Tacoma Longevity, Just Hit 180k
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tedNugent, Sep 15, 2024.
  1. Sep 15, 2024 at 2:44 PM
    tedNugent
    tedNugent [OP] Well-Known Member
    ted
    2019 trd Sport
    Finally hitting the 180k mile mark on my third gen. No problems or complaints aside from dealing with Toyota dealers for maintenance. I'm a little worried about longevity. My issue is the dealer I was going to told me I didn't need transmission oil changes because it has "Lifetime fluid", and even denied me a transmission oil change all the way up until I hit 111k when i finally started getting a transmission shudder. Then they advised I get it flushed, and the flush fixed the issue. I just got my second transmission oil change at 165, but i'm a bit worried about if the damage has already been done to the transmission due to the lack of transmission maintenance. Dealers really have no idea what they're doing. I want this truck to go 500k+ if possible.
    I change oil every 5-7k, got front diff changed at 60k, and rear diff changed at 120k.
    Anyone have any insight??
    tcaustin likes this.
  2. Sep 15, 2024 at 3:55 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Some of the transmission guys on the site recommend platinum lube guard additive. Of course you want it to be added earlier than 180k
  3. Sep 15, 2024 at 5:00 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Be sure you are checking out the Maintenance Map.
    https://www.tacomaworld.com/threads/2-7l-update-3rd-gen-maintenance-maps-get-300k-miles.789809/
    Here is a good video from post #1.
    https://www.youtube.com/watch?v=0aEkJhPr5u4
    Tocamo and TN1000 like this.
  4. Sep 15, 2024 at 5:16 PM
    Stuck in VT
    Stuck in VT Well-Known Member
    Utah
    2019 SR SX MGM
    Strange. I had an independent shop and the dealer tell me I needed it done. 62k miles.
    Road_Warrior likes this.
  5. Sep 15, 2024 at 5:27 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    180k.... sweet.... ( applauds )
    Lifetime fluid?...
    Yea. Right.
    Ask them to define 'Lifetime'... 100k?.... 200k?.... 500k?
    I got some ocean-front property in Kansas I'll let it go for a real good price.
  6. Sep 15, 2024 at 5:44 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I am surprised to hear dealers are still turning away customers wanting an ATF change. They could at least question the customer to see if he/she meets special operating conditions. The maintenance schedule for all non hybrid Toyota and Lexus vehicles I have seen states to do an ATF change at 60K if the vehicle meets certain driving conditions, such as towing, off-roading, commercial-use, etc…
    Speedbird likes this.
  7. Sep 15, 2024 at 5:51 PM
    medicfung
    medicfung Well-Known Member
    richie
    2019 DC TRD OFFROAD 4x4 6ft bed quicksand
    I have 109k on my supercharged taco. Maggie was installed at 45k, and has been flawless. I have no doubt it’ll last another 109k without issues. All recommended maintenance has been performed by a local toyota dealer.
  8. Sep 15, 2024 at 5:51 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    1st Gen dude lurking. Call me when you hit 277k. :D ( Company just started us on 50/50 in office/home mix. Haven't been driving much in the last 3 years. I suspect I'll be at 300 in no time. )
    As for the dealer snubbing you on the trans fluid. That should be done around 60k miles. 3rd Gen's should be the same/similar. 100k in the diff fluid is also cringeworthy. I do diff, trans, and transfer all at 60k. Coolant too, it will get acidic after a while and eat at things in the engine. Look at the Car Care Nut channel video he just posted about V8's blowing head gaskets. He thinks coolant played a part.
    02Duck, Road_Warrior and Chew like this.
  9. Sep 15, 2024 at 6:34 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    My neighbor is a master Toyota wrench dude and says 100k for tranny juice. Just hit 69k so I’ll take his advice as well as a coolant, brake fluid and PS fluid swap.
  10. Sep 16, 2024 at 4:15 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    My 18 has 30k and I had a retired Toyota mechanic do all the fluids front and rear diffs, transfer case, serpentine belt, plugs, tranny drain and fill, radiator flush, AC service just because it's coming up on 7 years old. Never had the vibrations or funky transmission issues and I can tell a difference as its so much smoother now but it could be in my head.
    turbosnail likes this.
  11. Sep 16, 2024 at 8:36 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Any dealer that is pushing you away from fluid changes and then recommending fluid flushes needs to be flushed themselves. I wouldn't go back.
    e_engstro, TnShooter and Chew like this.
  12. Sep 16, 2024 at 8:57 AM
    tedNugent
    ted
    2019 trd Sport
    :( That's what I get for taking advice from a "Tech" who pushes tune-ups and cleaners every time I would go. I am not the mechanic type, so I was hoping the dealership I bought the truck from would steer me in the right direction. I guess not. So would you say I am screwed and need to get rid of the thing asap before it breaks? I was thinking I could trade it in for a newer 3rd gen with 30k miles so I can do it the right way this time.
  13. Sep 16, 2024 at 8:58 AM
    tedNugent
    ted
    2019 trd Sport
    Lowe toyota in warner robins GA. Yes, I'm putting them on blast because hopefully this will save someone else from the same issue.
  14. Sep 16, 2024 at 9:02 AM
    tedNugent
    ted
    2019 trd Sport
    Nice!!! 277k is awesome! I'm so frsutrated right now at this point because it just seems that dealerships are bad all-around. Sales, maintanence, and just all-around. And they fake their own reviews to cover their tracks!
    auskip07 and JJ04TACO[QUOTED] like this.
  15. Sep 16, 2024 at 9:38 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    No one knows the outcome, you did what you can do, you can go back in time. I wouldn't sell it off or stress over what you can't control. Any high mileage (whatever one considers that to be) can and will have problems; that is the risk we accept, when are reaping the rewards of not paying for a new vehicle.
    Enjoy your truck and don't sweat it.
  16. Sep 16, 2024 at 3:03 PM
    tedNugent
    ted
    2019 trd Sport
    Thanks for the advice! I think i'll keep it
    Chew[QUOTED] likes this.
  17. Sep 16, 2024 at 7:19 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    No need to panic, just stay on top of the fluids, and take care of it. Plenty of people have held off the trans fluid, you aren't the first. Just don't buy "lifetime" anything. Take what people say and find a reasonable middle. Some will say 100k is fine (I don't) but most advice will average out to around 60k. Fluid is cheap-ish compared to transmissions and the associated downtime from a failure. Same w/ other fluids.
    I do all my own fluids (trans, transfer case, diff, brake, steering, coolant)/maint myself. 3rd suspension, plugs, wires, coils, starter, alternator, radiator, valve cover gaskets, O2 sensors, plenum gaskets, brake calipers, rear drum cylinders, all pads, shoes, carrier bearing, UCA's, all bushings, leaf springs, fuel filter, trans filter, master cylinder, brake booster, idler pully, hoses, thermostats. I'm probably forgetting something lol. Go get your hands dirty. :D
    02Duck and Chew like this.
  18. Sep 16, 2024 at 7:34 PM
    TN1000
    TN1000 Well-Known Member
    2018 metallic silver TRD OR
    Work in progress
  19. Sep 17, 2024 at 3:55 AM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    If it’s running fine , why would you be nervous. Just do it every 60 k going forward . As much a people complain about out auto trans , it’s pretty much bullet proof . Yes it has little things here and there but it sounds like you will be fine . When you do the fluid try not to do a flush , it stirs up a bunch of debris. Just do a drain and refill like I said every 60 k
  20. Sep 17, 2024 at 4:22 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Sounds like it’s doing well.
    I thought our 3rd gens were supposed to self destruct by 100k :rofl:
    Chew and auskip07 like this.
