 Limited
    I downloaded parts 1 thru 4 of the above video but I cannot find parts 5 and up. Any idea where they are?
  17. Feb 7, 2020 at 8:14 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    perhaps this new wireless borescope i got can find a small hole to go in and search for anything loose!
    i have been adjusting the opening size of the window to see if it goes away and if only happens in certain spots
    the motor still sounds and feels good, much better than the power windows i checked out on a for sale tacoma a couple hundred miles away with way less miles but not as old, that one sounded sickly
  18. Feb 7, 2020 at 9:18 AM
    07toyota1991
    I called the dealer and they cannot seem to locate this 10mm bolt I’m in need of
  19. Feb 7, 2020 at 9:42 AM
    dimoimo
    dimoimo Member
    Dimo
    03 XCAB SR5 5spd
  20. Feb 7, 2020 at 10:13 AM
    07toyota1991
    Cool I think it’s that last one actually but wouldn’t know without looking at the diagram. Still trying to decide how to go about putting it back in and if I will have to drill and re tap
