Tacoma Key Programming
Discussion in '2nd Gen. Tacomas (2005-2015)' started by seric007, Sep 8, 2012.
  1. Aug 10, 2016 at 7:17 PM
    #101
    Ross09
    Ross09 Well-Known Member
    Greeneville,TN
    2009 DCLB base 4x4
    Just did this today for my 09 taco. Followed instructions fully and it worked flawlessly. Got my programmer and blank off of Amazon for $17 total. Ace Hardware cut my blank for $1. Thanks OP
    Armed in Utah and YanE30M3 like this.
  2. Dec 28, 2016 at 10:59 AM
    #102
    JohnnyRed
    JohnnyRed Well-Known Member
    Northern Kentucky
    2008 DCLB TRD Sport
    I followed these directions and was able to program my new key. However, the immobilizer light continues to flash when the truck is running. I tried turning it from off to on 10 times quickly and it still doesn't reset. Anyone have any ideas? It's an 08 Tacoma.
    I found a video on youtube that shows what my truck is doing: https://www.youtube.com/watch?v=YFZxo1loupw
    I noticed a few quirks during my programming:
    I only had 2 sets of beeps, there was no long 3rd beep. (it beeped when I plugged it in and after about 30 seconds it beeped 3 times)
    The immobilizer light never turned on solid when programming the keys, it always flashed.
    I bought the truck and only received 1 key...I have a theory that I have the Valet Key and I've been able to program another Valet key. Does anyone with a valet key know if their light flashes when the truck is running? I don't remember my truck flashing like this before....but I may not have been paying attention.
  3. Dec 28, 2016 at 1:31 PM
    #103
    Sae68
    Sae68 Well-Known Member
    JimS
    Stockton, CA
    05 FJ 4x4 PreRunner
    I did the something . Don't remember if my immobilizer light already blinking before or after I program new key.
    No issue with the new key or keyless remote .
  4. Apr 26, 2017 at 5:00 PM
    #104
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
  5. Jun 17, 2017 at 6:12 PM
    #105
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    15 TRD Sport (DCLB-BRM) - 88 ///M3 (Zinnoberrot)
    OME 887/Dakars/NV305s/33" Duratracs/+
  6. Jul 13, 2017 at 11:29 AM
    #106
    zh137dz
    zh137dz Well-Known Member
    Nashville, TN
    2012 Tacoma Prerunner TRD Sport
    too many lights
    Has anyone successfully programmed a key for a 2012? My key programmer beeps once when plugged in and then about 30 seconds later it beeps continuously like there's an error. None of the methods have worked for me.
  7. Jul 13, 2017 at 11:43 AM
    #107
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  8. Jul 13, 2017 at 5:12 PM
    #108
    The Mad Hatta
    The Mad Hatta Free Dominion
    White Sands Missile Range, NM
    2012 DC SB TRD Sport, built into the Free Dominion vehicle
    Built the Free Dominion overland vehicle in 3 weeks. Check out my build thread for pics.
    I'm also trying to program a second key for a 2012. I bought the green OBD II transponder adder tool and aftermarket keys (the ones that already have a transponder code, which need to be added to the truck's list of accepted codes, by the green box). The green box says it works for Toyota G and H keys. Mine does the quick beep when plugged in, then immediately does two long beeps like it is supposed to, then nothing. The security light never starts blinking and the followup two beeps are never heard (it says this should happen 2-3 minutes later). I've seen mixed reviews of these online. I'm getting pretty annoyed with it though.
  9. Jul 14, 2017 at 8:04 AM
    #109
    zh137dz
    Nashville, TN
    too many lights
    I'm wondering if I got a bum transponder since it just does a ton of beeps and nothing at all similar to everyone else's experiences.
  10. Jul 14, 2017 at 8:55 AM
    #110
    anonemoose
    anonemoose Well-Known Member
    Bill
    Big Pine, Calif
    2015 White TRD Sport V6 DCSB
    Ride-Rites, Everything Weather-Tech Makes Added some 12 volt outlets with relays
    So, a question.... I did not get a valet key from my dealer when I bought it new. He said it had one, BS. Now wants to charge me for one. I do not see any instructions for creating a valet key only for a new master key. Since the dealer can make one there must be a way. Is there a difference in the key? Can I buy a valet blank and have it cut and program it?
    Thanks
  11. Jul 14, 2017 at 8:56 AM
    #111
    The Mad Hatta
    Well the transponder is in the key, and it doesn't beep. I think you mean the transponder-adder tool. These are cheaply made in China, so it doesn't surprise me that many of them are junk that don't work correctly. My first one made no noise at all, as if it weren't even initializing. It took me 2 weeks to get the seller to send me a replacement. The replacement beeps as it should, but the truck never is placed in the programming mode. I don't know if it's a problem with the tool, or if the tool simply doesn't work with the 2012 tacoma.
  12. Jul 18, 2017 at 7:42 PM
    #112
    Tac11
    Tac11 Well-Known Member
    Luis
    2011 white Tacoma sport TRD
    3" Front lift OME/5100 set at 0, 1/4 spacer on driver side CMC, BFG 285's, SCS ray 10’s -38 offset 1 inch rear block N-Fab steps Bumper Cali Raised LED light bar Cali Raised LED fog lights After market exhaust, and muffler tip Redline hood struts Tacoma Bed-liner mat Tailgate lock Tinted windows 20% HID headlights Short antenna Clazzio Seat covers Joying head unit
    Will this work for my 2011? I don't have a master key it looks like the valet key
  13. Sep 19, 2017 at 2:46 PM
    #113
    Strummer
    Strummer Well-Known Member
    Keith
    Tacoma 4x4 4 dr long bed
    Going to be doing this soon. Just bought a truck only had one key. Already ordered the keys and fobs . Now for the programmer .mine is a 2006 so I guess it will work?
    Tac11 likes this.
  14. Sep 19, 2017 at 3:19 PM
    #114
    Tac11
    Luis
    what year?
  15. Sep 19, 2017 at 3:20 PM
    #115
    Strummer
    Keith
    It's a 2006
  16. Sep 19, 2017 at 3:20 PM
    #116
    Tac11
    Luis
    lmk how it goes
  17. Sep 19, 2017 at 3:21 PM
    #117
    Tac11
    Luis
    I have 11 w only one key.. I cut the key but still need to program it
  18. Sep 20, 2017 at 10:21 AM
    #118
    zh137dz
    Nashville, TN
    too many lights
    I tried with my 2012 and haven't been able to enter programming mode with the ODBII tool. It just beeps continuously.
  19. Dec 4, 2017 at 5:51 PM
    #119
    Willyummk
    Willyummk Well-Known Member
    Will
    HA TO CA
    2011 DCSB TRD Sport
    So the guy I bought my truck from was kinda shady so I order new locks for doors, ignition cylinder and 3 keys. Do I still need to program the keys if I replace the whole. cylinder(tumbler)? And does this work with G key blades? This post just told me to move on because I have a G Blade key https://www.tacomaworld.com/threads/updated-tacoma-key-programming.356068/
  20. Dec 5, 2017 at 7:27 AM
    #120
    The Mad Hatta
    It is designed to work with G keys, but I could not get it to work on my tacoma. This would not work for your situation anyway, because this device requires you to have 1 programmed key to duplicate to the other keys. If you're changing locks and cylinder, you won't have any programmed keys. You'll need to have a professional locksmith do it. My locksmith cut and programmed 2 extra keys for $60 total, so you should be able to find someone to do it for far less than the dealership.
