Tacoma Super Duty Transmission Mount
Discussion in '4x Innovations' started by traxman25, May 17, 2010.
  1. May 17, 2010 at 7:21 AM
    traxman25
    traxman25 [OP] 4x Innovations Vendor
    Adam
    Platteville Wi
    Too Many!
    4x Innovations has created the first true super duty transfer case/transmission mount for Toyota Tacomas! In this new mount the soft, weak, stock rubber portion of the stock mount is replaced with quality Energy Suspension poly round bushings. These bushings will not split and fail on you, relieving you of such worries associated with stock mounts. They are also strong enough to handle the worst conditions while eliminating your transmission and transfer case shifter slap. Your new mount comes with thicker steel plates that are laser cut and CNC formed for the best fit possible. This mount is a direct replacement. You can even run this mount with after market cross members that reuse the Toyota rubber mount.
    As if all that wasn’t enough, there’s another trick feature to this mount. If you need remove your transfer case or transmission you now only need to remove two bolts from the bushings to pull the cross member down, not the 4, hard to get to, bolts that engage in the cross member.
    Tacoma transmission and transfer case mounts fit 95.5-04 Tacomas with 6 cylinder engine and manual transmission (R150F). They come bare steel ready to paint and install. They are $99 plus shipping.
    To order please either call us or click over to 4xInnovations.com and use the online shopping options.
    Biscuits and ChadsPride like this.
  2. Jun 11, 2010 at 3:25 PM
    traxman25
    Adam
    Platteville Wi
    Too Many!
    I finally have a limited amount of these in stock and ready to ship! Order yours today so it can ship Monday morning!
    ChadsPride likes this.
  3. Oct 14, 2010 at 8:34 AM
    traxman25
    Adam
    Platteville Wi
    Too Many!
    I have these in stock and ready to go!
  4. Apr 13, 2011 at 5:36 AM
    traxman25
    Adam
    Platteville Wi
    Too Many!
    These are in stock and ready to ship!
  5. May 22, 2011 at 2:02 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    Do you have one for a 2007 Tacoma (access cab) 4x4 automatic trans?
    hresendiz25 and ChadsPride like this.
  6. May 25, 2011 at 3:51 PM
    traxman25
    Adam
    Platteville Wi
    Too Many!
  7. Oct 19, 2014 at 1:56 PM
    pnwtaco
    pnwtaco Well-Known Member
    Taylor
    Bellingham, WA
    95 3.4 manual 4x4
    Bilstein 5100's, Pro Comp alloy rims with 33" Duratracs
    Just ordered mine! cant wait to get it on the truck, the rubber in my stock mounts are so weak that the trans/tcase is easily movable by hand.
  8. Oct 20, 2014 at 6:23 AM
    traxman25
    Adam
    Platteville Wi
    Too Many!
    Thanks for your order Taylor. It'll go out today and I'll send you tracking info once it ships.
  9. Dec 9, 2014 at 7:23 AM
    traxman25
    Adam
    Platteville Wi
    Too Many!
    We have these back in stock and ready to ship!
    ChadsPride and 06HAOLE like this.
  10. Sep 26, 2015 at 11:17 AM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Do you still make these? I couldnt find them on your website? I am ready to buy.
  11. Sep 26, 2015 at 11:20 AM
    traxman25
    Adam
    Platteville Wi
    Too Many!
    Yes we do and they are in stock. Looks like the link in the op was broken. It is now fixed.
  12. Sep 26, 2015 at 11:39 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    these mounts are amazing...i love mine and ive put it through some serious abuse!
  13. Sep 26, 2015 at 1:00 PM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    will these fit 2nd gens?
  14. Sep 26, 2015 at 1:08 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    Thanks for the fast response but I'm still confused if this works for my application. I have a 2.7L, 5 speed, 4wd Tacoma. Will it work for my truck? Im ready to buy.
    Your top post in this thread says:
    Tacoma transmission and transfer case mounts fit 95.5-04 Tacomas with 4 cylinder manual transmission and 6 cylinder manual
    The product info says on your site says:
    They do not fit anything not listed above, or the following:
    ANY 2wd transmission.
    W59 (3RZ-FE - 4 cylinder engine 4wd manual transmission)
    A43D 2wd automatic transmission 2RZ-FE.
    A340E A340F (3RZ-FE and 5VZ-FE 2wd or 4wd automatic)
  15. Sep 28, 2015 at 1:06 PM
    traxman25
    Adam
    Platteville Wi
    Too Many!
    These are for the R150F manual trans that comes behind the 5VZ-FE 6 cylinder engine only. They do not fit any other application.
  16. Sep 28, 2015 at 2:05 PM
    06HAOLE
    Fort Worth, TX
    2019 Ford Raptor
    Thanks man. I appreciate the help. I will be ordering some sliders from you when I get back from deployment.
  17. Sep 8, 2016 at 5:51 AM
    iyapysnf
    iyapysnf Well-Known Member
    2016 DC OR M/T
    Any plans for a mount for the 2016 Tacomas?
    crigg93 and hresendiz25 like this.
  18. Sep 8, 2016 at 6:29 AM
    traxman25
    Adam
    Platteville Wi
    Too Many!
    Not at this time.
  19. Apr 5, 2017 at 9:52 PM
    ChrisKugel
    ChrisKugel Member
    Orange County
    2009 TRD Off-Road 4x4 6speed
    Wondering if you guys have made a mount for an 09 v6 6spd 4wheel
  20. Apr 18, 2017 at 6:38 PM
    traxman25
    Adam
    Platteville Wi
    Too Many!
    Just for the 1st gens, sorry.
