Tacoma Racing Seats Photos - Recaro, Corbeau, Sparco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kiteboarder, Oct 31, 2011.
  1. Oct 31, 2011 at 12:29 PM
    kiteboarder
    kiteboarder [OP] Well-Known Member
    Danny
    SoCal
    I drive stick. Only.
    To come.
    Has anybody replaced the stock seats with racing seats such as Recaro, Corbeau, Sparco or other?
    If so, what's your experience with them AND... Post photos here.
    These are not mine (They are Dutch's I think), but searching around the forum I found them. They gave me the idea to consider them, instead of Katzkins. We'll see, after some research and budget-making.
  2. Oct 31, 2011 at 12:34 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Throwing this out there before things really get rolling -- if you install a 4- or 5-point harness in your truck, you *must* install at least a roll cage main hoop.
    The stock belts allow you to lean sideways in the event of a rollover. With a harness you're locked upright and are screwed if your truck rolls and you have no cage.
    That said...proceed. :)
    predikt, SocalTaco15 and Elevated like this.
  3. Oct 31, 2011 at 12:40 PM
    kiteboarder
    Danny
    SoCal
    To come.
    Makes sense, mjp2 - But if I go the racing seats route, they'll be more "mellow" racing seats. You can obviously get hardcore 4 point or 5 point seats like the ones above, but the racing seats companies also sell less "racy" models that have the looks and performance, and are compatible with various styles of seatbelts.
    My thinking is that if Katzkins are going to cost me a little over a grand, getting leather racing seats, while a bit more money, might be a better option.
  4. Oct 31, 2011 at 12:46 PM
    kiteboarder
    Danny
    SoCal
    To come.
  5. Oct 31, 2011 at 12:58 PM
    DPR921
    DPR921 Well-Known Member
    Dylan
    Cheshire, MA
    08 SR5 4x4 2.7
    Also a roll cage is a smart idea to properly mount the seat belts, its better to mount them at a 0 degree angle rather than a 45 degree..
  6. Oct 31, 2011 at 1:08 PM
    mjp2
    NJ
    You can go full bore racing seats (I had Corbeau CR1s in an F150 years ago) without a cage as long as you stick with the factory seatbelts. Obviously some will fit better than others, but most any of the reclining seats will work nicely with the stock belts.
    Simply by their design most fixed-back seats will tend to keep the belt off of you, which isn't ideal or even all that safe, but then a fixed-back seat would generally only go in a purpose-built vehicle anyway so it's not much of a concern.
    Just making sure folks stay safe out there. :thumbsup:
    My personal preference is for the CR1 seats. Fantastic support, great looks, and very, very comfortable on even the longest drives. I swapped them in when I commuted 150 miles a day and had severe back pain from the stock seats. They took care of that in no time!
  7. Oct 31, 2011 at 1:47 PM
    kiteboarder
    Danny
    SoCal
    To come.
    @mjp2 - Thanks! That's a lot of really good info right there.
    You seem to know what you are talking about, so I'm going to ask you this...
    1. When wearing a 5-point belt system for example, is a steering wheel airbag redundant? Or is it still good to have?
    2. When replacing the stock seats with racing seats yet keeping stock seatbelts, losing the seat airbags might not be a good idea. Right? Not having seat airbags means a 4 or 5 point harness is better (which then means you should have a roll bar too).
  8. Oct 31, 2011 at 1:50 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    like mjp2 said dont do a 4 or 5pt harness unless you have a cage.
    it is more dangerous to have a 4pt or 5pt in a non caged truck than to have a normal seatbelt
  9. Oct 31, 2011 at 1:51 PM
    awoit
    awoit Well-Known Member
    CA
    08 TRD, SR5
    subd :popcorn:
  10. Oct 31, 2011 at 1:52 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Airbags and five points are counter productive. You're not going anywhere when properly belted into a five point and the air bag is basically just going to give you a solid punch to the face.
    If you keep the stock seat belts to use on pavement, you might want to consider keeping the airbag and just dealing with the punch to the face if you end up deploying it offroad while wearing a harness.
  11. Oct 31, 2011 at 1:53 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I need something like those in my truck.
  12. Oct 31, 2011 at 1:55 PM
    kiteboarder
    Danny
    SoCal
    To come.
  13. Oct 31, 2011 at 1:59 PM
    97yota4wd
    Eric
    Mesa, AZ
    that "3 point" one is still technically a 4 point
  14. Nov 1, 2011 at 7:47 AM
    mjp2
    NJ
    Definitely redundant, but amusing if it does happen to go off. When I blew mine last year it never touched me. I just turned to my co-driver and said "So that's what that's like. I've never had an airbag go off before." while laughing.
    Losing the side impact airbag will mean you're in the same boat as most vehicles on the road. Not a big deal to me but it's your call. Note that the airbag light on the dash will most likely remain lit.
    And as stated above, that 3-point harness is essentially a 4-point. Anything that keeps you pinned upright is a no-no unless you're caged.
  15. Nov 1, 2011 at 8:39 AM
    GTABurnout
    GTABurnout Well-Known Member
    Tucson AZ
    2012 Tundra Crewmax Rock Warrior TRD SC
    Icons, TRD Supercharger, TRD Exhaust, TRD Intake
    mjp2, has pointed out most the issues. It kills me to see street cars with 4/5 point seat belts and race seats.
    Also remember fixed back seats are just as bad as harness if you don't have a cage.
    Coming from the faster street car world there is also a lot of discussion of a roll cage in a street car/truck. A simple fender bender can result in a huge issue should your head contact a cage with out a helmet on.
  16. Nov 1, 2011 at 9:35 AM
    kiteboarder
    Danny
    SoCal
    To come.
    Oh, I've had an airbag go off and break my thumb! And bruise my face. :s
    This is a great discussion. As far as what to do with my soon-coming truck I think I'm going to stick with the stock seats and re-upholster them with Katzkin. I did a bunch of research yesterday and compared the pros and cons.
    While I liked seats like the Corbeau CR1's, I ran the numbers and after buying the seats, seat brackets and re-upholstering the back seats to somewhat match, I'm looking at easily twice the price of a high-end Katzkin setup. Apart from the fact that I can't benefit from a harness (no cage) and I'll lose the side airbags.
    So maybe the CR1's might be more comfortable and supportive than the stock seats, and they might look cooler, but that's about it. Not worth twice the price to me at this stage.
    For my purposes, I think the stock seats leather upholstery will do the trick.
  17. Nov 1, 2011 at 9:44 AM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    Go with Katzkins man, Racing seats are cool but leather is class. ;)
    TacoTuesday!! likes this.
  18. Nov 1, 2011 at 9:49 AM
    ColdSteelTiger
    ColdSteelTiger Well-Known Member
    Seats are sweet but my stock seats have airbags
  19. Nov 1, 2011 at 9:54 AM
    kiteboarder
    Danny
    SoCal
    To come.
    By the way... For all those interested, Recaro sells seats with side airbags. Of course, they cost 3 times as much as the Corbeaus.
  20. Nov 1, 2011 at 11:27 AM
    ColdSteelTiger
    how much is that and can u please provide link
