Tacoma model differences?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BellyUpFish, Feb 12, 2015.
  1. Feb 12, 2015 at 9:39 PM
    BellyUpFish
    BellyUpFish [OP] Well-Known Member
    Could someone break down the different models for me?
    I'm thinking about buying one? If I can sell my current ride. I'll probably try and buy a 2013ish model.
    Tacoma TRD Sport
    Tacoma TRD 4x4
    Any any others?
  2. Feb 13, 2015 at 5:56 AM
    FASTK
    FASTK Well-Known Member
    Gregg
    Columbus
    2010 4dr 4x4 long bed
    You're in the 3rd generation discussion forum (2016), post this in the second generation forum for a response.
  3. Feb 13, 2015 at 5:57 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
  4. Feb 13, 2015 at 5:57 AM
    The_Hodge
    SC
    it's been moved.
  5. Feb 13, 2015 at 6:59 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    This plus I believe the Off-road package comes with the BFG AT tires (16" rim) and the Sport has street tires on a 17" rim.
  6. Feb 13, 2015 at 7:02 AM
    Capt Jrod
    Capt Jrod Well-Known Member
    Jarrod
    Northern Ohio
    15 WHITE DCSB 4x4 TRD SPORT
    All sounds right above. If buying new, make sure the dealer doesn't bling it out with overpriced oem accessories eg: $500 chrome tube steps, $150 floor mats, stainless exhaust tip,etc... A good dealer will remove these items and deduct it from the price. I knocked off $750 dollars and got the tubes for free! I got the DCSB trd sport, but I don't really off road it. As the almighty OZ says I do some hardcore mall crawling, and I am the coolest dad at ballet class. I also don't like the bling of the chrome.
  7. Feb 13, 2015 at 7:08 AM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
  8. Feb 13, 2015 at 9:39 AM
    Pigpen
    Northwest Montana
    Base model FTW!
    Get all the safety features without over paying for parts you're going to replace anyway.
  9. Feb 13, 2015 at 9:42 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Guess it depends on where you are looking: http://www.discounttiredirect.com/d....do&fl=&pc=38175&counter=0&ar=70&rd=16&cs=265
    8.4/10 isn't too bad
  10. Feb 13, 2015 at 9:51 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    [/thread]
  11. Feb 13, 2015 at 10:00 AM
    allen993
    allen993 Well-Known Member
    Allen
    Alabama
    2019 TRD Off-Road, Access Cab, Cement
    I believe it's more like $299...:eek:
  12. Feb 13, 2015 at 10:13 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    :cheers:
    Correct me if I am wrong, I think you can get a TRD Sport and a TRD Off Road in 2WD as well. Not always 4X4. I recently upgraded from a Prerunner SR5 DCLB, to a TRD OR AC 4x4, and really like the better seats in the TRD, DC Long bed only available in TRD Sport, and SR5 trims, no DCLB (6') in TRD OR. All Access cabs (AC) are the 6' bed. Good luck in your hunt !
  13. Feb 13, 2015 at 10:48 AM
    Wiggins
    Wiggins Well-Known Member
    Jacksonville
    14 MGM DCSB 4x4 TRD OR
    TRD Sport Hood, ICON 3" Lift - 700lb coils, Total Chaos UCAs 5% Tinted Windows Crystal Front Window Film 2.5 resi shocks front and rear, dakar leaf packs Wheelers Bump Stops All-Pro Offroad APEX Front Plate Bumper, PIAA Fog Lights, PIAA Fog Lights, Black Line-X All-Pro Offroad Skid Plates, Black Line-X All-Pro Offroad APEX Rear Plate Bumper, Side Armor for Plate, Hidden Receiver Hitch, Black All-Pro Offroad APEX Sliders,Line-X All-Pro Offroad APEX Pack Rack, Black Line-X, 16" height ScanTool 427201 OBDLink LX Bluetooth Hankook Dynapro ATM 285/75/16 Vision Manx 16"x8" rims, 4.5" Backspacing Warn M8000-s Winch, Factor55 Flatlink, Factor55 1" Hawse Fairlead RIGID Industries Ditch Lights Tractor Supply Bed Box 260amp H.O. Alternator Big 3 Cable Replacement NorthStar AGM34 battery Pelfreybilt Battery Cage Plefreybilt Fuse Plate BlueSea fuse block Kenwood TS-B2000 Short Wave Radio, Remote face, Pack Rack Mounted Antenna Uniden Bearcat CB Cab Mount Chop (BAMF Inserts) TODO: ARB Air System ARB Rear Air Locker w/ 4.88 gears ARB Front Air Locker w/ 4.88 gears HID Retrofit Headlights Rigid Industries RDS-Series 54" Midnight Edition LED Rigid Industries R2-46 Combo Round Light (x2)
    They cost less... and that works out for a lot of people really well until they're sitting in a lifted truck, getting tugged out of a hole by a frickin' Subaru.
  14. Feb 13, 2015 at 11:07 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    As far as cost savings go the difference between the TRD packages and the SR5 package is not that large (around $1500), while the difference between TRD and base/convenience packages is quite a bit larger. So if you want the SR5 features and will ever go off road I'd say go for a TRD package. If you want to replace nearly everything on the truck anyway then there is some reason to consider a base/convenience package using the savings to upgrade. Remember, you can't finance your upgrades but you can finance the TRD option package.
    As others said, the TRD Sport doesn't really add anything for off-road. The hood scoop is of course useless and 16" rims on the TRD Off Road are preferred to 17" rims on the TRD Sport for off road. Of course the TRD Off Road also comes with a rear locker, ATRAC and on automatics DAC as well. That also means a better integrated brake booster and ABS system on the TRD Off Road.
    To me if you want off road performance your best options are:
    TRD Off Road
    Base/Convenience with a lot of your own stuff added
  15. Feb 14, 2015 at 4:37 PM
    BellyUpFish
    Thanks for all the replies guys. I've got a lot of learn.
    I've never owned a truck and think a Tacoma may be the first..
  16. Apr 20, 2015 at 7:10 PM
    BellyUpFish
    Well, I sold the WRX.. Tacoma here I come.. Drove a handful today..
    Now it's time to find "the one.."
  17. Apr 20, 2015 at 8:08 PM
    Holeshot
    Holeshot Well-Known Member
    Gary
    Alabama
    15 Doublecab TRD Off Road 4 X 4
    This. I could not have said it better myself.
