Tacoma towing capacity
Discussion in '2nd Gen. Tacomas (2005-2015)' started by streetlightning, Nov 7, 2011.
  1. Nov 7, 2011 at 10:05 AM
    streetlightning
    streetlightning [OP] Member
    Denver, CO
    '12 Tacoma TRD T/X Pro
    I thought I'd pass this along as I tow quite a bit with my Tacoma. This '11 Tacoma is my third 2nd generation Tacoma and I really do like these trucks. I have several trailers of my own and two an average of three days a week including my Kubota B2400 tractor. Over the weekend, I hauled a friends Bobcat up to his house in the mountains. I would not recommend towing this much with the Tacoma, but it did it amazingly well. Without getting into detail, the weight exceeded the maximum towing capacity, but careful planning and smooth going made it stress free He understated the size of the Bobcat prior to me picking it up. It went great, but was probably at the very upper limit of the Tacoma. The last time he had the Bobcat hauled up to his place, they used a V10 F250 and it struggled up the hills as well. Again, I don't recommend towing your Bobcat with the Tacoma, but I'm very impressed.
  2. Nov 7, 2011 at 10:10 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    what was your total weight? I pulled a civic on a 1800 pound trailer and it did alright, however stopping was another story without trailer brakes.
  3. Nov 7, 2011 at 12:48 PM
    streetlightning
    Denver, CO
    Bobcat was 5600lbs and the trailer is around 2000lbs. I use that trailer to haul a lot of stuff. Loads like this Suzuki Samurai are no problem other than eating into the fuel mileage. On the highway, its easy to get the Tacoma down to 8-10MPG with a loaded trailer.
  4. Nov 7, 2011 at 12:55 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Yikes. I can see why you're on your 3rd truck in 6 years, I wouldn't want to hang on to it either knowing what the transmission has been through :D
  5. Nov 7, 2011 at 1:15 PM
    n2glock
    n2glock Active Member
    Eddie
    Southern California
    TRD Sport 4x4
    The decision of Toyota to keep installing rear drum brakes is puzzling. I have a 19' jet boat and the trailer has no brakes. Stopping while towing with my Tacoma is definitely an issue. Before my Taco I had a '03 Dakota w/ rear disc brakes and it always stopped fine while towing the boat. I'm gunna have to look into either adding brakes to the trailer and converting the Tacoma over to rear discs.
  6. Nov 7, 2011 at 1:19 PM
    Fiolo
    Fiolo Senior member
    1998 Tacoma, 2022 Tacoma, 2019 L5P Duramax
    Lost track many mods ago
    Impressive but I would probably not do it
  7. Nov 7, 2011 at 1:25 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Good to know! Pretty impressive that it did great, and with the new code on the scangauge that can scan transmission fluid temperature, glad to know I'll be able to pull heavy loads up to the stated 6500lbs rating no problem.
    Stewzz likes this.
  8. Nov 7, 2011 at 1:30 PM
    Pugga
    Massachusetts
    Drums are very strong, no need to convert to discs. Plus, a very large percentage of your braking power is done with the front anyways so you'd be much better off spending your money on upgrading to better pads and rotors on the front vs attempting to convert the rears.
    FWIW, I used to have an issue with the Tacoma's brakes but it seems the older they've gotten, they've either gotten better of I've gotten used to them. I tow pretty frequently now (trailer has no brakes) and have not had an issue stopping.
  9. Nov 7, 2011 at 1:33 PM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    i've towed my s2000 in a 1.5-2 ton dump trailer before. I wouldn't recommend it. these trucks are rating for 6500lb but i honestly don't like towing anything more than my drive-in/out snowmobile trailer and a couple sleds (prob 3500-4000lb).
  10. Nov 7, 2011 at 1:33 PM
    streetlightning
    Denver, CO
    Pugga - I haven't worn out any of the Tacomas yet. I haven't even changed brake pads on any of the three. Just tires. The '06 was a six speed extra cab which I traded for an '08 automatic double cab for space reasons. I traded the '08 for a Dodge Cummins 4X4 which I had problems with from the start and only had for 7 weeks before going back to a Tacoma. I will say, the US built (California) Tacomas seemed better than the 2011 one I have that was built in Mexico. My bad for getting a Dodge in the middle of things as I lost a lot of money on it, but the Tacomas have been great. It would be awesome if we could get one with the 4cyl diesel. I've been looking into getting an engine from Costa Rica for the future.
  11. Nov 7, 2011 at 1:36 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I towed fully loaded 20' 2axle trailer without brakes from Phoenix to Cali and back. The Tacoma did ok, I didnt go more than 65mph, to avoid revving at 4k rpm and constantly gear searching on the hills. The worst part was the gas mileage... 8-10mpg :eek:
  12. Nov 7, 2011 at 1:36 PM
    Pugga
    Massachusetts
    I'm just giving you a hard time... check this out if you're serious about a diesel conversion. It's expensive and if you weigh it out, you might be better off importing from Costa Rica if you can get all the paper work cleared to make it street legal here.
    http://www.dieseltoyz.com/
  13. Nov 7, 2011 at 1:38 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Because the rear brakes don't do very much. When you stop all the inertia carries towards the front of the truck, and the front brakes do the majority of the work. For the minimal gain you'll see in stopping power, it's not worth the greater initial cost (at least to Toyota).
  14. Nov 7, 2011 at 3:20 PM
    Rick323
    Rick323 Well-Known Member
    Northeast, Pa
    05 trd off road
    Nice!!
    I hauled 7000#+ loads quite a few times, never had a problem. It's the only time I use 4th gear (the manual trany is spaced nicely for towing). I never had a hard time stopping my trailer brakes work well.
  15. Nov 7, 2011 at 4:30 PM
    upcountry
    upcountry Active Member
    Seattle
    07 Tacoma
    Isn't it illegal to exceed to rating???? Just saying......
  16. Nov 7, 2011 at 7:16 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    If only.....but you are way off. When towing anything with a tongue weight of more than 350#, there is as much, if not more weight on the rear axle than on the front. (as measured on a highway scale) That means the drums are trying to do more of the stopping than the front discs. The crapulance of rear drums isn't very apparent in normal driving, but while towing or hauling, that are definitely an issue. And a huge safety issue for folks who are overloading their trucks.
  17. Nov 7, 2011 at 7:30 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Physics says otherwise. Just because the weight is above the rear axle doesn't mean the rear drums are doing the majority of the stopping. Yes, it will be harder to stop with a trailer...but that is true whether the rear wheels are being stopped by disc brakes or drums.
  18. Nov 7, 2011 at 7:37 PM
    Isthatahemi
    TRD OFF ROAD
    Have you considered that the weight of the trailer transfers froward to the rear axle of the truck? And if you are towing 7000#, there is more weight transferring from trailer to rear axle, than the very slight amount of transfer forward from a low G stop. The Tacoma has automatic brake porportioning, so the braking force will be biased to the rear, as under a full braking situation it will use all available traction, which will be more abundant at the rear tires, which consequently have less braking force than the front discs.
    Physics actually explain why you are incorrect, sorry.
  19. Nov 7, 2011 at 7:44 PM
    BLUVVV
    BLUVVV LARGE Member
    Bryce
    Valley Center, CA
    11' A/C TRD O-R PreRunner
    flowmaster 40, blackout headlights, 10'' infinity subwoofer, custom rear enclosure, kicker mono amp. 5100's set at 2.5'', 32'' pro Comp Xtreme M/T tires, Pioneer dub din head unit, K&N CAI, MB Motorsports V-Drive rims
    this is probably the most I have towed with my Tacoma... 14' trailer with a quad and RZR full of gas... not sure how much it weighed but had no problem going or stopping!
  20. Nov 7, 2011 at 8:35 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Yes, rear brakes have to do some more work when towing, but the front brakes still do the majority of the work. The Tacoma (or any other vehicle) is a rigid body and the inertia carries through the entire structure. When you brake hard, the front of the vehicle dives downwards whether the vehicle is loaded or unloaded. This causes a lot of downward force on the front tires, which gives them plenty of traction. Consequently, as the front dives, the rear is lifted slightly, reducing traction.
    Additionally, the trailers that we're talking about also have trailer brakes, which drastically reduce the amount of work that both sets of brakes on the vehicle have to do. There is a reason why semi's use drum brakes.
    And this is only true with a properly loaded trailer, and one that is within the tow capacity of the Tacoma. (Not 7000 lbs.)
