Tacoma heat blend door
Discussion in '2nd Gen. Tacomas (2005-2015)' started by "OldManTan", Jan 4, 2011.
  1. Jan 4, 2011 at 12:13 AM
    "OldManTan"
    "OldManTan" [OP] Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    For the past few winters I have been wondering why my cab doesn't heat up quickly. Well I think the blend door hasn't been working properly. I thought I read on here about problems with them, but can't find it now. When I attempt to turn the heat full hot, it starts clicking. I can only turn the heat control to about 3/4 before the clicking starts. Actually feels like an improvement over before, but what can I look at to fix it fully. I haven't had a chance to look at it, so pardon the dumb question. Just looking for a place to start, or tips on how to go about it. Thanks as always for the help....
  2. Jan 4, 2011 at 9:41 AM
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
  3. Jan 4, 2011 at 9:44 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
  4. Jan 4, 2011 at 9:56 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I gotta ask...What's a blend door?
  5. Jan 4, 2011 at 10:45 AM
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
    The blend door is what changes the air temp coming out of the HVAC system. When you turn the dial to cool it moves to allow the cold air in and vice versa. It is located under the dash and if you move it while the truck is off and ignition on you should hear it.
  6. Jan 4, 2011 at 10:05 PM
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
