Tacoma not emissions ready wtf
Discussion in '1st Gen. Tacomas (1995-2004)' started by fortiz619, Mar 22, 2020.
  1. Mar 22, 2020 at 10:16 PM
    fortiz619
    fortiz619 [OP] yeh i drive a 2wd big woop wanna fight about it?
    Southern California , IE ,SD
    04 Tacito 5lug, 16 tundra, 07 tundra
    Title explains it all, after installing my new carb legal header on my 2rz my obd2 scanner saids it’s not emission ready , I’ve got no CEL but my scanner does flash a “cat” problem , so now I wonder if it’s the header causing this or just a coincidence that my cats or 02 sensors going bad , No leaks and all stock exhaust
  2. Mar 22, 2020 at 10:16 PM
    Bishop84
    Bishop84 Well-Known Member
    How long did you drive it since reseting the code?
    Wyoming09 likes this.
  3. Mar 22, 2020 at 10:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Disconnect battery, leave alone for 15mins, reconnect, drive and enjoy.
    fortiz619[QUOTED][OP] likes this.
  4. Mar 22, 2020 at 10:17 PM
    fortiz619
    I’ve got NO CELs
  5. Mar 22, 2020 at 10:19 PM
    fortiz619
    I’ve read this couple minutes ago , might give it a try , I’m praying it’s not the header since it took me forever To install since bolts stripped
  6. Mar 22, 2020 at 10:29 PM
    Glamisman
    Glamisman Well-Known Member
    not emissions ready indicates that not all of the smog monitors have been completed. I do not know what scanner you are using and having said that if it is a $20 scanner it will not tell you which monitors have been completed and passed. 99% of the time it is the evaporative monitors that have not been completed. There is only one way to run the evap monitors and it is as follows: The fuel tank MUST be between 1/4 and 3/4 full. The intake air temp sensor reading MUST be within 10 degrees of the engine coolant temperature and there MUST be a minimum of 8 hours of the vehicle sitting with the ignition off and this must happen twice.
  7. Mar 22, 2020 at 10:37 PM
    fortiz619
    Ok thanks for the info , My scanner isn’t that best but it’s not The worst out there and no it’s doesn’t provide me with all that information you mentioned it’s just telling me it’s not ready “yellow”
  8. Mar 23, 2020 at 12:13 AM
    ForestRunnerFrank99
    ForestRunnerFrank99 Well-Known Member
    Josh
    Rancho Cucamonga, CA
    '99 TRD 4x4 Manual 3.4l v6
    Fox Coil-overs, Dakar Leafs, Intake, Tires, Rims
    Have you disconnected your battery recently? If you did you need to drive enough for the emissions system to complete it's check protocol. Having a CEL means nothing in this case, just that the system hasn't thrown a code yet since the computer was reset. Depending on how you drive this could take days or weeks to clear. I have a very similar scanner and the yellow light means it's checking everything and so far everything is good. I can't tell you exactly what the I/M Monitoring Status symbols mean, but I know they tell you what point the vehicle is in emission checking.
    I deal with emissions crap all the time here in California. As long as you don't throw a CEL then you'll be fine.
    As a note, the green light does not necessarily mean you will pass smog, just that they will check it for you.
    fortiz619[OP] likes this.
  9. Mar 23, 2020 at 12:21 AM
    fortiz619
    Oh ok , I’m going to give it a while and run it for a couple more days
  10. Mar 23, 2020 at 1:41 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have had it take more then 500 miles to cycle all the tests.
    Clear any codes or disconnect the battery your starting over.
    ForestRunnerFrank99 likes this.
  11. Mar 23, 2020 at 1:49 AM
    ForestRunnerFrank99
    Josh
    Same, I have had it take months. Toyota has protocols and they can take time. Somewhere there are steps to complete the drive cycle from Toyota, it could speed up your process if you can find them.
    cruiserguy and fortiz619[OP] like this.
  12. Mar 23, 2020 at 1:53 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I have tried the forced protocols my luck was never good always one test would not cycle and never the same one on different vehicles
  13. Mar 23, 2020 at 2:12 AM
    tony2018
    tony2018 Well-Known Member
    you have to drive it around
  14. Mar 23, 2020 at 8:30 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :popcorn:
    Hobbs likes this.
  15. Mar 23, 2020 at 8:33 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    :popcorn::popcorn:
    Kwikvette[QUOTED] likes this.
  16. Mar 23, 2020 at 8:36 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Here is a drive cycle that works well on Toyotas when trying to set the readiness monitors to pass an emissions test.
    • Fuel tank at 1/2 full.
    • Engine cold start idle for 10 minutes.
    • Drive at highway speed 55-60 mph with steady throttle for 16 minutes.
    • Return to idle for three minutes with engine running in park.
    • Drive again at medium speed 40 mph for eight minutes.
    • Return to idle for three minutes.
    • Repeat next day.
    One monitor requires a minimum temperature of 40 °F. If your climate is below this temperature at night, the evap monitor will not complete. You must park the vehicle in a heated garage above 40° F for 12 hours, with the key off and fuel tank at 1/2, to run the evap monitor.
  17. Mar 23, 2020 at 3:29 PM
    fortiz619
    I’m going to try this now since freeways here are empty thank you
    zippsub9[QUOTED] and cruiserguy like this.
  18. Mar 23, 2020 at 5:03 PM
    btu44
    btu44 Well-Known Member
    Long Beach area, Ca
    04 Tacoma Double Cab, 4WD, TRD Off-Road
    SC with 7th injector. ICON 2.5 shocks and coil overs, SPC UCA, EMU Dakar rear springs. FrontRunner bed rack. ICOM IC7100 amateur transceiver
    This is much easier than this almost impossible to understand Toyota procedure...but it's the quickest.
    cruiserguy and zippsub9[QUOTED] like this.
  19. Mar 23, 2020 at 5:10 PM
    fortiz619
    I can’t believe it worked scanner turned green , I did exactly what you said ,you the man !
  20. Mar 23, 2020 at 6:23 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Awesome!
    cruiserguy likes this.
