Tacoma Water Proofing
Discussion in '1st Gen. Tacomas (1995-2004)' started by ryanbelfor, May 16, 2018.
  1. May 16, 2018 at 9:15 PM
    ryanbelfor
    ryanbelfor [OP] Member
    1996 Tacoma Base Regular Cab 4x4 Manual
    None, yet...
    Okay, so I recently watched a video from JerryRigEverything where he talked about the off-road capabilities of the 2018 Mercedes-Benz G-Class. One thing that stood out to me was that fact that the car was water proofed. Like, the doors and all the seals were water proof. That got me thinking about my truck. I have taken it in some, somewhat, deep water and did not notice any water seeping in. It also may not have been that deep. What are your experiences with this? Is there something that can be done to make them "water proof?" How well do these trucks hold up to deep water? Want to make sure I don't screw up my truck going in a deep pool.
    Thanks
  2. May 16, 2018 at 9:58 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    If you care about your carpet I wouldn’t go up to the door jam, if you dont care about the inside then just dont go as far as the intake inlet and you will be fine, well actually if you dont have an electric fan then I wouldn’t go deep enough to let the fan hit the water
    Running Board Man likes this.
  3. May 16, 2018 at 10:16 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Or build this...
  4. May 17, 2018 at 12:13 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If you want to explore rivers and Lakes buy a boat
    What good does making the cab water resistant when the under hood electrical items as well as the engine intake are exposed
    Major project to make the engine compartment water tight then figure out a new cooling system
    The deeper the water the more the pressure the better the sealing needs to be
  5. May 17, 2018 at 1:42 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    Alternator and A/C compressor are weak points. Also is the starter. Went deep once, had water come in the cab. Had to take out all the carpet and let it dry in the sun which was a Pita. A/C compressor bearing made terrible noise after, so annoying. Finally had to get it changed because I was worried it would seize. Actually I think my compressor did go... My starter went out a couple weeks after being submerged.
    Btw, most important is you have to extend all your breathers and vents for the diffs, t-case, and transmission..... the first two are easy to flush but the trans.... not fun.
  6. May 17, 2018 at 2:36 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Waterproofing the doors or the engine bay, IMO, is a dumb idea. But I guess if you have a $100k+ 4x4 like the G-class, not getting your carpet wet is a primary concern.
    For people who actually wheel, though, not floating away is a bigger concern, which is what would happen if water is not allowed to get in the cab or engine bay...
    Diff breathers, snorkel, etc... are all you really need. Motors and alternators generally work fine submerged, this is actually how you break in r/c car motors (in a glass of water). What's most damaging to components is all the crap in the water (mud, silt) and corrosion.
    My brother once found a deep hole with his '86 4Runner, front wheels went in, and water got up to the windshield. It ended up sitting for a couple days because he couldn't get a tow. Finally got it out, towed it home, and changed all the fluids. Took a fair amount of cleaning, but everything lasted another 100k miles before I finally killed it (I later bought it form my brother).
    These guys drove a jeep COMPLETELY submerged (12 feet), and mainly all they did was waterproof the switches, and smear dielectric grease in all the plugs, and obviously the snorkels.
    https://www.youtube.com/watch?v=icp2Pb5uoME
    Jay-coma and ryanbelfor[OP] like this.
  7. May 17, 2018 at 2:39 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Fred’s jeep is pretty cool, he actually had a cummings r2.8 in that video, all he water proofed was the small amount if eletrics in the car abd used dye electric grease on all the conections to keep the water out
  8. May 17, 2018 at 2:48 PM
    x2468
    Dye electric grease is a good idea. I went and did every connection I could find.
    Sperrunner[QUOTED] likes this.
  9. May 17, 2018 at 8:15 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    My bad i was tired when i typed that, actually still am tired, I should probably take a nap lol
  10. May 17, 2018 at 8:20 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Do you not see how many grammer mistakes i make on here lol, im tired or at work 24/7 i dont time to re read what i type not do i care lol
  11. May 17, 2018 at 8:26 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I know how to spell it but when you arnt things typing ings which is more common with everyday typing vs ins which you only type when you wanna take abot desiels. Maybe if i was desiel dave i would put ins vs ings all the time
