Tacoma offroad model tire pressure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by taokieboater, Oct 31, 2023.
  1. Oct 31, 2023 at 10:21 AM
    taokieboater
    taokieboater [OP] Member
    I took delivery of my 2023 Tacoma Off road a few months ago.
    Went camping and pretty much loaded it up. Canoes, gear etc.
    It has the standard 265 70 R16 tires.
    Sticker recommends 32 lbs air pressure
    Tires looked pretty much pushed down and I put 40 pounds air in front and back tires.
    Back home, unloaded all the gear.
    Been a few days and I think the truck drives much better at 40 lbs than 32.
    Question for you more experienced Taco owners is: Am I going to hurt anything if I keep the 40 lbs air pressure which is higher than Toyota recommends?
  2. Oct 31, 2023 at 10:26 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^What's max pressure written on the tire sidewall? I seem to remember it's 37 psi, which would mean 40 psi is too high.
  3. Oct 31, 2023 at 10:38 AM
    terryhutchinson
    terryhutchinson Well-Known Member
    Terry
    2023 Tacoma TRD Off Road
    I also have a '23. Same size stock tire - mine are the Wrangler Territories. Door panel says inflate to 30psi all around and the tires show a max inflation pressure of 51 psi. I run mine at 30-32 depending on ourdoor temp. 6000 miles on them and they are wearing evenly.
  4. Oct 31, 2023 at 10:39 AM
    Bishop84
    Bishop84 Well-Known Member
    You'll just burn the center tread for no reason. Loaded 40psi is fine, but drop it back down to 35psi or less for better wear.
    Tires are supposed to squat. Appearances dont matter.
  5. Oct 31, 2023 at 10:44 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    this!
    Overinflated will just oversize the center of the tire,, which to you is probably why it feels better, it has less rolling resistance and less side flex,,, but since it's contact patch is significantly smaller,,, so is the level of traction it can provide.
  6. Oct 31, 2023 at 11:06 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Wear and heat will be an issue and you'll also start running into vibration issues as well. Toyota will generally fill them to 35 PSI in the summer which has them well above that on the roadway. My door sticker says 30 psi when cold. Once I removed the excess air and set them back to what the door sticker says, my vibrations were greatly reduced.
    shakerhood likes this.
  7. Oct 31, 2023 at 11:08 AM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
    Braking performance will suffer when overinflated too. Door pressure is probably where you want to be.
  8. Oct 31, 2023 at 11:14 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    What model do you have that 32 psi is on the door sticker? Long bed or something? I thought all the Off-Roads are 30 psi.
    For the stock tires, you definitely should stick to the sticker pressure. 40 psi is never appropriate on passenger rated tires, to need 40 or more would be LT territory.
    When you change to a different size or load rating, then use a calculator based off of the stock load/size/pressure to calculate what the new tire should be aired to. Appearances of the sidewall don't matter, that is not a metric for properly inflated.
  9. Oct 31, 2023 at 11:53 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    My long bed I am certain says 29 psi
  10. Oct 31, 2023 at 12:40 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    30 psi is the recommended u can run between 32-33 cold . 40 is way to much and will wear out your tires quicker and unevenly. Possible blow out could happen being over inflated . If u are running at 40 cold then when they are warm u will be at 45 -47 depending on speed .
  11. Oct 31, 2023 at 12:55 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    If your tires are rated for 40 or more 40 won't cause a blowout. Low pressure causes more great which can lead to a blowout. High pressure can cause wear issues and possibly less traction.
    Tire pressure depend on many factors, tire construction and load are important. High chance that at least loads are varying across trucks.
  12. Oct 31, 2023 at 1:05 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Chalk test
    Grand Inquisitor likes this.
  13. Oct 31, 2023 at 1:20 PM
    taokieboater
    thanks for the feedback
    I think I will go with 35 psi cold
    BluberryBCtaco likes this.
  14. Oct 31, 2023 at 1:42 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    May even depend on season. AZ summer a "cold 35" can expand to 40 quickly, but in winter may only expand to 37. I just reinflated to 33 cold because it had dropped to 30 cold (through time and some use in light-offroad space that was not supposed to be serious offroad) and my MPGs dropped 1-2. Now at 33 cold it expands to 36-37 in use and MPGs back up.
    Center strip on my tires looking perhaps lower than sides, probably should ask Discount Tire to measure the side-vs-center tread to diagnose the condition of the tires.
  15. Oct 31, 2023 at 3:48 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    "Toyota" has nothing to do with it. It's the place you take it to and it sounds like you're using a dealer. The inflation is usually based on the person using the hose and nothing scientific. Most of those guys don't bother looking at your door jamb sticker neither. Most put too much air in tires and torque wheels way too tight.
    TS4x4 likes this.
  16. Oct 31, 2023 at 3:54 PM
    RedWings44
    Michigan
    Actually Toyota technically does given that I've heard from several users on here (including those who have worked at dealerships) that it is standard practice at the Toyota dealerships to fill to 35 PSI in the summer. I'm aware they don't look at the door sticker or I wouldn't have to let air out of my tires after they've finished performing the service each and every time.
    On the flip side, I drive so much that I'm getting service done about every 2 months and so I can't forget to check my tire pressures.
  17. Oct 31, 2023 at 4:00 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Tire pressure is a function of load. It could be considered as an air spring. The pressure recommended is to ensure load capacity and tire longevity. Over inflation can be just as bad as under inflation causing premature tire failure.
    My Sport recommends 29 psi...
    If you change tire size or load rating, it is important to set the pressure to match the tire...
    Here is a calculator make sure you have the correct pressure
  18. Nov 1, 2023 at 5:12 AM
    Bocephous
    Bocephous Unvaxxed Deplorable Bitter Clinger
    NEPA
    2023 TRD Offroad
    Sticker on the inside of the door says 30psi. I thought I knew better than that shortly after picking up my '23 TRDOR and inflated them to 35psi. Found out it rides better (less jarring on bumps) with 30psi. So, 30psi it is.
    Steves104x4 and RedWings44 like this.
  19. Nov 1, 2023 at 6:12 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    These threads always crack me up. You can safely run a pressure that is at least what the placard shows up to the max pressure on the tire. Of course these are always cold pressures. Anything in between is up to you, your driving style and your comfort.
    And as always the chalk test is pointless and a total waste of time. I have no idea why people still suggest that nonsense. There is zero scientific data that is provided from that.
  20. Nov 6, 2023 at 8:22 PM
    camposme
    camposme Well-Known Member
    Ty
    Piedmont Triad - NC
    '16 TRD Sport DCSB
    Fox 2.5 Racing Suspension w/ Resi (ET) OME Dakars (Med Duty) SPC UCAs BAMF Grille TRD Skid TRD Wheels Tom Woods DS
    You'll have a little bit of convex nature to your tire profile which would create some uneven wear maybe? Whatever feels comfortable within the recommended tire limits should work well.
