Tacoma Tool Box
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12PM4X4OR, Aug 17, 2013.
  1. Aug 21, 2013 at 11:56 AM
    jameskhana
    jameskhana Maibatsu Monstrosity
    James
    Dallas, TX
    2007 DCSB Base 4x4 6spd
  2. Aug 22, 2013 at 4:27 AM
    12PM4X4OR
    12PM4X4OR [OP] Nip it in the bud!
    Fife
    Wanna wax the steps @ the old folks home?
    none
    Oops on the wheel wells. Major oversight on my part!:eek:
  3. Aug 22, 2013 at 4:42 PM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    The husky does not have gull wing doors, but its only $159.
  4. Aug 22, 2013 at 4:44 PM
    12DblCab
    12DblCab I don't know what to write here
    South
    2012 DCSB TRD Sport "Pyrite Mica"
    I need to go take some cool pics of my truck instead of random ones while I'm bored lol.
  5. Aug 22, 2013 at 4:51 PM
    12DblCab
    South
    The toolbox should come with slits inside of it where you would put the J-bolts to hook under the bed caps. You put a washer and nut on the J-bolt inside of the toolbox so it can't be loosened or stolen from outside of the toolbox. I marked where the J-hooks were touching under my rails (the rail where the tie downs move around) with a permanent marker. Then I took off the rails (only a few screws) and drilled holes there so the J-hooks would grab after I re-installed them.
    The Kobalt boxes have a little piece you can adjust to make the lid tighter after it latches. The metal is a little more flimsy than some more expensive toolboxes, but I'm pretty happy with the locks.
    My closest Lowe's couldn't order the black one because it was possibly discontinued. I ended up calling around to the different Lowe's in my area, and one store had a few of them while the other stores had none. You just have to ask around.
    TacoGuy1995 likes this.
  6. Aug 22, 2013 at 6:09 PM
    East TN Yota
    East TN Yota Well-Known Member
    TN
    06 Tundra
    ^ I replaced the hex nuts with wing nuts, so I could remove it quick if I needed to.
    Ive had Husky, Delta, and Tractor Supply Co. The shocks went out on the Delta very quickly. The Husky held up pretty well. The best quality in my opinion was the Tractor Supply box. It is made by DeeZee. They just put the TSC badge on it.
  7. Aug 22, 2013 at 7:05 PM
    jameskhana
    James
    Dallas, TX
    Got it - thanks!
  8. Sep 2, 2013 at 8:00 AM
    EvilRick
    EvilRick New Member
    Would you mind posting a close-up of the rail attached to your box. (Not a euphemism).
  9. Sep 2, 2013 at 2:19 PM
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    Here ya go.I used the original bolts that held the rail on the bed. I just drilled holes in the box,and used nuts to attach the bolts and then ground the bolts down on the inside of the box.
    KeokiLK likes this.
  10. Sep 2, 2013 at 3:55 PM
    GuapOh
    GuapOh Well-Known Member
    Nor Cal
    2011 SR5 4x4 MT
    Skid Plate, Hood Protector, Wheel Locks, Snugtop XV, Yakima Rack, Weathertechs, Sick Speed Shifter, Avid Bumper, Avid Sliders, Bilstien 5100's, TSB Spring packs
    Here is my preferred solution. Perfect for hand tools and shooting supplies.
    toopoortobecool likes this.
  11. Sep 2, 2013 at 6:05 PM
    EvilRick
    EvilRick New Member
    You rock. TYVM.
  12. Apr 26, 2015 at 5:31 PM
    SprtBkr
    SprtBkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 5.7L Double Cab 4x4 Inferno
    Haha. Kobalt is from Lowe's. They discontinued the black one for midsize trucks. Only silver now. :(
  13. Apr 27, 2015 at 9:19 AM
    TRDMountaineer
    TRDMountaineer Well-Known Member
    Ripley, WV
    2015 AC TRD Sport MGM 6-spd S/C
    TRD S/C, aFe Stage-2 Intake, Magnaflow 15315, Leer 100XQ w/ Tracker II Rack, General AT2 265/70R17, OEM skid, TRD FJ caps, Wet Okole Realtree seat covers, TRD grey shift knob, Weathertech floorliners, Weathertech window visors, Salex glove box+console organizers, Grid-It console lid mod, Lamin-X amber fogs, Craven Speed A-pillar phone mount, Debadged
    Toyota OEM found on Craigslist. I'm planning on painting the entire thing black, since the aluminum on top has some corrosion and the clear coat is peeling.
    SprtBkr likes this.
  14. Apr 27, 2015 at 9:26 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    I found a good used one on CL locally for $100. I bought some DeeZee brackets to mount it to the rails. It was silver, I cleaned it and plastidipped it, turned out great IMO.
  15. Apr 27, 2015 at 9:51 AM
    #35
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    This is a Lund Challenger I got from JC Whitney - on sale with no shipping - but can't find receipt. Removed the front bed tie-down rail and replaced it with a piece of square steel tubing - then re-fitted that rail to the tool box rear. The tiny J-bolts (2) that came with the tool box were a bad joke so I replaced them with longer 5/16 J's from Ace Hardware - they engage the heavy duty hold downs at the front corner of the truck bed. Reinforced the toolbox at the J clamp holes with pieces of steel flat bar inside the box. Space inside is small - I was used to a big box and really had to down/size the amount of stuff "I couldn't live without".
    airrage likes this.
  16. Feb 26, 2018 at 8:03 PM
    #36
    TacoMedic214
    TacoMedic214 Next Level Tactical.
    christopher
    NY
    2016 Quicksand DCOR
    K/n air filter... Silverstar lights so far, Rear bumper, TRD Exhaust, Wildpeak AT
    So will this work without changing factory equipment, I dont want to drill through my truck because of salt and Rust
  17. Feb 26, 2018 at 8:05 PM
    #37
    TacoMedic214
    christopher
    NY
    2016 Quicksand DCOR
    Im currently looking for a Box, with a easy install. Any help would be great, I do want black. The slim line ones look amazing
  18. Feb 26, 2018 at 8:28 PM
    #38
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
  19. Feb 27, 2018 at 10:43 AM
    #39
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Can also mount box using bed rail tie down by cutting off tips .Wholes line up with kolbalt toolbox perfect.
    Yotabilly and JGO like this.
  20. Apr 5, 2018 at 6:39 AM
    #40
    jay0689
    jay0689 Member
    josh
    2014 grey double cab long bed trd sport
    bilstein 5100 icon 1.5 progressive add a leaf
    will a 60 inch angled uws toolbox fit on a 2nd gen any help with this much appreciated
